DUEX 0.11 FAN 5
@dc42 said in DUEX 0.11 FAN 5:
@paolozampini1973 what do you mean by "pin 17" ?
Thank you for answering me I wasn't hoping for it anymore I have been trying to talk to her for a long time.
axis Y external DRIVER 7 ( WHEN switch to mode ON PIN17 = EN + 3.3V switch to mode ON FAN 5
WHEN switch to mode OFF PIN 17 = EN + 0.0V switch to mode OFF FAN 5 )
axis X external DRIVER 8 ( WHEN switch to mode ON PIN 22 = EN + 3.3V switch to mode ON FAN 6
WHEN switch to mode OFF PIN 22 = EN + 0.0V switch to mode OFF FAN 6 )
I want to specify that the dwelling of the X and Y motor and the disabling of the x & y motor works perfectly at the beginning Print skills and x & y motors at the end of the print disables the X and Y motors this function works perfectly
@paolozampini1973 so you are looking to turn a fan on when an external driver enable pin is activated, and off when it is deactivated.
I think you can do that in RRF 3.4.0 by pretending that the fan is a motor brake solenoid. Use the M569.7 command https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m5697-configure-motor-brake-port to associate that fan port with the motor.
the command 569.7 is not very clear how to use it there is a bit of confusion can you help me please I'll publish my config.g
config (33).g -
@paolozampini1973 said in DUEX 0.11 FAN 5:
config (33).g@dc42 Good evening can you help me please
Why not use a thermistor attached to the motor? Then you can also see what the motor temperature actually is to know if it's an issue or not. You're trying to make this the more complicated than necessary.
@phaedrux said in DUEX 0.11 FAN 5:
for the simple reason that I would have to make a structural change AND in any case it would not be 100% reliable it would be 96% reliable and also because I have to use the same rule for other things other functions
your solution is much cheaper but much more complicated and then I haven't solved all the problems. Anyway, thanks for your interest
the simplest solution is also to leave the fans on all the time
@paolozampini1973 I cannot find PIN17 in the list of official pin names. can you point me to wjhere that is and what it's name is in the documentation? I seem to be looking in the wrong place.
OK, I did read the documentation and I believe dc42 would like you to add the following to config.g instead of a normal fan definition for fan5. Assuming this is for motor number 7:
comment out the following lines from your config.g (lines 90 and 91):
M950 F5 C"duex.fan5" Q500 ; X create fan 1 on pin fan1 and set its frequency M106 P5 S1 H-1 ; set fan 1 value. Thermostatic control is turned on
make it that they look like this
; M950 F5 C"duex.fan5" Q500 ; X create fan 1 on pin fan1 and set its frequency ; M106 P5 S1 H-1 ; set fan 1 value. Thermostatic control is turned on
then, add the following line to your config.g (assuming driver 7):
M569.7 P0.7 C"duex.fan5"
restart your machine, make a move that uses motor 7. if the fan turns on while the motor is active, this setting works. If the fan is on when the motor is inactive and turns off when motor 7 works, change the M569.7 like this:
M569.7 P0.7 C"!fan0"
Note that this will always turn the fan on fully and that I have not tested this function myself.
@oliof said in DUEX 0.11 FAN 5:
30/4/2022, 18:38:03 M569.7 P0.7 C"fan5"
Warning: M569.7: Command is not supported30/4/2022, 18:37:12 M569.7 P0.7 C"duex.fan5"
Warning: M569.7: Command is not supportedThanks for your reply but the command is not supported
@paolozampini1973 from my original post:
so i should upgrade
The problem is that with my configuration I don't know what it means to me at What problems do I run into after what changes I have to makeam have RRF 3.3.0
my 3D printer now works very well however if I do the upgrade What are the changes I have to do next ?
@paolozampini1973 read the upgrade notes and make any required updates to your configuration: https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-340
Other than adding macros for heater fault I did not change a single thing on my machine, but yours is different and may need adjusting.
Ok I will read And anyway I will make a complete backup of the memory in case I should have problems I can go back
@paolozampini1973 backups are always a good idea. I have my configurations under version control and stored on github for easy reference and to make sure that in the case of local catastrophe I have a copy available elsewhere.
I'll probably do this upgrade tomorrow as temperatures and speeds improve what your opinion is ?
I am running my printers very conservatively, so I do not go for maximum speed.
I believe that a printer once that makes 70 - 80 mm is more than enough important to have the accuracy is the quality
