    Help with setting up new Duet 6HC/3HC and Panel 7i
    duet 6hc duet
    792
      Use fallback #2 to flash it via USB
      https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
      Or connect the Duet to the network and use the webui.
      rmilyardundefined 1 Reply Last reply Reply Quote 0
      • rmilyardundefined
        rmilyard @Phaedrux
        @phaedrux so in BOSSA getting just this when click write. Never moves %
          Can you try with this version of Bossa?
          https://github.com/Duet3D/BOSSA/releases/tag/1.9.1a-duet3d
          What file specifically are you trying to flash?
          rmilyardundefined 2 Replies Last reply Reply Quote 0
          • rmilyardundefined
            rmilyard @Phaedrux
            @phaedrux Duet3Firmware_MB6HC.bin
            • rmilyardundefined
              rmilyard @Phaedrux
              @phaedrux after messing with it more I think have 3.4.0 on duet and 1.2.4 on panel 7
              FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-03-15 18:57:26<LF>ok<LF>
                Phaedrux Moderator @rmilyard
                @rmilyard said in Help with setting up new Duet 6HC/3HC and Panel 7i:
                1.2.4 on panel 7
                You may want to update to the latest 3.x version available for the paneldue.
                Now that the Duet is updated you can try connecting to the Pi again. Make sure the SD card is removed from the Duet.
                • rmilyardundefined
                  rmilyard @Phaedrux
                  @phaedrux I flashed PanelDue-v3-7.0.bin164
                  As for connecting to pi still same. Just not sure.
                  dc42undefined rmilyardundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @rmilyard
                    That's the wrong binary for a 7i. It may work, but the colours will be wrong.
                    • rmilyardundefined
                      rmilyard @rmilyard
                      So wrong bin? Have the 7" PanelDue V3.0
                      Stephen6309undefined 1 Reply Last reply Reply Quote 0
                      • Stephen6309undefined
                        Stephen6309 @rmilyard
                        @rmilyard If you have the 7" PanelDue with the addon board that mounts via header pins, that the correct firmware.
                        The addon Board: https://www.filastruder.com/collections/electronics/products/paneldue
                        7i: https://www.filastruder.com/products/paneldue-7i
