    IDEX motor jitter
    Beta Firmware
    2.0k
    • MaxGyverundefined
      MaxGyver @fcwilt
      @fcwilt
      I am fairly certain that this is a firmware issue, since the problem is also present when U is driven from the main board and the same jittering is present in X when the second extruder (U-axis) is printing and the first extruder (X-axis) is only moving in Y.
      Right now, I am printing at 200mm/s with 5000mm/s² accelerations on X, Y and U. Although the jittering is less severe at lower speeds, it is still noticeable.
      EDIT:
      It is really hard to tell by watching the print. But I got the strong impression that the jitter only courses when the Y-Axis moves! When Y is stationary, the jitter is gone 😮
      dc42undefined fcwiltundefined 2 Replies Last reply Reply Quote 1
        dc42 administrators @MaxGyver
        @maxgyver do you have any toothed belts running over smooth idlers?
        MaxGyverundefined 1 Reply Last reply Reply Quote 0
        • MaxGyverundefined
          MaxGyver @dc42
          @dc42 said in IDEX motor jitter:
          Nope. I am a little offended by that. 😆 😉
          This is what I have done so far:
          • checked for loose pulleys
          • checked belt and belt path
          • checked if linear rails run smooth
          • checked motor cables and connectors
          • checked CAN cable (All from Kenable)
          • deactivated bed leveling
          • deactivated demon.g
          I have also rewritten most of my config file without success.
          • fcwiltundefined
            fcwilt @MaxGyver
            @maxgyver said in IDEX motor jitter:
            @fcwilt
            EDIT:
            I see you are using x32 micro-stepping for X, Y and U.
            And the speeds you mentioned (200mm/s) are rather fast.
            Perhaps the 6HC system cannot keep up?
            Could you try x16 micro-stepping at 100mm/s?
            I agree it may be the firmware. I am seeking to determine if there is a threshold condition that when crossed the problem appears.
            Disclaimer: I am still on firmware 3.3.0 as I am letting others deal with the issues in 3.4.x.
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 05 2020 11:42:30 GMT+0200 (Mitteleuropäische Sommerzeit)
            M550 P"Factory500"  ; set printer name
            ; Blower
            M950 F0 C"!out4+out4.tach" C"Blower" Q25000 ; create fan 0 on pin out4 and set its frequency
            M106 P0 X0.40 B0 H1:2 T80
            ; Chamer Fan
            M950 F4 C"!out5+out5.tach" A"Filter Fan"
            M106 P4 X0.30 B0 H0:1:2 T60
            ; Power ON
            M81 C"pson"
            M80 ; switch power on
            G4 S4 ; wait for expansion boards to boot
            M569 P0 S0 ; Drive 0.0/Z1 motor (rear left)
            M569 P1 S1 ; Drive 0.1/Z2 motor (rear right)
            M569 P2 S1 ; Drive 0.2/Z3 motor (front right)
            M569 P3 S0 ; Drive 0.3/Z4 motor (front left)
            M569 P4 S1 ; Drive 0.4/E1 motor
            M569 P5 S0 ; Drive 0.5/E2 motor
            ; Closed loop drives
            M569 P123.0 S0 ; X-Motor
            M569 P124.0 S0 ; U-Motor
            M569 P125.0 S0 ; Y1-Motor
            M569 P126.0 S1 ; Y2-Motor
            M569.1 P123.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 123 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            M569.1 P124.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 124 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            M569.1 P125.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 125 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            M569.1 P126.0 T2 C20 R125 I500 D0.1 H50 ; Configure the 1HCL board at CAN address 126 with a quadrature encoder on the motor shaft that has 20 steps per motor full step.
            ; Motion System
            M584 X123.0 Y125.0:126.0 Z0:1:2:3 U124.0 E4:5 ; set 4 Z drivers and add one U driver -> Must come earlier than M350,M906,M92, M201, M203, M208, M350, M566, M574, M667 and M669
            M350 X32 Y32 Z16 U32 E16:16 I1 ; Configure microstepping with interpolation
            M92  X160 Y160 Z640 U160 E400:400  ; Set steps per mm
            M203 X42000 Y42000 Z1800 U42000 E10000:10000; A40000 B40000 ; Set maximum speeds (mm/min)
            M566 X600 Y600 Z200 U600 E600:600 ; set maximum instantaneous speed changes (mm/min)
            M201 X30000 Y30000 Z500 U30000 E30000:30000 ;A6000 B6000 ; Set maximum accelerations (mm/s^2)
            M906 X2400 Y2400 Z1200 U2400 E900:900 I25 ;A300 B300 ; Set motor currents (mA) and motor idle factor in per cent
            M84 S5 ; Set idle timeout
            M917 X50 Y50 Z50 U50 ; Set holding current in percent
            ; Kinematics
            M669 K11 Y1:-1:0:-1 ; Matrix mapping for Axis - X:Y:Z:U
            ;M669 K11 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1 ; Matrix mapping for Axis - X:Y:Z:U
            ;M669 K1 X1:0:0:0 Y1:-1:0:-1 Z0:0:1:0 U0:0:0:1
            M671 X-41:495.5:495.5:-41 Y353:353:23:23 S10 ; lead screw positions and maximum allowed correction S in mm
            M208 X0 Y0 Z0 U0 S1 ; set axis minima
            M208 X405 Y323 Z350 U405 S0 ; set axis maxima
            M574 X1 S1 P"123.io1.in" ; configure active-high endstop for low end on X via pin io1.in
            M574 Y2 S1 P"126.io1.in" ; configure active-high endstop for low end on Y via pin io1.in
            M574 U2 S1 P"124.io1.in" ; configure active-high endstop for high end on U via pin io1.in
            M574 Z2 S1 P"io3.in" ; configure active-high endstop for high end on Z via pin io0.in
            M558 P5 C"io5.in" H2 A10 S0.01 R0 F300:150 T60000       ; IR Z-Probe 1: set Z probe type and the dive height + speeds
            M376 H10                                                ; Set height (mm) over which to taper off the bed compensation (should be 20x max mesh error)
            G31 P500 X0 Y20 Z1.5                                    ; Set Z probe parameters, lower Z-value -> nozzle further down
            ; Bed Heater
            M308 S0 P"temp0" A"Bed" Y"thermistor" T100000 B3950 ; define bed temperature sensor
            M950 H0 C"out8" Q10 T0 ; create bed heater output on bed output and map it to sensor 0
            M143 H0 S125 ; set temperature limit for heater 0 to 120C
            M307 H0 R0.383 K0.269:0.000 D2.81 E1.35 S1.00 B0 ; enable PWM mode for the bed heater and set PWM limit
            ; Hotend1 Heater
            M308 S1 P"temp1" A"Extruder1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
            M143 H1 S300 ; set temperature limit for heater 1 to 280C
            M307 H1 R2.872 K0.252:0.115 D1.45 E1.35 S1.00 B0 V23.8
            ; Hotend2 Heater
            M308 S2 P"temp2" A"Extruder2" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin temp2
            M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
            M143 H2 S300 ; set temperature limit for heater 2 to 280C
            M307 H2 R2.872 K0.252:0.115 D1.45 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
            ; tool 0, X-axis
            M563 P0 D0 H1 X0 F1 ; tool 0 uses extruder1 and heater 1 with fan 1 as the print cooling fan
            M568 P0 R0 S0 ; set standby and active temperatures for tool 0
            G10 P0 X0 Y0 Z0 S0 R0 ; set tool 0 offsets and temperatures
            M950 F1 C"out6" ; T0 Fan
            ; tool 1, U-axis
            M563 P1 D1 H2 X3 F2 ; tool 1 uses extruder2 and heater 2 with fan 2 as the print cooling fan and maps X to U
            M568 P1 R0 S0 ; set standby and active temperatures for tool 1
            G10 P1 X0 U1.6 Y0 Z0 S0 R0 ; set tool 1 offsets and temperatures. (increase U to move nozzle to the left)
            M950 F2 C"out7" ; T1 Fan
            ; Create a tool that prints 2 copies of the object using both carriages'''
            ;M563 P2 D0:1 H1:2 X0:3 F1:2 S"Duplication Mode" ; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
            ;G10 P2 X0 Y0 U-205 S0 R0 ; set tool offsets and temperatures
            ;M567 P2 E1:1 ; set mix ratio 100% on both extruders
            ; Create a tool that prints 2 mirrored copies of the object using both carriages'''
            ;M563 P3 D0:1 H1:2 X0:3 F1:2 S"Mirror Mode" ;tool 3 uses both extruders, hot end heaters and fans, and maps X to both X and U
            ;G10 P3 X0 Y0 U-465 S0 R0 ; set tool offsets and temperatures
            ;M567 P3 E1:1 ; set mix ratio 100% on both extruders
            ; Temp sensors
            M308 S7 Y"mcu-temp" A"MCU" ; configure sensor 5 as thermistor for MCU
            M308 S3 P"124.temp0" Y"pt1000" R2180     A"Chamber Temp." ; Setup temp  0  on 1HCL at CAN address 50 as sensor 3  - sensing the chamber temperature
            M308 S4 P"temp3" A"Blower Temp." Y"thermistor" T100000 B3950 ; define bed temperature sensor
             ; LED lights
            M950 P3 C"out3"
            M42 P3 S1
            ; Pressure Advance
            M572 D0:1 S0.02 ; Extruder Drive Number, Pressure advance amount
            ; Accelerometer
            ;M955 P0 C"io4.out+io4.in" I05
            ; input shaping
            ;M593 P"none" F99
            M501 ; set the active parameters to those stored in sys/config-override.g
            M291 P"The printer is not homed, home now?" R"Homing" S3
             G28```
              @maxgyver if the vibration occurs when both U and Y motors are driven from the main board, then I don't see how it can be a firmware issue, because in that configuration I can't see any way that the steps would get out of sync.
              MaxGyverundefined 1 Reply Last reply Reply Quote 1
              • martin7404undefined
                martin7404
                I had the same isue with duet wifi and duex5- double makfoged IDEx machine. In the end it was fualty driver on wifi board. New duet wifi solved the isue
                Muldex IDEX Duet2+Duex5
                Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
                Sapphire Pro with Duet2, with closed-loop motors
                custom high temp E3D tool changer with Duet2+Duex
                • fcwiltundefined
                  fcwilt @martin7404
                  @martin7404 said in IDEX motor jitter:
                  Since he was tried different drivers on the 6HC and on the three 1HCLs do you think a driver problem is likely?
                  • MaxGyverundefined
                    MaxGyver @dc42
                    The vibrations are still present when both U and Y motors are driven from the main board.
                    @fcwilt x16 microstepping makes no difference
                    What would be the theoretical maximum achievable speed for a system with dual mark forged belts?
                    I am interested in the math behind this.
                    I am using GT2 belts with 20teeth pulleys.
                    • MaxGyverundefined
                      MaxGyver @MaxGyver
                      I managed to get a slow motion shot of the U axis jitter. This was captured with U and Y driven from the main board.
                      Video
                      • fcwiltundefined
                        fcwilt @MaxGyver
                        Video
                        You are referring to the left/right motion?
                        Yes, quite obvious.
                        And if you connect the X driver to the U axis hardware and the U driver to the X axis hardware the problem moves to the X axis hardware?
                        • MaxGyverundefined
                          MaxGyver @fcwilt
                          @fcwilt said in IDEX motor jitter:
                          I can test this tomorrow, but when I print with the secondary extruder on the U axis, the same left/right motion is present in X. So I suppose it is not a problem with the U axis hardware.
                            @maxgyver do X, Y and U axes have the same steps/mm?
                            • MaxGyverundefined
                              MaxGyver @dc42
                              Yes.
                              I did also test different microstepping settings with no improvement.
                              ; Motion System
                              ; Kinematics
                                @maxgyver if the axes have identical steps/mm and microstepping, then the step pulses should be precisely synchronised. So I think it must be a mechanical problem.
                                Is there any vibration when you move each of the 3 motors individually? You can use G91 followed by G1 H2 commands to test that.
                                martin7404undefined MaxGyverundefined 2 Replies Last reply Reply Quote 0
                                  martin7404 @dc42
                                  @dc42 In double makfoged he can move individually X and U but for Y he moves all the motors
                                    dc42 administrators @martin7404
                                    Yes but you can still command the motors to move individually, and see whether the resulting movement is smooth or not.
                                    • MaxGyverundefined
                                      MaxGyver @dc42
                                      @dc42 Individual motor moves are no problem, the jitter only courses when they have to work in conjunction.
                                      • MaxGyverundefined
                                        MaxGyver @dc42
                                        If the axes have identical steps/mm and microstepping, then the step pulses should be precisely synchronised. So I think it must be a mechanical problem.
                                        When printing with the U-Axis extruder, the jitter is present in the X-Axis extruder and vice versa. The active extruder is moving just fine and the print turns out okay. So I do not see how this can be a mechanical issue.
                                        If it is not a firmware issue, then maybe a CAN related problem?
                                          martin7404
                                          @maxgyver Can you show your belt arrangement scheme
                                          • fcwiltundefined
                                            fcwilt @MaxGyver
                                            You could possibly rule out CAN bus problems by running all drivers off the 6HC and disconnecting the expansion boards (and make the needed adjustments to the config file).
