    0% measured minimum
    Filament Monitor
    924
    • fractalengineerundefined
      fractalengineer @osterac
      @osterac hmm that's still way off; ideally you would get as near to 100% on both min/max
      You did print the revision 2 right? With the schmitt-trigger sensor?
      If so you might want to check if the axle is spinning properly when you're feeding filament through the sensor;
      Just take a piece by hand, feed it through the sensor and watch for the axles spinning/sensor blipping.
      On V2 you can also pinch the axle while it spins to feel how well does it grips
      Railcore II ZL
      osteracundefined 1 Reply Last reply Reply Quote 1
      • osteracundefined
        osterac @fractalengineer
        @fractalengineer
        On Thingiverse it says version 1.2 and various parts have various revision numbers - the parts for the body do not have revision numbers. I found it hard to tell which file to print because there are stl files with no revision numbers and 3mf files that do have revision numbers. I just printed the stl files. I do have the schmitt-trigger that is linked to on thingiverse.
        I checked out the grip of the wheel and there is one spot on the wheel that doesn't grip quite as well as the rest. Could be that it is slipping during retraction.
        Here's my sensor:
        edit I cracked it open and there seems to be a very slight indentation on the rubber wheel. I'll try printing a new one.
        fractalengineerundefined 1 Reply Last reply Reply Quote 0
          @osterac Ok I just updated the whole files on the thing; there's only one version now for clarity
          And yep you really need your seams to be well tuned on that wheel; if they're protruding a bit you can still trim them with flush cutters or a razor blade
          Railcore II ZL
          • osteracundefined
            @fractalengineer
            Finally got my printer to make a decent wheel. Here's the result of calibration now:
            m591 d0
            Pulse-type filament monitor on pin e0stop, disabled, sensitivity 25.992mm/pulse, allowed movement 55% to 95%, check every 51.0mm, measured sensitivity 24.010mm/pulse, measured minimum 87%, maximum 177% over 33326.1mm
            Look okay? Is 177% too high?
              dc42 administrators @osterac
              @osterac you have a very high mm per pulse value (24mm). So you can only measure filament lengths to the nearest multiple of 24mm. This means that in order to get accurate measurements, the length of filament sampled must be many times 24mm. You are using only 51mm, so you can expect to get large variations. If you increase the sampling length to 100mm or more, the variation will reduce.
              The instructions on the page you linked to say that the mm per pulse should be 1.2mm, so I don't think you can have built it correctly.
              osteracundefined 1 Reply Last reply Reply Quote 0
              • osteracundefined
                osterac @dc42
                Thanks for explaining that, always helps to know how things work.
                I could try re-printing the sensor wheel... Or
                maybe my sensor is defective? There are some models of the sensor wheel with fewer teeth but that seems like it would decrease accuracy?
                Could it still be a problem with slippage?
                Sorry for all the questions... Hope I'm not bothering you...
                  It's no bother at all. We're here to try and help people figure it all out.
                  Can you make a video of your extruder in use?
                  • osteracundefined
                    osterac @Phaedrux
                    @phaedrux
                    Here's a YouTube link
                    https://youtu.be/xuf4eaktg_w
                      @osterac thanks. It appear s to me that the flashing of the red light in the filament monitor is in frequent (so the 24mm per pulse value is believable) but is also somewhat erratic. Perhaps there isn't a clear path between the opto switch transmitter and receiver through the slots in the wheel?
                      • osteracundefined
                        osterac @dc42
                        @dc42 figured it out I think. The mounting screws for the sensor were too long so they weren't properly seating the sensor. Now that the sensor is in nice and tight the blinking is consistent. Haven't calibrated yet though.
                        • osteracundefined osterac has marked this topic as solved
                        • osteracundefined
                          osterac
                          Yeah, looks good. Here's the calibration:
                          Pulse-type filament monitor on pin e0stop, disabled, sensitivity 4.141mm/pulse, allowed movement 95% to 103%, check every 51.0mm, measured sensitivity 4.186mm/pulse, measured minimum 97%, maximum 101% over 1837.5mm
                          I used the 12x sensor wheel rather than the default 24x wheel (fewer teeth), not sure if that helps or not.
                          Anyway, thanks for your help guys. I appreciate it.
