    How do I home my Z axis with BLTouch?
    My Duet controlled machine
    936
    • TRATOONundefined
      TRATOON
      Whenever I home all the Z-Axis goes down and then stops, the probe doesn't deploy (I have dual z axis by the way).
        Post your config.g homez.g and homeall.g
        Also send M122 and M98 P"config.g" and post the results.
        TRATOONundefined 1 Reply Last reply Reply Quote 0
        • TRATOONundefined
          TRATOON @Phaedrux
          @phaedrux Config: ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 23:00:27 GMT-0700 (Pacific Daylight Time)
          M550 P"Ender 5 Plus" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M92 X80.00 Y80.00 Z800.00 E409.00 ; set steps per mm
          M566 X600.00 Y600.00 Z30.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z480.00 E7200.00 ; set maximum speeds (mm/min)
          M201 X1500.00 Y1500.00 Z100.00 E6000.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X20 Y20 Z0 S1 ; set axis minima
          M208 X320 Y320 Z350 S0 ; set axis maxima
          M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
          M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
          M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-41 Y-2 Z3.75 ; set Z probe trigger value, offset and trigger height
          M557 X35:215 Y35:195 S20 ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 ; configure sensor 0 as thermistor on pin bedtemp
          M143 H0 S100 ; set temperature limit for heater 0 to 100C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
          M563 P0 S"Nozzle" D0 H1 F0 ; define tool 0
          Homez.g: ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 23:00:28 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G90
          G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered
          G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
          G30
          ;G91 ; relative positioning
          ;G90 ; absolute positioning
          M122: === Diagnostics ===
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
          Board ID: 0JD0M-9P6M2-NW4SS-6JKD8-3SN6Q-1UWMK
          Used output buffers: 3 of 24 (21 max)
          Static ram: 23868
          Dynamic ram: 74300 of which 0 recycled
          Never used RAM 13912, free system stack 184 words
          Tasks: NETWORK(ready,13.1%,226) HEAT(notifyWait,0.0%,316) Move(notifyWait,0.0%,364) MAIN(running,85.5%,460) IDLE(ready,1.3%,30), total 100.0%
          Owned mutexes:
          Last reset 00:01:12 ago, cause: power up
          Last software reset at 2022-04-22 10:52, reason: User, GCodes spinning, available RAM 13764, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 21.4, current 26.6, max 26.9
          Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min n/a
          Driver 2: standstill, SG min n/a
          Driver 3: standstill, SG min n/a
          Driver 4: standstill, SG min n/a
          Driver 5:
          Driver 6:
          Driver 7:
          Driver 8:
          Driver 9:
          Driver 10:
          Driver 11:
          Date/time: 2022-04-22 11:15:32
          Cache data hit count 2490559107
          Slowest loop: 8.64ms; fastest: 0.18ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 3.3ms, write time 0.0ms, max retries 0
          DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          === AuxDDARing ===
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty
          === Network ===
          Slowest loop: 15.64ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address e0:98:06:a4:42:62
            WiFi Vcc 3.36, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 24560
            WiFi IP address 192.168.1.148
            WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
            Socket states: 4 0 0 0 0 0 0 0
          M98:
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Warning: Macro file config-override.g not found
          fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @TRATOON
            @tratoon
            If that Z homing code was generated by the configuration tool the tool is confused.
            That is homing code when you have a Z endstop sensor 0 thus the G1 H1 Z-355 F1800 command which moves the bed toward the nozzle (or nozzle toward bed) until the Z endstop sensor is activated.
            But you configuration file doesn't configure a Z endstop sensor, only X and Y.
            I don't home Z with my Z probe so my example code below may not be entirely correct.
            This assumes X and Y have already been homed, which is a requirement for homing with a Z probe.
            G1 H2 Z5 F6000    ; lift Z relative to current position - we are about to move X and Y and we want to be sure the nozzle is clear of the bed.
            G1 Xaaa Ybbb Fccc ; move the probe to the center of the bed - for aaa, bbb, ccc use values suitable for your printer
            G30               ; probe the bed and set the logical position of Z thus homing the Z axis
            Hope that works for you.
            • TRATOONundefined
              TRATOON @fcwilt
              @fcwilt So do I replace everything in homez.g with the code you provided or just specific lines. If specific lines, please mention which ones.
                Phaedrux Moderator @TRATOON
                @tratoon said in How do I home my Z axis with BLTouch?:
                Really you just need to delete these lines.
                Also check your homeall.g
                TRATOONundefined 2 Replies Last reply Reply Quote 0
                • TRATOONundefined
                  TRATOON @Phaedrux
                  @phaedrux homez.g:
                  ; homez.g
                  M98 P"homex.g"
                  M98 P"homey.g"
                  G1 X175 Y175 F6000 ; move the probe to the center of the bed - for aaa, bbb, ccc use values suitable for your printer
                  homeall.g:
                  ; homeall.g
                  ; called to home all axes
                  G1 H1 X305 Y305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                  G1 H2 X-5 Y-5 F6000 ; go back a few mm
                  G1 H1 X305 Y305 F360 ; move slowly to X and Y axis endstops once more (second pass)
                  G1 H1 Z-355 F360 ; move Z down stopping at the endstop
                  does this look correct?
                  • TRATOONundefined
                    TRATOON @Phaedrux
                    @phaedrux said in How do I home my Z axis with BLTouch?:
                    homeall.g:
                    ; homeall.g
                    Is this correct?
                      Delete this part and replace it with this part
