Declaring variables in config.g
@fcwilt That's really helpful, than you Frederick.
This is how I've declared the variable in config.g:
... global savedSpindleSpeed = 0 ...
and this is how (it's been suggested) I should access it...
... if state.currentTool >= 0 & tools[state.currentTool].spindle >= 0 set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ...
I'm assuming "state.currentTool" is built-in, but there are no squiggly brackets anywhere!
Is that what I'm missing, do you think, as this is on a CNC?
EDIT: I've just noticed "[state.currentTool].spindle >=0," yet the second part shows "tools[state.currentTool].spindleRpm". Should they both be ".spindleRpm"?
@nightowl999
Your expressions in your condition should be enclosed in brackets.
As you are using CNC mode, you would need to use curly brackets.if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
Also you are correct, it should be spindleRpm in both instances.
You can check the correct syntax and work out which object model values to use by making use of the object model browser plugin in DWC.This will let you see the object model and drill down to get the info you need.
If you select a value, the correct path can be copied to the clipboard using the copy button at top right. -
@owend So the original line should be changed to this:
if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0} set {global.savedSpindleSpeed} = {tools[state.currentTool].SpindleRpm} ...
... or should the lower line be enclosed within a single pair of curly parentheses?
As an aside, is "SpindleRPM" the same as "spindlerpm" and SPINDLERPM?
Thanks
@nightowl999
No, you only need the curly brackets when doing a comparison using OR or AND
This groups and separates the parts of the equations
You don't need them when setting the value of the variable.if {global.A = global.B} & {global.B<global.C} set global.D = global.B
if {global.A = global.B} || {global.B<global.C} set global.D = global.B
You also need them when you must calculate something as part of a standard command such as using a variable in a speed setting
G1 X100 Y100 F{global.D}
@nightowl999 said in Declaring variables in config.g:
No they are not the same.
The object model values and variable names are case sensitive. -
@owend Well, I'm definitely missing something, because the resume.g file doesn't restart the spindle, when I expect it should.
This is the declared variable in config.g:
This is my pause.g file:
G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} ; move the Z axis to a safe height if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0} set global.savedSpindleSpeed = tools[state.currentTool].spindleRpm ; save current spindle speed G1 X273.5 Y560 F2400 ; move XY to a safe place M5 ; turn the spindle off echo "Spindle speed saved at", global.savedSpindleSpeed, "RPM" ; spindle speed saved
...and this my resume.g:
if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0} M3 S{global.savedSpindleSpeed} ; resume saved spindle speed G4 S1 ; wait 1 second to allow the spindle to spin up echo "Spindle speed resumed at ", global.savedSpindleSpeed, "RPM" G1 R1 X0 Y0 F2400 ; go above the paused XY position
This should be easy with all the help I've had, but what have I missed..?
Can you try this to ensure that the condition is being met.
if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0} M3 S{global.savedSpindleSpeed} ; resume saved spindle speed G4 S1 ; wait 1 second to allow the spindle to spin up echo "Spindle speed resumed at ", global.savedSpindleSpeed, "RPM" G1 R1 X0 Y0 F2400 else echo "condition not met. Spindle speed remains at " ^ tools[state.currentTool].spindleRpm ^ "RPM"
I can, @owend, but running pause.g indicates the spindle speed of 0RPM is saved, not the 18,000RPM it's running at, so it seems to be an issue with pause.g?
@OwenD here we are, the text from the Console:
27/05/2022, 19:43:24 M0 Printing paused at X128.8 Y168.9 Z64.0 Cancelled printing file 0:/gcodes/Calibration Toolpath.gcode, print time was 0h 0m 27/05/2022, 19:43:12 Spindle speed saved at 0 RPM 27/05/2022, 19:43:10 M25 Resume state saved 27/05/2022, 19:43:08 Printing resumed 27/05/2022, 19:42:56 M24 Error: in file macro line 14 column 63: meta command: array index out of bounds 27/05/2022, 19:42:52 Printing paused at X125.6 Y125.8 Z65.0 27/05/2022, 19:42:40 Spindle speed saved at 0 RPM 27/05/2022, 19:42:37 M25 Resume state saved 27/05/2022, 19:42:29 M32 "0:/gcodes/Calibration Toolpath.gcode" File 0:/gcodes/Calibration Toolpath.gcode selected for printing 27/05/2022, 19:42:16 File 0:/gcodes/Calibration Toolpath.gcode will print in 0h 3m plus heating time 27/05/2022, 19:42:15 M37 P"0:/gcodes/Calibration Toolpath.gcode" Simulating print of file 0:/gcodes/Calibration Toolpath.gcode 27/05/2022, 19:42:04 G10 L20 P1 Origin of workplace 1: X97.00 Y94.00 Z67.00 27/05/2022, 19:41:37 g1 x147 27/05/2022, 19:41:20 g1 y84 27/05/2022, 19:41:06 g1 y660 27/05/2022, 19:40:34 Connected to weeble
This will be the problem.
See the other thread. -
This is Line 14 from resume.g...
with the same error when I changed it to:
echo "condition not met. Spindle speed remains at ", tools[state.currentTool].spindleRpm, "RPM"
@nightowl999
I suspect you have no tool defined when the resume starts.
