    No voltage on Extruder Hot end?
    Using Duet Controllers
    584
      droftarts administrators @Akds48
      @akds48 And what is the error message when you turn the hot end on?
        @akds48 Unfortunately, your config.g is not very helpful, it just calls other macros. Please post the following:
        /sys/settings/common_settings.g
        /sys/settings/machines/ws200.g
        /sys/settings/extruders/vol_vol.g
        /sys/config-override.g
        Also, send M115 and post reply. This shows the firmware version you are using.
        • Akds48undefined
          Akds48
          @droftarts
          @droftarts
          Error was: Heater error: temperature rising much more slowly than the expected 1.7°C/sec.
          it was showing when i run the heater to heat up.
          When i send M115 it shows the firmware version 3.1 something
          and to upload the files it is showing the parse error
          ws200.g
          vol_vol.g
          common_settings.g
          config-override.g
            @akds48 All those files are empty. Are they empty on the SD card? You can cut and paste the contents into you post. If you use the 'code' formatting </>, they will be easier to read.
            Most likely, the configuration files are meant for RRF version 2.05 (it says this in the config.g file), and have not been updated to RRF v3, so the heater is not defined correctly. There have been major changes between RRF2 and RRF3.
            If you want this to work without updating the configuration, flash version 2.05.1 of the firmware to the Duet: https://github.com/Duet3D/RepRapFirmware/releases/tag/2.05.1
            • Akds48undefined
              Akds48
              @droftarts
              Please check these again.
              common_settings.g
              config-override.g
              ws200.g
              vol_vol.g
                @akds48 Sorry, those don't work. Please just cut and paste the contents of those 4 files into a forum post.
                Akds48undefined 1 Reply Last reply Reply Quote 0
                • Akds48undefined
                  Akds48 @droftarts
                  @droftarts
                  vol_vol.g
                  common_settings.g
                  ws200.g
                  config-override.g
                  Please check now
                    @akds48 Okay, it looks like the configuration is correct for RRF v3. Tools appear to be configured correctly. Can you post an image of what you see in DWC?
                    • Akds48undefined
                      Akds48 @droftarts
                      @droftarts
                      i am not using DWC, right now i am controlling the machine with proterface and Simplify3D.
                      and iam getting a open circuit error on terminal while i have connected all the things properly.IMG_20220520_170300300.jpg
                        @akds48 Troubleshooting will be a lot easier if you use DWC; you can see much more information. You can follow the guide here to get connected: https://docs.duet3d.com/en/How_to_guides/Getting_connected/Getting_connected_to_your_Duet
                        Can you measure the resistance of the thermistors at room temperature, at the connector that plugs into the Duet? Are you sure you have two Volacano extruders?
                        I assume you downloaded the configuration from 3D Platform? https://support.3dplatform.com/portal/en/kb/3d-platform/200-300-series
                        • Akds48undefined
                          Akds48 @droftarts
                          @droftarts
                          No right now i am using single extruder, actually when i run the command for heating the extruder, it shows the target temp for 2 seconds only then it shows -273 as above.
                          and when i checked the resistance at the point of thermistor it shows 0 value there.
                          and yes i downloaded the firmware from 3DP support.
                            @akds48 Sounds like the thermistor has failed, or the wiring is broken or disconnected. At room temperature (25C), the resistance should be 100,000 ohms, at least according to the config you are using:
                            ; LEFT EXTRUDER
                            M308 S1 P"e0_temp" Y"thermistor" A"Volcano" T100000 B4725 C7.06e-8 ; set thermistor values for Volcano
                            M950 H1 T1 C"e0_heat"                           ; set heater 2 to use temp 2
                            M307 H1 A547.2 C279.0 D4.4 S1.00 V23.1 B0       ; set heater control values for Volcano left
                            M143 H1 S300                                    ; set max temp: 300C
                            M563 P0 D0 H1 S"Left extruder" F0:1             ; Define tool 1
                            G10 P0 R0 S0                                    ; Set initial tool 1 active and standby temperatures to 0C
                            G10 P0 X0 Y0 Z0                                 ; Set initial tool offsets to 0 (will be over-ridden)
                            ; RIGHT EXTRUDER
                            M308 S2 P"e1_temp" Y"thermistor" A"Volcano" T100000 B4725 C7.06e-8 ; set thermistor values for Volcano
                            M950 H2 T2 C"e1_heat"                           ; set heater 2 to use temp 2
                            M307 H2 A547.2 C279.0 D4.4 S1.00 V23.1 B0       ; set heater control values for Volcano right
                            M143 H2 S300                                    ; set max temp: 300C
                            M563 P1 D1 H2 S"Right extruder" F0:1            ; Define tool 1
                            G10 P1 R0 S0                                    ; Set initial tool 1 active and standby temperatures to 0C
                            G10 P1 X0 Y0 Z0                                 ; Set initial tool offsets to 0 (will be over-ridden)
                            • Akds48undefined
                              Akds48 @droftarts
                              @droftarts
                              okay i will change the thermistor if it can be a problem.
                                @akds48 does anything work at the extruder/hot end? Fans, or extruder motor (if you allow cold extrusion)? Maybe a wiring fault at that end?
                                • Akds48undefined
                                  Akds48 @droftarts
                                  @droftarts
                                  only fan is working neither the motor nor the heater or thermistor.
                                    jay_s_uk
                                    @akds48 i'm not sure e0_temp is valid as a name. try e0temp. same for the other ones with a _
                                    Akds48undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                    • Akds48undefined
                                      Akds48 @jay_s_uk
                                      @jay_s_uk
                                      It is a default firmware which i am using from 3D platform to operate the machine.
                                        droftarts administrators @jay_s_uk
                                        @jay_s_uk said in No voltage on Extruder Hot end?:
                                        It's fine:
                                        A pin name is a string of characters enclosed in double quotation marks. It is not case sensitive. All instances of _ and - characters are stripped from pin names before comparing them.
                                        https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3#pin-names
                                        • Akds48undefined
                                          Akds48
                                          @droftarts
                                          i have changed the thermistor but it is same again.
                                          could it be a VSSA fuse problem? as i have lower version of duet board and it has no fuse !
                                          i have the first one board which has not fuse for thermistor, bed or fan.
                                            @akds48 The large fuses are not the VSSA fuse, they are for heated bed, and fans/stepper motors/hot end heaters. From on of your earlier pictures, you have a v1.02 board, which means the VSSA fuse is resettable, so it shouldn't be causing a problem. (See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pcb-revision-history)
                                            VSSA fuse problems were confined to v1.0 and v1.01 board, see https://docs.duet3d.com/en/User_manual/Troubleshooting/Parts#vssa-fuse
                                            I think you need to test the thermistor inputs. The easiest way to do this it to get a known-value resistor, and connect it directly to the thermistor pins, and see if the correct temperature is reported. I use these for testing:
