    DWC Seems to Crash After Uploading a Print
    Duet Web Control
    1.6k
    • clegg78undefined
      clegg78 @CCS86
      @ccs86 I have not. My machine is used for pretty consistent production use and the DWC thing is annoying, very annoying, but hasn't been a show stopper for it to run. And the code/config tweaks for 3.4.0 I don't want to unwind. I guess if it turns out there is no fix, I may have to go back.
      A geek designing and building his own custom IDEX printer from scratch as seen here: https://joekelly.co/3d/
      • CCS86undefined
        CCS86
        @Phaedrux @dc42
        We might want to move this thread.
        I just flashed back to RRF 3.4.0 RC1 (DWC 3.4.0 stable) and the issue vanishes.
          dc42 administrators @CCS86
          @ccs86 is this still on Duet Maestro?
          CCS86undefined 1 Reply Last reply Reply Quote 0
          • CCS86undefined
            CCS86 @dc42
            @dc42 Yes
              @ccs86 please provide your config.g file and any other macro files that it calls.
              • CCS86undefined
                CCS86 @dc42
                ; Configuration file for Duet Maestro (firmware version 3)
                G90                                                    ; absolute coordinates
                M83                                                    ; relative extruder
                M550 P"Maestro86"                                      ; set printer name
                M552 P0.0.0.0 S1                                       ; enable network and acquire dynamic address via DHCP
                M586 P0 S1                                             ; enable HTTP
                M586 P1 S0                                             ; disable FTP
                M586 P2 S0                                             ; disable Telnet
                M569 P0 S0                                             ; drive 0 goes backwards
                M569 P1 S1                                             ; drive 1 goes forwards
                M569 P2 S0                                             ; drive 2 goes backwards
                M569 P3 S0                                             ; drive 3 goes backwards
                M569 P0 D2 ;D3 V468					; X Stealthchop2 till about 10 mm/sec
                M569 P1 D2 ;D3 V468					; Y Stealthchop2 till about 10 mm/sec
                M569 P2 D3 V40 						; Z Stealthchop2 till about 46.9 mm/sec
                M569 P3 D2 						; Extruder in Spreadcyle
                M584 X1 Y0 Z2 E3                                       ; Drive mapping
                M92 X160.0 Y160.0 Z401.5 E695                          ; Steps per mm
                M350 X16 Y16 Z16 E16 I1                                ; Microstepping with interpolation
                M201 X5000.00 Y5000.00 Z230.00 E2500.00                ; Max accelerations (mm/s^2)
                M203 X12000.00 Y12000.00 Z2100.00 E2400.00             ; Max speeds (mm/min)
                M204 P2500 T4000                                       ; Accelerations (mm/s^2)
                ;M205 X12 Y12 Z3 E4.5                                  ; Maximum jerk rates (mm/s)
                M566 X600 Y600 Z180.0 E270 P1                          ; Maximum jerk rates (mm/min)
                M593 P"MZV" F40.5					; Input Shaping
                M572 D0 S0.032 						; Pressure Advance
                M906 X1300 Y1300 Z1400 E490 I50                        ; Motor currents (mA) and motor idle factor
                M84 S30                                                ; Idle timeout
                M208 X0 Y0 Z0 S1                                       ; Axis minima
                M208 X195 Y180 Z220 S0                                 ; Axis maxima
                M574 X1 S1 P"!xstop"                                   ; Active-high endstop for low end on X via pin !xstop
                M574 Y1 S1 P"!ystop"                                   ; Active-high endstop for low end on Y via pin !ystop
                M574 Z1 S2                                             ; Z endstop controlled by probe
                M558 P5 C"^zprobe.in" H5 F500 T6000 A1                 ; Z probe type to bltouch and the dive height + speeds
                M950 S0 C"zprobe.mod"                                  ; create servo pin 0 for BLTouch
                G31 P25 X20 Y-14 Z.98                                  ; Z probe trigger value, offset and trigger height
                M557 X20:195 Y0:166 S18.8                              ; define mesh grid
                M376 H1.5                                              ; mesh taper
                ;Accelerometer
                M955 P0 C"twck0+twd0" R12
                M308 S0 P"spi.cs1" Y"rtd-max31865"                     ; configure sensor 0 as a PT100 sensor in the first position on the Duet 2 daughter board connector
                M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
                M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                                ; map heated bed to heater 0
                M143 H0 S120                                           ; set temperature limit for bed heater 0
                M308 S1 P"e0temp" Y"pt1000" ;T100000 B4725 C7.06e-8    ; configure sensor 1 as PT1000 on pin e0temp
                M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
                M143 H1 S243                                           ; set temperature limit for nozzle heater 1
                M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater and set PWM limit
                M308 S2 Y"drivers" A"DRIVERS"                          ; configure sensor 2 as temperature warning and overheat flags on the TMC2660 on Duet
                M308 S3 Y"mcu-temp" A"MCU"                             ; configure sensor 3 as thermistor on pin e1temp for left stepper
                ; Heater model parameters
                ;Bed
                ;M307 H0 R0.194 C896.8 D2.07 S1.00
                ;M307 H0 R0.190 K0.196:0.000 D2.03 E1.35 S1.00 B0
                M307 H0 R0.190 K0.174:0.000 D1.95 E1.35 S1.00 B0
                ;Hotend
                ;M307 H1 R2.523 C231.0:134.5 D5.90 S1.00 V24.3
                ;M307 H1 R2.324 K0.389:0.146 D3.76 E1.35 S1.00 B0 V24.3
                M307 H1 R2.459 K0.398:0.160 D3.91 E1.35 S1.00 B0 V24.3
                M950 F0 C"fan0" Q500                                   ; create fan 0 on pin fan0 and set its frequency
                M106 P0 S0 H-1                                         ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"fan1" Q500                                   ; create fan 1 on pin fan1 and set its frequency
                M106 P1 S1 H1 T45 B1.5 X180                            ; set fan 1 value. Thermostatic control is turned on
                M950 F2 C"fan2" ;Q800                                  ; create fan 2 on pin fan2 and set its frequency
                M106 P2 H1:2:3 L1 X1 T53                               ; set fan 2 value
                M563 P0 S"E0" D0 H1 F0                                 ; define tool 0
                G10 P0 X0 Y0 Z0                                        ; set tool 0 axis offsets
                G10 P0 R0 S0                                           ; set initial tool 0 active and standby temperatures to 0C
                M595 P40
                T0                                                     ; select first tool
                • CCS86undefined
                  CCS86
                  Do you need anything else @dc42 ?
                  • CCS86undefined
                    CCS86 @CCS86
                    Does 3.4.1 have any potential improvements for this issue?
                      Phaedrux Moderator @CCS86
                      @ccs86 said in DWC Seems to Crash After Uploading a Print:
                      I'm not sure, but worth testing with the latest code base regardless.
                      • CCS86undefined
                        CCS86
                        Bug seems to be gone in 3.4.1 RC1
                          Thanks for confirming this. Based on your report and on another one on a Duet 2, I suspected that in some configurations parts of the object model might be getting too large to fit in the available buffer space to send to DWC. So in 3.4.1 I increased the buffer space on Duet 2 and Maestro, and shrunk the object model data a little.
                          • dc42undefined dc42 marked this topic as a question
                          • dc42undefined dc42 has marked this topic as solved
