    When slecting Hotend heater 1 in dashboard error
    Duet Web Control
    483
    • shaunpplundefined
      shaunppl @jay_s_uk
      @jay_s_uk Just found them.
      ; tpost0.g
      ; called after tool 0 has been selected
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon May 23 2022 12:52:37 GMT+0100 (British Summer Time)
      ; Wait for set temperatures to be reached
      M116 P0
      ; tpre0.g
      ; called before tool 0 is selected
        jay_s_uk @shaunppl
        @shaunppl what version of RRF are you running? It'll tell you in M115
        What version of DWC are you running? It'll tell you under settings general
        shaunpplundefined 1 Reply Last reply Reply Quote 0
        • shaunpplundefined
          shaunppl @jay_s_uk
          @jay_s_uk Duet web control 3.4.0, FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.2.2 ELECTRONICS: Duet 3 Mini5plus Ethernet FIRMWARE_DATE: 2021-02-11
            jay_s_uk @shaunppl
            @shaunppl theres your issue. you need to update your firmware to 3.4.0
            shaunpplundefined 2 Replies Last reply Reply Quote 0
            • shaunpplundefined
              shaunppl @jay_s_uk
              @jay_s_uk Yep you are very right, have just uploaded the later firmware 3.4.0 and it worked, many thanks for your help.
              • shaunpplundefined
                shaunppl @jay_s_uk
                @jay_s_uk Had to upgrade to the Mini 5+ as my maestro board keeps wiping the sd cards ? and making them unreadable.
                So took all my settings with it, so scraching head to sort 3 axis homing and other issues etc, talk about having a bad day. lol
                  jay_s_uk @shaunppl
                  @shaunppl sounds like an issue with the sd card socket on the maestro then
                  • shaunpplundefined
                    shaunppl @jay_s_uk
                    @jay_s_uk Yeah i think so, but now worried as my other prototype are all on the maestro boards and 2 failures means i will have to probably move them all to duet 3 boards.
                    • shaunpplundefined
                      shaunppl @jay_s_uk
                      @jay_s_uk How are you getting on with your predator, I revamped mine with a rail conversion along with a meastro board and smart efficator made a hell of a difference.
                        jay_s_uk @shaunppl
                        @shaunppl good thanks. so far changed the belts, motors, motor pulleys, added rails, changed the motherboard, made my own magball rods, fitted a smart effector with direct extruder (LGX Lite) and fitted a dragon HF.
                        • shaunpplundefined
                          shaunppl @jay_s_uk
                          @jay_s_uk Yeah i am trialing the revo hotend with the upgraded smart efficator board (a lot more accurate and less prone to the vibration issues when bed levelling) and using a fixed mounted hemera extruder not the flying spring mounts, seems to be more stable and prints faster.
