    PID problems
    921
    • BlitzRegundefined
      BlitzReg @Phaedrux
      @phaedrux
      m122
      5/5/2022, 2:20:12 PM m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later
      Board ID: 08DJM-9178L-L2MS8-6J1FL-3S06N-KBHGP
      Used output buffers: 3 of 24 (13 max)
      Static ram: 23868
      Dynamic ram: 74568 of which 40 recycled
      Never used RAM 13604, free system stack 184 words
      Tasks: NETWORK(ready,13.1%,236) HEAT(notifyWait,0.0%,332) Move(notifyWait,0.0%,364) MAIN(running,86.8%,440) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 01:05:34 ago, cause: software
      Last software reset at 2022-05-05 13:14, reason: User, GCodes spinning, available RAM 13604, slot 0
      Error status: 0x00
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 21.9, current 23.6, max 24.0
      Supply voltage: min 24.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2022-05-05 14:20:10
      Slowest loop: 4.93ms; fastest: 0.18ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.6ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Network ===
      Slowest loop: 15.75ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      • WiFi -
        Network state is active
        WiFi firmware version 1.26
        WiFi MAC address 84:0d:8e:b2:1e:40
        WiFi Vcc 3.42, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 25976
        WiFi IP address 192.168.86.101
        WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
        Clock register 00002002
      • BlitzRegundefined
        BlitzReg @Phaedrux
        @phaedrux said in PID problems:
        M98 P"config.g"
        5/5/2022, 2:21:34 PM M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Error: Heater 7 not found
        • BlitzRegundefined
          BlitzReg @Phaedrux
          @phaedrux yes external mosfet
          • BlitzRegundefined
            BlitzReg @Phaedrux
            @phaedrux I'm running pid tune now on the bed. The bed with a IR gun is 10C higher then what the thermistor is showing
            • BlitzRegundefined
              BlitzReg @Phaedrux
              @phaedrux
              • BlitzRegundefined
                BlitzReg @Phaedrux
                Yes, just looked up what I purchased and they are 3950. So , do I put B3950 ?
                  Phaedrux Moderator @BlitzReg
                  @blitzreg said in PID problems:
                  Yes.
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B3950
                  BlitzRegundefined 2 Replies Last reply Reply Quote 0
                  • BlitzRegundefined
                    BlitzReg @Phaedrux
                    @phaedrux hi so no C0 R4700 behind B3950? I'm running it now
                    • BlitzRegundefined
                      BlitzReg @Phaedrux
                      @phaedrux right now the thermistor in phase 3 reads 84 and the IR gun shows 96. Makes me wonder if the thermistor is bad
                        Where is the thermistor positioned to get the reading?
                        Are you measuring with the IR temp gun in the same location?
                        • BlitzRegundefined
                          BlitzReg @Phaedrux
                          @phaedrux no, I actually testing it all 4 corners and in the middle where the thermistor is located
                          • BlitzRegundefined
                            BlitzReg @Phaedrux
                            @phaedrux Almost 1 hour on phase 3. My other hypercube has already tuned using firm ware 1.21. now I'm wondering when I tell the extruder to heat to 220C its actually 220C. My first prints off them looked like they got pretty hot. I am using the e3d hemeria w/volcano direct drive. I also have their REVO
                              For the hotend you have a known thermistor and the correct values from E3D, so it should be as accurate as you can expect.
                              As for the bed, at 24v it takes a long time to heat up and it does many cycles, so it can take quite a while. Rather than tuning to 90c, try a more reachable temp like 60.
                              BlitzRegundefined 3 Replies Last reply Reply Quote 0
                              • BlitzRegundefined
                                BlitzReg @Phaedrux
                                @phaedrux Hi, the problem was the thermistor in the bed. I swapped it out and now the temps are almost the same between the panel and the IR Gun. Now the gremlin has move to the extruder. I have a REVO Hermera direct drive and it keeps getting heater faults. I have ver 3.4.0 and ran M303 T0 S240 and it tunes fine. But I noticed the the temp rises above the print temperature I set and keeps going until there is a heater fault.
                                • BlitzRegundefined
                                  BlitzReg @Phaedrux
                                  • BlitzRegundefined
                                    BlitzReg @Phaedrux
                                    @phaedrux Why is it saying Heater 0 when the fault happens on heater 1 the extruder? Not sure what is happening here!
                                      I think that is a bug in the displayed heater. Please update to 3.4.1 RC1
                                      https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.1rc1
                                      What did your tuned values result in?
                                      If the part cooling fan doesn't have a big impact on the heater, you can tune the hotend as a normal heater with M303 H1 S240 and see if it behaves better.
