3.3 to 3.4 on Duet2Ethernet DWC Reconnecting/crashing
Firmware installation
714
    How did you update to 3.4? Did you upload the full zip file? Is DWC also updated?
    undefined 1 Reply Last reply 21 Mar 2022, 21:53 Reply Quote 0
      clegg78 @Phaedrux
      @phaedrux Yeah full zip file upload. I am tempted to try it again. And thanks for the note on the MAC change, I kind of skipped over the Duet 3 notes since this is a 2. DWC looks like its updated, looks different and says its 3.4 so I am guessing it is is updated.
      You can see in the log above the "Operation failed (Reason: Service Unavailable)" is noted, that is what I have been seeing.
      A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
        @clegg78 said in 3.3 to 3.4 on Duet2Ethernet MAC Change? DWC issues?:
        Can you share your config.g and the results of M98 P"config.g" please?
        undefined 1 Reply Last reply 22 Mar 2022, 03:30 Reply Quote 0
          clegg78 @Phaedrux
          @phaedrux
          Yeah absolutely:
          G90                                                    ; send absolute coordinates...
          M83                                                    ; ...but relative extruder moves
          M550 P"JK3D.us IDEXRig v3.4.0"                                     ; set printer name
          M929 P"eventlog.txt" S1 ; Set event log
          M575 P1 S1 B57600 									; Enable Panel Due Port.
          M555 P2                                            	; Set firmware compatibility to look like Marlin
          G21                                                	; Work in millimetres
          M552 S1	 ; DHCP
          ;M552 P192.168.50.45 S1                                 ; enable network and set IP address
          ;M553 P255.255.255.0                                    ; set netmask
          ;M554 P192.168.50.1                                     ; set gateway
          M586 P0 S1                                             ; enable HTTP
          M586 P1 S0                                            ; enable FTP
          M586 P2 S0                                             ; disable Telnet
          ;##########Motor/Movement/Build Area##############
          ; Movement section
          M569 P0 S0; Drive 0 goes backwards(change to S0 to reverse it) -X
          M569 P1 S1 ; Drive 1 goes forwards ZL
          M569 P2 S1 ; Drive 2 goes forwards ZR
          M569 P3 S0 ; Drive 3 goes backwards E0
          M569 P4 S1 ; Drive 4 goes forwards E1
          M569 P5 S1 ; Drive 5 goes forwards U
          M569 P6 S1 ; Drive 6 goes backwards Y
          M569 P7 S0 ; Drive 7 goes forwards Y
          ;M569 P8 S1 ; Drive 8 goes forwards
          ;M569 P9 S1 ; Drive 9 goes forwards
          ; Motor Assignments
          M584 X0 Y6:7 Z1:2 U5 E3:4 ; U Axis for second X stepper, dual X and Dual Y and dualZ
          M350 Z16 I1;
          M350 X16 Y16 U16 I1; Configure microstepping with interpolation
          M92 X200.00 U200.00 Y200.00 Z1600 E809.00:395.2          ; set steps per mm (Updated for Hemera - 409 is stock)
          ; FEEDRATE CONVERSIONS
          	; 20mm/s = F1200
          	; 70mm/s = F4200
          	; 120mm/s = F7200
          	;200mm/s = 12000
          M201 X2000 Y2000 U2000 Z500 E7000:7000; Accelerations (mm/s^2)
          M203 X18000 Y18000 U18000 Z1800 E15000:15000 ; Maximum speeds (mm/min)
          M205 X15 Y15 U15 Z10 E50:50 ; Maximum jerk speeds mm/sec  (Lowered to 13 for X and U in testing was 15 to check for skipped steps)
          M566 P1 ; Set Jerk Policy to 1
          M204 P3000 T4000			; Set printing and travel accelerations
          M906 X1200 Y1400 U1200 Z1200 E900:900 I15; Set motor currents (mA) and motor idle factor in percent  (Raised X and U to 1100 for testing to overcome skippe steps)
          M84 S240                                               ; Set idle timeout
          ; Home to the Min of X, Max of Y, Max of U set that to get the center zero.   Use the non home axis as travel limits.
          M208 X152.5 Y180.4 U203.59 Z300 ; Set axis maxima (adjust to suit your machine) Add U+ to move alignment to the left.
          M208 X-200 Y-189.5 U-152.5 Z0 S1 ; Set axis minimum (adjust to make X=0 and Y=0 the CENTER of the bed)   X Changed to 200 -3mm between the X and U wit the U being 3mm further back, so add -3 to the Y number
          M574 X1 S1 P"xstop"                                    ; configure active-high endstop for low end on X via pin xstop
          M574 Y2 S1 P"ystop"                                    ; configure active-high endstop for low end on Y via pin ystop
          M574 U2 S1 P"e0stop"                                    ; configure active-high endstop for High end on U via pin e0Endstop
          ;M574 Z2 S1 P"zstop"                                    ; configure active-high endstop for low end on Y via pin zstop
          M574 Z1 S2                                             ; configure Z-probe endstop for low end on Z
          ;Motor Stall Detection
          M915 X Y U F0 R2 S15
          M915 Z F0 R2 S30
          ;Code to calibrate the lead screws
          M671 X-265:265 Y0:0 S1 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis Max correction of 1
          ; #######Z-Probe#######
          M950 S0 C"duex.pwm1"                                 ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H2.5 F70 T7500 A10 R0.5 S0.004       ; set Z probe type to bltouch and the dive height + speeds
          G31 P25 X16 Y28 Z1.67              ;  Set Z probe trigger value (Higher the number the closer to the nozzle) Increased from 1.66 to 69 on 9/22
          M557 X-145:145 Y-145:145 S48.3                        ; define mesh grid
          M376 H8				; Taper off compensation over 10mm of height
          M564 S0 ; Allow moving out of range.
          ; ##########Heaters/Sensors###################
          ;BED HEADTER
          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950         ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat"T0 Q10                                ; create bed heater output on bedheat and map it to sensor 0
          M143 H0 S135                                           ; set temperature limit for heater 0 to 135C
          M307 H0 B0 S1.00                                     ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                ; map heated bed to heater 0
          ;E0
          ;V6 Thermistor Cartridge E0
          ;M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
          ;V7 Beta Thermistor E0
          ;V6 PT1000
          M308 S1 P"e0temp" Y"pt1000" ; temp Sensor for V6 E0 with PT1000
          M950 H1 C"e0heat" T1 Q100                                 ; create nozzle heater output on e0heat and map it to sensor 1
          M143 H1 S400                                           ; set temperature limit for heater 1 to 400C - Copper Block,NozzleX, Ti Heatbreak, 40W Precision Heater.
          ; V7 300C Max temp
          ;M143 H1 S315   										; set temperature limit for heater 1 to 300C
          M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
          ;E1
          ;V6 Thermistor Cartridge E1
          ;M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin e1temp
          ;V6 E1 PT1000
          M308 S2 P"e1temp" Y"pt1000" ; temp Sensor for V6 E0 with PT1000
          M950 H2 C"e1heat" T2 Q100                                 ; create nozzle heater output on e1heat and map it to sensor 2
          ;M143 H2 S285                                           ; set temperature limit for heater 2 to 285C
          ;V7 300C Max temp
          M143 H2 S325                                         ; set temperature limit for heater 2 to 300C
          M307 H2 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
          ;PT1000 calibration sensor
          ;M308 S8 P"duex.e5temp" Y"pt1000" A"Calibration"; sensor 8 (disabled for when not being used)
          ;Virtual Sensors
          M308 S3 P"mcu-temp" Y"mcu-temp" A"MCU"					  ; set virtual heater for MCU
          M308 S4 P"drivers"  Y"drivers" A"Driver"				  ; set virtual heater for stepper drivers
          ;DHT Sensor
          M308 S5 P"duex.cs6" Y"dht22" A"Chamber Temp"
          M308 S6 P"S5.1" Y"dhthumidity" A"Chamber Humidity"
          ; ##########Fans#############
          M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
          M106 P0 C"E0 Part Fan" S0 H-1                          ; set fan 0 name and value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
          M106 P1 C"E1 Part Fan" S0 H-1                          ; set fan 1 name and value. Thermostatic control is turned off
          M950 F2 C"fan2" Q1                                   ; create fan 2 on pin fan2 and set its frequency
          M106 P2 C"System Board Fans" S0 H3:4 T44:55 L50 X255             ; set fan 2 name and value. Thermostatic control is turned on
          M950 F3 C"duex.fan3" Q500                              ; create fan 3 on pin duex.fan3 and set its frequency
          M106 P3 C"E0 HE Fan" S1 H1 T80 L0 X255                      ; set fan 3 name and value. Thermostatic control is turned on
          M950 F4 C"duex.fan4" Q500                              ; create fan 4 on pin duex.fan4 and set its frequency
          M106 P4 C"E1 HE Fan" S1 H2 T80 L0 X255                       ; set fan 4 name and value. Thermostatic control is turned on
          M950 F5 C"duex.fan5" Q500                              ; create fan 5 on pin duex.fan5 and set its frequency
          ;#####LEDS###########
          M106 P5 C"Pause LED" S0 H-1                            ; set fan 5 name and value. Thermostatic control is turned off
          M950 F6 C"duex.fan6" Q500                              ; create fan 6 on pin duex.fan6 and set its frequency
          M106 P6 C"E0 LED" S0 H-1                               ; set fan 6 name and value. Thermostatic control is turned off
          M950 F7 C"duex.fan7" Q500                              ; create fan 7 on pin duex.fan7 and set its frequency
          M106 P7 C"E1 LED" S0 H-1                               ; set fan 7 name and value. Thermostatic control is turned off
          M950 F8 C"duex.fan8" Q500                              ; create fan 8 on pin duex.fan8 and set its frequency
          ;M106 P8 C"Bed LED" S0 H-1                        ; ###Commented out, no longer bed fan####set fan 8 name and value. Thermostatic control is turned off  (### Going to bereplaced with chamber fan script)
          ;##### 24v Duex Heaters as Fan outputs
          ;M950 H3 C"duex.e3heat" Q500 T8
          ;M141 H3 P0; Set chamber heater Not needed right now
          ;M106 P9 C"DummyHeater" S255 H-1
          ;M950 F10 C"duex.e4heat" Q500
          ;M106 P10 C"HeaterLED2" S255 H-1
          ;M950 F11 C"duex.e5heat" Q500
          ;M106 P11 C"HeaterLED3" S255 H-1
          ;M950 F12 C"duex.e6heat" Q500
          ;M106 P12 C"HeaterLED4" S255 H-1
          ;############Call Chamber Fans##########
          M98 P"/macros/jobscripts/ChamberFan.g"
          ;############Call Filament Sensor Configurations########
          M98 P"/macros/jobscripts/FilamentSensor.g"
          ;############Call Pressure Advance ########
          M98 P"/macros/jobscripts/PressureAdvance.g"
          ;############Call InputShaping ########
          M98 P"/macros/jobscripts/InputShaping.g"
          ;########Cold Extrusion Limit##########
          M302 S185 R185
          ;Filament settings
          M404 N1.75 D0.4
          ;############Extend TEMPERATURE FAULT WARNINGS - ONLY FOR Nozzle/Tool changes
          ;M570 H1 P90 T80	;Heater 1 (E0) Extended Fault Warnings
          ;M570 H2 P90 T80	;Heater 2 (E1) extended fault warnings
          ;Disable heater warnings for
          ;###TOOL DEFINITIONS####
          ; Tool 0 X - Left hand Extruder
          M563 P0 D0 H1 F0 X0 S"Left Titan Aero"    ; tool 0 uses extruder 0 and heater 1 and maps X to X, use fan 2 as the print cooling fan
          G10 P0 X0 Y0 Z0                              ; Set tool 0 axis offsets
          ;G10 P0 R0 S0                                  ; Set initial tool 0 active and standby temperatures to 0C
          ;Tool 1 U - Right hand Extruder Hemera
          M563 P1 D1 H2 X3 F1 S"Right Hemera"      ; tool 1 uses extruder 1 and heater 2 and maps X to U, use fan 1 as the print cooling fan
          G10 P1 X0 Y-5.38 Z0    ; Set initial tool 1 active and standby temperatures to 0C (Higher the negative number the futher back in the Y the U axis alings)
          ;G10 P1 R0 S0                                  ; Set initial tool 0 active and standby temperatures to 0C
          ; Duplication Tool 2
          M563 P2 D0:1 H1:2 X0:3 F0:1 S"Dual Duplication Print" ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
          G10 P2 X76 Y0 U-76 Z0   ; set tool offsets and temperatures for tool 2
          ;G10 P2 R0 S0
          M567 P2 E1:1 ; set mix ratio 100% on both extruders
          ; Mirror Tool 3
          M563 P3 D0:1 H1:2 X0:3 F0:1 S"Dual Mirror Print" ; tool 2 uses both extruders and hot end heaters, maps X to both X and U, and uses both print cooling fans
          G10 P3 X85 Y0 U-85 Z0    ; set tool offsets and temperatures for tool 2 (+10mm offset for clearance due to the mirroring movements)
          ;G10 P3 R0 S0
          M567 P3 E1:1 ; set mix ratio 100% on both extruders
          M501                                                   ; load saved parameters from non-volatile memory
          undefined 1 Reply Last reply 22 Mar 2022, 06:20 Reply Quote 0
            Phaedrux Moderator @clegg78
            Can you try with logging disabled? It can be quite resource intensive.
            MCU temperature: min 27.3, current 45.1, max 45.9
            Is your board actively cooled?
            undefined 1 Reply Last reply 24 Apr 2022, 20:11 Reply Quote 0
              clegg78 @Phaedrux
              @phaedrux Sorry I thought I replied - yes the board is actively cooled, it has a air channel with constant airflow (and thermostatically controlled fans that keep the MCU from going above 45C or so. )
              I can disable the eventlog and try, not much goes in there other than the start/stop of the prints it seems.
              Everything on this printer was relatively error free until 3.4.0 upgrade caused this pretty chaotic DWC stability issue. I've noticed it from multiple PCs and sometimes DWC wont even come up on mobile devices for some weird reason.
              undefined 1 Reply Last reply 24 Apr 2022, 23:03 Reply Quote 0
                clegg78 @clegg78
                Update on some testing @Phaedrux @dc42
                I disabled both my filament sensors for some testing (Duet Rotating magnet sensors v1.7). 2x of them.
                If I enable either of them, DWC constantly reconnects. if I enable both, it gets crazy.
                If both are disabled the DWC instance is stable. You can see the sequence here, the system is stable, I enable one of the sensors, and DWC starts dropping and reconnecting.
                My Tool 0 sensor: M591 D0 P3 C"e1_stop" S1 R40:140 L26 E60
                My Tool 1 sensor: M591 D1 P3 C"connlcd.enca" S1 R40:140 L26 E60
                This is crazy repeatable as well.
                  Interesting. Would you be able to downgrade to 3.3 and see if the behaviour is definitely isolated to 3.4?
                  https://github.com/Duet3D/RepRapFirmware/releases/download/3.3/Duet2and3Firmware-3.3.zip
                  undefined 1 Reply Last reply 25 Apr 2022, 17:03 Reply Quote 0
                    clegg78 @Phaedrux
                    @phaedrux I am in the middle of a large set of production runs on the machine and I am not sure I have my 3.3 config saved (I should, but I need to find it) if I can get a gap I will test, but I had none of these issues before upgrading.
                    dc42undefined 1 Reply Last reply 25 Apr 2022, 21:03 Reply Quote 0
                      dc42 administrators @clegg78
                      @clegg78 it could be that the object model has grown too large for the output buffers. Please provide your config.g file so that I can investigate this.
                      undefined 1 Reply Last reply 25 Apr 2022, 22:34 Reply Quote 0
                        clegg78 @dc42
                        @dc42 Here is my config:
                        M929 P"eventlog2.txt" S1 ; Set event log
                        M552 S1	 ; DHCP
                        ; Movement section
                        ; Motor Assignments
                        M350 Z16 I1;
                        	; 20mm/s = F1200
                        	; 70mm/s = F4200
                        	; 120mm/s = F7200
                        	;200mm/s = 12000
                        M201 X2000 Y1800 U2000 Z500 E7000:7000; Accelerations (mm/s^2)
                        M205 X15 Y13 U15 Z10 E50:50 ; Maximum jerk speeds mm/sec  (Lowered to 13 for X and U in testing was 15 to check for skipped steps)
                        M208 X152.5 Y180.4 U203.45 Z300 ; Set axis maxima (adjust to suit your machine) Add U+ to move alignment to the left.  Moved to .45 from .59 after machine warmed
                        M915 Z F0 R2 S30
                        ;BED HEADTER
                        ;E0
                        ;V6 PT1000
                        ;E1
                        ;V6 E1 PT1000
                        M143 H2 S400                                         ; set temperature limit for heater 2 to 400C
                        ;Virtual Sensors
                        ;DHT Sensor
                        M302 S185 R185
                        ;Filament settings
                        M404 N1.75 D0.4
                        ;G10 P2 R0 S0
                        ; Mirror Tool 3
                        ;G10 P3 R0 S0
                        Filamentsensor.g:
                        M591 D0 P3 C"e1_stop" S1 R40:140 L26 E60 ;
                        M591 D1 P3 C"connlcd.enca" S1 R40:140 L26 E60 ;
                        undefined 1 Reply Last reply 15 May 2022, 19:18 Reply Quote 0
                          clegg78 @clegg78
                          @dc42 I upgraded to the 3.4.1 RC that is posted and it seems to have remedied a most of the disconnections! I am seeing the max Output buffers go to 26, but in general no (or many less) crashes or reconnections like was happening before.
                          M122
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1rc1 (2022-05-03 09:34:00) running on Duet Ethernet 1.02 or later + DueX5
                          Board ID: 08DGM-917NK-F23T0-6J1F6-3SD6T-1GBWD
                          Used output buffers: 7 of 26 (26 max)
                          Static ram: 23868
                          Dynamic ram: 74972 of which 0 recycled
                          Never used RAM 9088, free system stack 96 words
                          Tasks: NETWORK(ready,203.0%,218) HEAT(notifyWait,5.1%,307) Move(notifyWait,209.7%,283) DUEX(notifyWait,0.0%,24) MAIN(running,149.4%,425) IDLE(ready,0.1%,30), total 567.3%
                          Owned mutexes:
                          Last reset 23:10:43 ago, cause: software
                          Last software reset at 2022-05-14 14:04, reason: User, GCodes spinning, available RAM 9256, slot 1
                          Error status: 0x0c
                          Aux0 errors 0,1,0
                          Step timer max interval 0
                          MCU temperature: min 42.8, current 45.7, max 46.8
                          Supply voltage: min 23.8, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/670/646, gc cycles 0
                          Events: 1 queued, 1 completed
                          Driver 0: standstill, SG min 3
                          Driver 1: ok, SG min 0
                          Driver 2: ok, SG min 0
                          Driver 3: standstill, SG min 0
                          Driver 4: ok, SG min 0
                          Driver 5: ok, SG min 37
                          Driver 6: ok, SG min 9
                          Driver 7: ok, SG min 10
                          Driver 8: standstill, SG min n/a
                          Driver 9: standstill, SG min n/a
                          Driver 10:
                          Driver 11:
                          Date/time: 2022-05-15 13:15:30
                          Slowest loop: 350.13ms; fastest: 0.14ms
                          === Storage ===
                          Free file entries: 8
                          SD card longest read time 22.2ms, write time 10.3ms, max retries 0
                          DMs created 83, segments created 54, maxWait 25947876ms, bed compensation in use: mesh, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 18853, completed 18813, hiccups 0, stepErrors 0, LaErrors 0, Underruns [356, 0, 0], CDDA state 3
                          === AuxDDARing ===
                          Heater 0 is on, I-accum = 0.0
                          Heater 2 is on, I-accum = 0.7
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is doing "G1 X-24.463 Y21.930 E0.0324" in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Code queue is empty
                          === Filament sensors ===
                          Extruder 0: pos 2.11, errs: frame 1 parity 0 ovrun 0 pol 0 ovdue 0
                          Extruder 1: pos 328.01, errs: frame 0 parity 0 ovrun 0 pol 1 ovdue 0
                          === DueX ===
                          Read count 1, 0.00 reads/min
                          === Network ===
                          Slowest loop: 161.96ms; fastest: 0.00ms
                          HTTP sessions: 1 of 8
                          Interface state active, link 100Mbps full duplex
