    BL Touch Probes Extremely Slowly
    488
    • TRATOONundefined
      TRATOON @fcwilt
      @fcwilt And it's not just the Z-Axis, whenever I start a print and it starts to home it is very slow when compared to homing it manually.
      • TRATOONundefined
        TRATOON
        @fcwilt I just changed Z Axis to 500. I got that number from somebody else's config for ender 5 plus (The Z axis on E5 Plus is really slow) And it was all the axis that were going slow not just the z
        • fcwiltundefined
          fcwilt @TRATOON
          @tratoon said in BL Touch Probes Extremely Slowly:
          I would need to see your homing code. The Z axis speed might be limiting homing.
          As a reference the Z axis max speed for all my printers is 1200.
          • TRATOONundefined
            TRATOON
            I just changed the 500 in m203 to 1200
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 23:00:17 GMT-0700 (Pacific Daylight Time)
            G91                   ; relative positioning
            G1 H2 Z5 F6000        ; lift Z relative to current position
            G1 H1 X285 Y285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 H2 X-5 Y-5 F6000   ; go back a few mm
            G1 H1 X285 Y285 F360  ; move slowly to X and Y axis endstops once more (second pass)
            G90             ; absolute positioning
            G1 X175 Y175 F6000 ; go to first probe point
            G30             ; home Z by probing the bed
            ;G91                  ; relative positioning
            ;G1 Z5 F100           ; lift Z relative to current position
            ;G90                  ; absolute positioning
            ; homex.g
            ; called to home the X axis
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Apr 21 2022 23:00:28 GMT-0700 (Pacific Daylight Time)
            G1 H1 X345 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 H2 X-5 F6000  ; go back a few mm
            G1 H1 X345 F360  ; move slowly to X axis endstop once more (second pass)
            G1 H2 Z-5 F6000  ; lower Z again
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y345 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 H2 Y-5 F6000  ; go back a few mm
            G1 H1 Y345 F360  ; move slowly to Y axis endstop once more (second pass)
            ; homez.g
            ; called to home the Z axis
            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Apr 30 2022 22:44:38 GMT-0700 (Pacific Daylight Time)
            Also why is it that only when its printing it homes slowly, but when I press the Home All in DWC it works fine? Could it be the GCODE File?
            • fcwiltundefined
              fcwilt @TRATOON
              @tratoon
              It could be. Some slicers have an option to change printer settings, like max speed.
              I always disable that feature, if it exists.
              You can post the first 50 lines of so of a file you are printing - it will likely be obvious from examining the code if the slicer is messing with your settings.
              TRATOONundefined 1 Reply Last reply Reply Quote 0
              • TRATOONundefined TRATOON marked this topic as a question
              • TRATOONundefined TRATOON has marked this topic as solved
              • TRATOONundefined TRATOON has marked this topic as unsolved
              • TRATOONundefined
                TRATOON @fcwilt
                @fcwilt
                ;FLAVOR:RepRap
                ;TIME:146379
                ;Filament used: 178.503m
                ;Layer height: 0.2
                ;MINX:121.595
                ;MINY:35.455
                ;MINZ:0.2
                ;MAXX:303.405
                ;MAXY:304.545
                ;MAXZ:37
                ;Generated with Cura_SteamEngine 4.12.1
                T0
                M190 S55
                M104 S195
                M109 S195
                M82 ;absolute extrusion mode
                M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
                M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
                M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
                M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
                M220 S100 ;Reset Feedrate
                M221 S100 ;Reset Flowrate
                G28 ;Home
                G29 ; Start BL-Touch Probing Sequence
                M420 S1 Z2 ;Enable ABL using saved Mesh and Fade Height
                G92 E0 ;Reset Extruder
                G1 Z2.0 F3000 ;Move Z Axis up
                G1 X10.1 Y20 Z0.28 F5000.0 ;Move to start position
                G1 X10.1 Y200.0 Z0.28 F1500.0 E15 ;Draw the first line
                G1 X10.4 Y200.0 Z0.28 F5000.0 ;Move to side a little
                G1 X10.4 Y20 Z0.28 F1500.0 E30 ;Draw the second line
                M83 ;relative extrusion mode
                G1 F2400 E-0.5
                ;LAYER_COUNT:185
                ;LAYER:0
                M107
                M204 T500
                ;MESH:20220402_Kavi_Gupta_Bottom_Base_Type_01.stl(2)
                G0 F15000 X174.977 Y158.881 Z0.2
                M204 P10000
                ;TYPE:WALL-INNER
                G1 F2400 E0.5
                G1 F12000 X176.08 Y158.783 E0.03683
                G1 X177.149 Y158.497 E0.03681
                G1 X178.153 Y158.029 E0.03684
                G1 X179.06 Y157.394 E0.03683
                G1 X179.844 Y156.609 E0.0369
                G1 X180.478 Y155.704 E0.03675
                G1 X180.947 Y154.697 E0.03695
                G1 X181.232 Y153.631 E0.0367
                G1 X181.33 Y152.525 E0.03693
                G1 X181.232 Y151.424 E0.03676
                G1 X180.945 Y150.352 E0.03691
                G1 X180.478 Y149.352 E0.03671
                G1 X179.841 Y148.442 E0.03695
                G1 X179.06 Y147.661 E0.03674
                G1 X178.153 Y147.026 E0.03683
                G1 X177.149 Y146.558 E0.03684
                G1 X176.08 Y146.272 E0.03681
                G1 X174.974 Y146.175 E0.03693
                G1 X173.873 Y146.272 E0.03676
                G1 X172.804 Y146.558 E0.03681
                G1 X171.798 Y147.027 E0.03692
                G1 X170.892 Y147.664 E0.03684
                G1 X170.11 Y148.444 E0.03674
                G1 X169.474 Y149.354 E0.03693
                G1 X169.006 Y150.358 E0.03684
                G1 X168.721 Y151.424 E0.0367
                G1 X168.624 Y152.528 E0.03686
                G1 X168.722 Y153.634 E0.03693
                G1 X169.007 Y154.7 E0.0367
                G1 X169.476 Y155.706 E0.03692
                G1 X170.112 Y156.612 E0.03682
                G1 X170.894 Y157.394 E0.03678
                G1 X171.801 Y158.029 E0.03683
                G1 X172.804 Y158.497 E0.03681
                G1 X173.873 Y158.783 E0.03681
                G1 X174.977 Y158.881 E0.03686
                G0 F15000 X174.977 Y158.479
                ;TYPE:WALL-OUTER
                G1 F12000 X176.01 Y158.388 E0.03449
                G1 X177.012 Y158.12 E0.0345
                G1 X177.952 Y157.681 E0.03451
                G1 X178.802 Y157.086 E0.03451
                G1 X179.536 Y156.351 E0.03455
                G1 X180.13 Y155.503 E0.03444
                G1 X180.57 Y154.56 E0.03461
                G1 X180.837 Y153.561 E0.03439
                G1 X180.928 Y152.525 E0.03459
                G1 X180.837 Y151.494 E0.03442
                G1 X180.568 Y150.49 E0.03457
                G1 X180.13 Y149.553 E0.0344
                G1 X179.533 Y148.7 E0.03463
                G1 X178.802 Y147.969 E0.03438
                G1 X177.952 Y147.374 E0.03451
                G1 X177.012 Y146.935 E0.03451
                  Phaedrux Moderator @TRATOON
                  Your slicer has these speed limiting commands in it's start gcode section. Remove them from the slicer.
                  TRATOONundefined 1 Reply Last reply Reply Quote 1
                  • TRATOONundefined
                    TRATOON @Phaedrux
                    @phaedrux Now whenever I change the initial layer speed it doesn't work, and prints it at normal speed, which causes adhesion problems.
                    • fcwiltundefined
                      fcwilt @TRATOON
                      Where are you changing that layer speed? It should be in the slicer.
                      • TRATOONundefined
                        TRATOON @fcwilt
                        @fcwilt It is in the slicer
