    z axis homing fails... it just keeps clicking
    • The Chairmanundefined
      The Chairman
      X and y home fine. When I home z, Z0 does fine, while Z1 keeps clicking and bouncing.
      • fcwiltundefined
        fcwilt @The Chairman
        @the-chairman said in z axis homing fails... it just keeps clicking:
        Please don't overwhelm us with details. 😉
        Please copy-and-paste your config.g file and the various "homing" files - use the </> tag - one tag per file.
        The Chairmanundefined 2 Replies Last reply Reply Quote 1
          The Chairman @fcwilt
          @fcwilt Thanks for the input. I tried copying code on my phone yesterday and the forum gave me an error. A friend suggested that I run m119 in the console and it showed the z stop as being off. I looked over the wiring this morning to discover that the z probe cable was plugged into the wrong spot on the Duet. Problem solved.
          I am trying to suss out my Crealty CR Touch, but I'll start another thread on it when I'm ready for input.
            @fcwilt I'm having an issue with search on this forum. I'm trying to find how to set up the Crealty CR Touch and not coming up with much.
            Stephen6309undefined dc42undefined 2 Replies Last reply Reply Quote 0
            • Stephen6309undefined
              Stephen6309 @The Chairman
              @the-chairman Got to BLTouch at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting Creality has different wiring.
                dc42 administrators @The Chairman
                @the-chairman it looks like it's more or less compatible with BLTouch, see https://www.crealityofficial.co.uk/blogs/buyer_guides/bltouch-vs-cr-touch. If you configure it as for a BLTouch and it still doesn't work, I suggest you create a new thread.
                The Chairmanundefined 1 Reply Last reply Reply Quote 0
                • dc42undefined dc42 marked this topic as a question
                • dc42undefined dc42 has marked this topic as solved
                  The Chairman @dc42
                  @dc42 Thanks! I am currently getting this error:
                  G32 Error: Probe already triggered before probing move started
                  I'm not even sure I have it wired correctly, but I think I do. 😄 I'll check out that link in a bit and see if I can suss it out from there.
