    Echo commands...
    1.5k
    • fcwiltundefined
      fcwilt @Nightowl
      @nightowl999 said in Echo commands...:
      Is there a guide or tutorial somewhere, where I can start to learn this stuff for myself, please? I appreciate there is guidance with some examples of gcode and meta commands on the Duet pages, but I'm hoping to learn more.
      I use quite a few code files beyond the common ones. Here is a set from one of my printers:
      Feel free to ask any questions you may have about the "programming" features of the Duet firmware - version 3.4.x plus BtnCmd 0.10.09 can do some rather amazing things compared to the Duet firmware 2.x I started with a few years back.
      Nightowlundefined 1 Reply Last reply Reply Quote 0
      • mikeabuilderundefined
        mikeabuilder
        @fcwilt - I did start with a boolean variable, but the first time I used it I had to look to remember if "OK" was true of false. The second time I looked it up, I switched it to "OK" and "CANCEL" so I would not need to look it up again.
        @Nightowl999 - The programming capability these folks are building into RRF (and I believe it if these few folks) is a relatively new capability and is very simplified. You will not find anything as fancy as what you learned in VB. It was primarily developed to support the "gcode everywhere" philosophy. Additional features may be added, but I would not expect a full-blown programming language.
        Having said that, the meta command page in the wiki (https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands) really does describe all the capabilities. Beyond that, it's clever folks building macros. But here's my nuggets of RRF gcode programming wisdom.
        • You use G codes and M codes in your macros to "send" things to the machine.
        • You use the object model (https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation) to read things from the machine that you might use a G or M code in the console to see in the user interface. You can "never" set a value to a variable by setting it equal to am M or G code.
        • Understanding what is and is not a "code block" is important because a variable created inside a code block is only available to itself and it sub-blocks (child blocks) not it's parent. Return to this when you get an error saying a variable does not exist when you know darn well you created it.
        • It seems easiest to just make everything a global variable, but these take up memory space and are never deleted, except a power on or reset. So you can clog up the memory with too many. Best to use local variable wherever you can. Those are destroyed and the memory freed up for other uses as soon as the code block where they were created is finished being run.
        • Carefully read and practice the echo, particular the echo >filename and echo >>filename. These are your ticket to having your macro write something to a file that you can read later.
        • So far, there is not command for reading a file, making arrays, parsing strings, or collecting generalized user input. In my opinion, these things are slippery slopes to a mountain of work for the developers and they have been wise in approaching them with extreme caution.
        infiniteloopundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
        • infiniteloopundefined
          infiniteloop @mikeabuilder
          @mikeabuilder
          So far, there is no command for reading a file
          In a sense, there is: you can execute the file as a macro. This includes the ability to establish or modify global variables, to execute GCodes with parameters having been calculated at file creation time, to inspect the object model, and to run conditional code.
          At least, this gives us the ability to store data, instructions and conditions - and to handle them when we "read" the file (calling it as a macro). This is different from the common idea of keeping data and code distant, but apart from string handling and a user interface in excess of M117 and M291, we have all the tools to control our machine by means of writing and reading states and conditions. Think different 😊
          • fcwiltundefined
            fcwilt @mikeabuilder
            @mikeabuilder said in Echo commands...:
            Good to know.
            But for the record OK is always True and CANCEL is always False. 😉
            I notice you check for the missing message parameter. Any reason you did not simply abort if missing?
            • Nightowlundefined
              Nightowl @fcwilt
              @fcwilt
              I'm thinking I might configure a 'working' page specifically for CNC users with @MintyTrebor's BtnCmd add-in, but I need to get my head around what I need to see before I do that.
              Unlike you 3D printer guys, I really don't have an interest in temperatures, hot ends, fans, beds, heaters, etc., just a few progress indicators, pause, resume, stop and PANIC!! buttons, is all 🙂
              Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
              I'm still on my learning curve, so take everything I say with caution!
              RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
              • Nightowlundefined
                Nightowl
                One thought. In VBA you can hover the mouse icon over a declared variable and it will show it's value in a ToolTip. I'm not asking for that here (I don't think this system is complex enough to warrant that) but is there a way of finding the value of a variable in the code sender, or is it only in the Object Model (if at all)?
                  mikeabuilder
                  @infiniteloop - regarding writing a file that contains gcode that will put values into variables when it is executed. That's brilliant! Love it. The user (me) will need to be careful about managing global and local variables so as to not use up all the memory. I'm already envisioning an array.g for simple arrays.
                  @fcwilt - true (or should I say "OK") about OK always being true, but that's another thing to remember and my brain is nearly filled to capacity. I pop up a user message if there is no message parameter supplied just to help me during debug - but it is redundant with returning "NO MESSAGE" in the global variable.
                    Well, in some cases macros can replace a global variable completely. That's not true for state and conditional checks during runtime, but why not put some parameter for a Gcode into a macro - together with the Gcode? As additional benefit, these "data" survive loss of power (and earthquakes as well).
                    • fcwiltundefined
                      I check for parameters as well and I do two things:
                      • use M291 to display the message dialog explaining the problem
                      • use abort to end execution and display the same message.
                      Even if aaa.g invokes bbb.g which invokes ccc.g, if ccc.g executes an abort that ends it right there and execution does not continue in bbb.g or aaa.g.
                      So "bad" things won't happen if I mess up passing a parameter.
                        mikeabuilder
                        @fcwilt - thanks for pointing out the abort command. I was unaware. It's a great capability. I'll need to think if I always want to abort the whole shebang if a message is missing or I might add it as an optional parameter so the user can choose to abort or proceed if there is no message supplied.
                        I feel I'm standing on the edge of the slippery slope. A whole programming language could be built here...
