    Some tools are not showed in Web interface ..
    Firmware installation
    • AllSiriusundefined
      AllSirius
      Trying to attach the clay extruder with dual motors but cant see it!
      Dear folks ! Anyone can see the problem?
      I'm using Duet Expansion Breakout Board And External Drivers.
      Sometime before I have already successfully used this setup with dual motors mixed extrusion. But new Resetup and version of the firmware making confuse.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu May 05 2022 09:25:32 GMT+0300 (Israel Daylight Time)
      M575 P1 S1 B57600                                               ; enable support for PanelDue
      G90                                                             ; send absolute coordinates...
      M83                                                             ; ...but relative extruder moves
      M550 P"Maker 1 Hybrid"                                          ; set printer name
      ;M453         			 ; CNC Mode
      ;M452 C"duex.pwm5" R255 F200         ; Enable Laser mode, on exp.heater3, with max intensity being 255, and a PWM frequency of 200
      M551 **                                               ; set password
      M552 S1                                                         ; enable network
      M586 P0 S1                                                      ; enable HTTP
      M586 P1 S0                                                      ; disable FTP
      M586 P2 S0                                                      ; disable Telnet
      M569 P0 S0                                                      ; physical drive 0 goes backwards
      M569 P1 S1                                                      ; physical drive 1 goes forwards
      M569 P2 S1                                                      ; physical drive 2 goes forwards
      M569 P3 S1                                                      ; physical drive 3 goes forwards
      M569 P4 R-1                                                     ; burn burn burn
      M569 P5 R1 T2.5:2.5:5:0 S1                                      ; physical drive 5 goes backwards --- Z MOTOR
      M569 P6 R1 T2.5:2.5:5:0 S1                                   ; physical drive 6 goes forwards ---- Y MOTOR
      M569 P7 R1 T2.5:2.5:5:0 S1                                   ; physical drive 6 goes forwards ---- Y MOTOR
      M569 P8 R1 T2.5:2.5:5:0 S1
      M584 X0 Y6:7 Z5 U1 E3:2:8   ; set drive mapping
      M350 X128 Y16 Z16 U128 E16:16:16 I1                                ; configure microstepping with interpolation
      M92 X640.00 Y171.00 Z5050.00 U640 E220:400:80            ; set steps per mm
      M566 X2000.00 Y1300.00 U4000 Z60.00 E800:20000:2000              ; set maximum instantaneous speed changes (mm/min)
      M203 X4000.00 Y4000.00 U21000 Z300.00 E1000:1800:22000        ; set maximum speeds (mm/min)
      M201 X600.00 Y600.00 U4500 Z80.00 E400:10000:1500        ; set accelerations (mm/s^2)
      M906 X1300 Y1200 Z700 U1200 E760:1000:900  I30                     ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                         ; Set idle timeout
      M208 X0 Y0 Z0 S1                                                ; set axis minima
      M208 X700 Y600 Z500 S0                                          ; set axis maxima
      M574 X1 S1 P"xstop"                                             ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                             ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M558 P0 H5 F120 T6000                                           ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                                        ; define mesh grid
      M140 H-1                                                        ; disable heated bed (overrides default heater mapping)
      M308 S0 P"e0temp" Y"thermistor" T100000 B3950                   ; configure sensor 0 as thermistor on pin e0temp
      M950 H1 C"e0heat" T0                                            ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H1 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S250                                                    ; set temperature limit for heater 0 to 250C
      M308 S2 P"e0temp2" Y"thermistor" T100000 B3950                   ; configure sensor 0 as thermistor on pin e0temp
      M950 H2 C"e0heat" T0                                            ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H2 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S120                                                   ; set temperature limit for heater 0 to 250C
      M950 F0 C"fan0" Q500                                            ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                                  ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                                            ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H0 T45                                                ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"Plastic" D2 H0 F0                                     ; define tool 0
      G10 P0 X0 Y0 Z0                                                 ; set tool 0 axis offsets
      G10 P0 R0 S0                                                    ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"Clay" D8 H1 F3                               ; define tool 2
      G10 P1 X0 Y0 Z0                                                 ; set tool 2 axis offsets
      G10 P1 R0 S0                                                    ; set initial tool 2 active and standby temperatures to 0C
      ;M568 P1 S1                                                      ; enable mixing for tool 2
      ;M567 P1 E0.5:0.5
      M563 P2 S"Spindle"                                        ; define tool 1
      G10 P2 X0 Y0 Z0                                                 ; set tool 1 axis offsets
      G10 P2 R0 S0                                                    ; set initial tool 1 active and standby temperatures to 0C
      M501                                                            ; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"              ; set voltage thresholds and actions to run on power loss
      1.PNG ![alt text](image url)
      I'll appreciate any help! Have tried so many combinations already , but no solution yet . .
        jay_s_uk @AllSirius
        @allsirius said in Some tools are not showed in Web interface ..:
        the driver number is the extruder driver that starts sequentially from 0 it is not the driver number
        So D8 should actually be D2. This also means D2 on your plastic tool should actually be D0
        You also call heater 1 for the clay tool and heater 0 for the plastic tool but theres no heater 0 so I assumed the plastic tool should be H0 not H1.
        And you call F3 for the clay tool but don't have an F3 defined
        AllSiriusundefined 2 Replies Last reply Reply Quote 3
          AllSirius @jay_s_uk
          @jay_s_uk
          Yeah, a messed up with heater , by giving a many trying attempts to see any different after all combinations with drivers %) Now I realised that made some mess. .
          I'll back to the first configuration ,I guess the heaters aren't a problem .
          And thanks allot for quick replay , I have a feeling it will solve it.. D8 is stone of all the problems)) !
          Hope I'll be back soon with the working config!
          Thanks a lot Jay!
            AllSirius @jay_s_uk
            @jay_s_uk Thanks again! it's alive! 😃
            If somebody will stuck with same kind of problem here is Config:
            ;M453         			 ; CNC Mode
            M551 P"******"                                                ; set password
            M584 X0 Y6:7 Z5 U1 E3:8:2   ; set drive mapping
            M350 X128 Y16 Z16 U128 E16 I1                                ; configure microstepping with interpolation
            M308 S0 P"e0temp" Y"thermistor" T100000 B4138                   ; configure sensor 0 as thermistor on pin e0temp
            M950 H0 C"e0heat" T0                                            ; create nozzle heater output on e0heat and map it to sensor 0
            M307 H0 B0 S1.00                                                ; disable bang-bang mode for heater  and set PWM limit
            M143 H0 S250                                                 ; set temperature limit for heater 0 to 250C
            M308 S1 P"e1temp" Y"thermistor" T100000 B4138                   ; configure sensor 0 as thermistor on pin e0temp
            M950 H1 C"e1heat" T1                                            ; create nozzle heater output on e0heat and map it to sensor 0
            M563 P0 S"Plastic" D0 H0 F0                                     ; define tool 0
            M563 P1 S"Clay" D2:1                                             ; define tool 2
            M567 P1 E0.5:0.5
            P.s. Still have some work to do with Laser and Spindle , but this story for another chapter .. ::)
            The Mixed 2motor extruder for clay are working! Cheers! 😉
            AllSiriusundefined 1 Reply Last reply Reply Quote 0
              AllSirius @AllSirius
              ;M453         			 ; CNC Mode
              M567 P1 E0.5:0.5
              BTW. if I use command M542 ; Enable Laser mode - it switching the DWC to CNC mode and there are no tools are showed at all.. But I'll back to it later !
                jay_s_uk @AllSirius
                @allsirius yes, thats pretty normal to switch to the CNC interface when in Laser mode as its then down to the gcode to control the laser using M3 (for on), M5 (for off) and then the S value in each G0/G1 move to control the laser power
