    Second print height issues
    IR Height Sensor
    • X4TECundefined
      X4TEC
      Hi anyone experience the following?
      I have a P3Steel with Duet Wifi and IR sensor.
      After a successful first print, I find that my second print always starts +.6mm above the correct Z point (ie if layer is .2 the print starts at .8, and reads as such on console). If I reset the electronics it prints correctly. The g-code job is exactly the same job, the printer homes the Z correctly, and I've done the paper under the nozzle check, but I can not work out where the extra .6mm is coming from.
      • Nylkosundefined
        Nylkos
        Do you have G92 Z0 anywhere other then homez.g or homeall.g?
        • Sabagmnundefined
          Sabagmn
          I would also double-check if you have a config-override.g file with G31 gcodes in it. Those will override your G31 settings in config.g
          Had that happen to me before and ended up having to comment them out.
          • X4TECundefined
            X4TEC
            @Nylkos:
            Hi Nylkos, I don't have G92 in any of the home files,
            • X4TECundefined
              X4TEC
              @Sabagmn:
              Hi Sabagmn. not got any G31 in my config-override file.
                deckingman
                Can you post the first 50 or so lines of the gcode file you are trying to print.
