    Power failure and resurrection on a CNC machine
    CNC
    7.3k
    • Nightowlundefined
      Nightowl @infiniteloop
      @infiniteloop
      I found the printed version...
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
      • infiniteloopundefined
        infiniteloop @Nightowl
        @nightowl999
        to see if I can find a way of saving the value of a variable in the resurrect.g file
        That’s difficult. If you have M911 configured near the end of your config.g, it will automatically generate resurrect.g and write it on the SD card. In a second step, M911 will execute the commands you told it with the P parameter. There, you might be able to invoke your own macro generator - although, I’m not quite sure about how to put a macro call into the P string … 🤔
        Depending on whether resurrect.g has already been closed at this stage, you might be able to append own gCode commands - at the end of the file, which is the wrong place for what I think you want to achieve.
        Another possibility is to save your own file, which can then be called from resurrect-prologue.g. To get an idea where in the recovery process resurrect-prologue.g is called, please have a look at this document.
        The third option is to ignore resurrect.g completely and to generate your own recovery file instead.
        Aside from the document linked above, you should thoroughly study the resurrect.g file you now have on your SD card. Best is to draw a copy onto your PC and to comment each single gCode you find. Also take care of the parameters and their meaning. Use the GCode Dictionary to spell the lines, until you can imagine what resurrect.g does and why so.
        Then, you are finally able to decide whether you can get along with some supplemental file which is called from within resurrect-prologue.g, or if you have to bite the apple and write your own recovery mechanism.
        In the meantime, I’ll prepare some code samples for you. Sorry, but this may take until tomorrow, as I have an Arduino on my desk which needs a severe debugging treatment 🤓
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          @infiniteloop
          Thanks for that, and I'm pretty sure I can wait until tomorrow! 🤣 🤣
          Yeah, I didn't realise the resurrect.g file was overwritten every time, but I should have!
          Now my thinking is when the power fails the relevant information should be saved into
          state.restorePoint[0].spindleSpeed and state.restorePoints[0].toolNumber, which I thought it would make sense for it to do that anyway, but it seems not.
          Maybe I could write something into the M911 string to save that info into the restore points and 'recover' it from the resurrect-prologue.g file?
          infiniteloopundefined 2 Replies Last reply Reply Quote 0
            @nightowl999
            Sorry, but the object model is read-only. This said, I think I know what you mean: these are the properties you want to restore on top of resurrect.g.
            You must write a macro to generate a file with these data points. That file, in turn, is a macro itself, containing the data as arguments of GCode instructions who put these data into place.
            Whether you can call this file from resurrect-prologue.g or not depends on the required order of commands: for instance, you should not turn the spindle on before the proper tool has been selected. That’s why you should study your resurrect.g in detail.
              @nightowl999 This time, the debugging session took not as long as I expected, so here’s some fish for the cat: 😸
              ; --- just a sample resurrect.g file: don't ever execute! ---
              √M141 P0 S50.0										; activate chamber heater
              √G29 S1												; load the height map from file and activate bed compensation
              √T-1 P0												; de-select tools, don't run macros
              √G92 X-101.068 Y6.281 Z9.100							; set position of head without moving it
              √G60 S1												; store current position in slot #1
              M98 P"resurrect-prologue.g"
              √M116												; wait for all temperatures to reach their set values
              √M290 X0.000 Y0.000 Z0.100 R0						; restore babystepping offsets
              √G10 L2 P1 X0.00 Y0.00 Z0.00							; L=2: this sets the origin of the coordinate system number
              G10 L2 P2 X0.00 Y0.00 Z0.00							;	 specified by the P parameter (1 to 9) to the specified X, Y, X... values
              G10 L2 P3 X0.00 Y0.00 Z0.00
              G10 L2 P4 X0.00 Y0.00 Z0.00
              G10 L2 P5 X0.00 Y0.00 Z0.00
              G10 L2 P6 X0.00 Y0.00 Z0.00
              G10 L2 P7 X0.00 Y0.00 Z0.00
              G10 L2 P8 X0.00 Y0.00 Z0.00
              G10 L2 P9 X0.00 Y0.00 Z0.00
              G54													; select coordinate system #1
              √G10 P1 S0 R0										; set active(S) and standby(R) temperatures for tool #1
              √T1 P0												; select tool #1, don't run macros
              √G10 P0 S230 R225									; set active(S) and standby(R) temperatures for tool #0
              √T0 P6												; select tool #0, run macros (0b0110) - tfree=1, tpre=2 and tpost=4
              M106 S0.70											; set fan speed (fan defaults to #0)
              √M106 P0 S0.70										; 	now, with dedication to every possible fan
              √M106 P1 S0.00
              M106 P2 S0.00
              M106 P5 S0.00
              M106 P7 S0.00
              M106 P8 S0.00
              √G92 E0.00000										; set position of extruder without moving it
              √M83													; extruder to relative
              √M23 "0:/gcodes/Grundplatte II.gcode"				; select file for printing
              √M26 S8015948 P0.000									; set pointer into file (P=proportion of the first move to be skipped, default 0.0, must be less than 1.0)
              √G0 F6000 Z11.200									; place Z 2 mm above the printing position
              √G0 F6000 X-91.068 Y6.281							; drive X and Y to the printing position
              √G0 F6000 Z9.200										; lower Z for 2 mm into its printing position
              √G1 F3000.0 P0										; use speed F, set port bits to 0 (remainder from RRF 2?)
              G21													; set units to mm
              √M24													; resume print (after a pause)
              That’s an older resurrect.g file that I used as a first template for my own recovery macro. I’ve added comments to understand what’s going on, every GCode I then implemented in my counterpart has a checkmark.
              Depending on the editor and font used, the comments are badly misaligned. For better readability, you might want to paste the content of the black box into your editor of choice and ameliorate the text at will. 😜
              Recently generated "resurrects" look a bit different, so I suggest you to publish your latest resurrect.g - I'd like to have a look at that.
              Nightowlundefined 1 Reply Last reply Reply Quote 0
              • Nightowlundefined
                @infiniteloop
                Here is the latest resurrect.g file:
                ; File "0:/gcodes/Calibration Toolpath.gcode" resume print after power failure at 2022-05-29 16:49
                G21
                G92 X182.895 Y658.930 Z66.000
                G60 S1
                T-1 P0
                M116
                M290 X0.000 Y0.000 Z0.000 R0
                ; Workplace coordinates
                G10 L2 P1 X147.00 Y584.00 Z67.00
                G54
                M106 S0.50
                M106 P0 S0.50
                M116
                G92 E0.00000
                M83
                M486 S-1
                G17
                M23 "0:/gcodes/Calibration Toolpath.gcode"
                M26 S249
                G0 F6000 Z68.000
                G0 F6000 X182.895 Y658.930
                G0 F6000 Z66.000
                G1 F2500.0 P0
                G21
                M24
                I was under the impression this file was overwritten with a new one every time there was a 'power failure', and it wasn't user-editable?
                  @nightowl999 said in Power failure and resurrection on a CNC machine:
                  Your first impression is correct. Whether resurrect.g is write-protected or not? Can't tell you as I currently have no such file at hand …
                  Nevertheless, here's the first lesson - by the way, it demonstrates how M911 generates resurrect.g, up to the fact that the generated file will always be overwritten when we call M98 P"MWriter.g" again 😊
                  ; MWriter aka macro writer
                  ; Creates the macro "HelloWorld.g" on the SD card which in turn can be executed
                  ; Requirements: RRF v3.4
                  ; To keep things simple, we use the /sys directory - which makes sense as any recovery macros should live in there.
                  ; For development and tests, I use DWC, mainly with the "System" tab
                  var fName = "HelloWorld.g"			; this is the filename for the macro to create
                  ; Here, we create the file - note the use of a single ">" with echo: this overwrites any existing file with this name.
                  echo >{var.fName} "; HelloWorld.g"
                  ; with ">>", echo appends something to the now existing file:
                  echo >>{var.fName} "; Macro file created by macro ""MWriter.g"""	; we always write strings - note how to put a string into it (""MWriter.g"")
                  echo >>{var.fName} ""												; empty line for better readability
                  echo >>{var.fName} "M291 S2 R""Hello World"" P""Moin Moin"""		; message box, blocking (S2), with title (R) and message (P), localized :-)
                  echo >>{var.fName} ";EOF"											; ... old habit of mine
                  ;EOF																; same habit ...
                  Oh, and thanks for your resurrect.g - I'll try to study it. Did you make a copy and added comments?
                  • Nightowlundefined
                    @infiniteloop
                    Yes, here it is, but I'm not sure if I've done it correctly...
                    G21					; sets units to mm
                    G92 X182.895 Y658.930 Z66.000		; sets the position for X, Y and Z
                    G60 S1					; save memory slot number
                    T-1 P0					; deselects the tool
                    M98 P"resurrect-prologue.g"		; runs the user-defined resurrect-prologue.g
                    M116					; wait for all temperatures to reach set value
                    M290 X0.000 Y0.000 Z0.000 R0		; sets babystepping (not CNC)
                    G10 L2 P1 X147.00 Y584.00 Z67.00	; origin of coordinate system number
                    G10 L2 P2 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P3 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P4 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P5 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P6 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P7 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P8 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G10 L2 P9 X0.00 Y0.00 Z0.00		; as above for 3D printers
                    G54					; select coordinate system 1
                    M106 S0.50				; turns the fan on at half speed
                    M106 P0 S0.50				; turns user-configured fan on
                    G92 E0.00000				; sets the position for the extruder
                    M83					; sets extruder to relative mode
                    M486 S-1				; Indicate a non-object, purge tower, or other global feature
                    G17					; select XY plane for arc moves
                    M23 "0:/gcodes/Calibration Toolpath.gcode"	; selects the file previously running
                    M26 S249				; set file offset from the start of the interrupted file
                    G0 F6000 Z68.000			; rapid move to above saved Z height
                    G0 F6000 X182.895 Y658.930		; rapid move to saved XY axes
                    G0 F6000 Z66.000			; reaped move to saved Z height
                    G1 F2500.0 P0				; controlled linear move  relating to output pins
                    M24					; start/resume SD print
                      Thx, and well done! From a first glance, I get the impression that this resurrect.g is missing all the things which are specific to CNC routers.
                      Could you please try to edit this commented version and insert comment lines with the CNC specific commands you miss? Think carefully, the sequence of commands is essential, else you can wreck your machine in the worst case.
                      With this "script" ready, we can see if the required additions can be called from resurrect-prologue.g or if we have to write the whole M911 stuff ourselves.
                      Nightowlundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • Nightowlundefined
                        @infiniteloop Whew, let's see how this goes...
                        G60 S1					; I think a user-defined save slot can be 0, 3, 4 or 5 (0 is default)
                        ? T-1 P0				; I'm not sure why the tool is deselected
                        Assuming this data has been saved in the state.restorePoints nodes...
                        T0					; select the last tool used - this should be stored in the relevant state.restorePoints[*].toolNumber
                        Set savedSpindleSpeed			; select the last tool's spindle speed - this should be stored in the relevant state.restorePoints[0].spindleSpeeds
                        ; M116					; not relevant for CNC
                        ; M290 X0.000 Y0.000 Z0.000 R0		; not relevant for CNC
                        G10 L2 P1 X147.00 Y584.00 Z67.00	; I think this is necessary
                        ; G10 L2 P2 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P3 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P4 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P5 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P6 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P7 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P8 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ; G10 L2 P9 X0.00 Y0.00 Z0.00		; not relevant for CNC
                        ? G54					; select coordinate system 1
                        ; M106 S0.50				; not relevant for my CNC
                        M106 P0 S0.50				; turns user-configured fan on (I've got a case fan configured)
                        ; G92 E0.00000				; not relevant for CNC
                        ; M83					; not relevant for CNC
                        ? M486 S-1				; not relevant for CNC
                        ? G17					; not sure if this is relevant for CNC - it's not in the config.g file
                        ? G1 F2500.0 P0				; controlled linear move relating to output pins
                        Before the power failure happens, I know where the spindle information is held, as I use that in my pause.g (which includes a test M28/M29 script) and resume.g files. These may help, so I've added them below...
                        ; pause.g
                        M28 savedCNC.g
                        echo "Duet and RepRap are fantastic"
                        M29
                        set global.savedSpindleSpeed = spindles[0].active ; sets the global variable
                        echo "Spindle speed saved at " ^ {global.savedSpindleSpeed} ^ "RPM" ; shows saved spindle speed in the Console
                        G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} F2400 ; move the Z axis to a safe height
                        G0 X273.5 Y560 ; move XY to a safe place
                        M5 ; turn the spindle off
                        ; resume.g
                        if state.currentTool =-1
                        	echo "No tool active.  Selecting tool zero"
                        	T0 ; select tool zero
                        if state.currentTool >= 0
                        	echo "Spindle state on tool ", state.currentTool, " is ", spindles[state.currentTool].state
                        if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                        	M3 S{global.savedSpindleSpeed} ; resume saved spindle speed
                        	G4 S1 ; wait 1 second to allow the spindle to spin up
                        	echo "Spindle speed resumed at " ^ {global.savedSpindleSpeed} ^ "RPM" ; this should show the setting was successful
                        G0 R1 X0 Y0 ; move X and Y back to saved work XY location
                        G1 R1 Z0 F240 ; move Z slowly down to saved work Z location
                        infiniteloopundefined 1 Reply Last reply Reply Quote 1
                          @nightowl999 Some remarks to your resurrect.g:
                          1. G60 S1 - this saves the current coordinate values in the memory slot which is later referred to from M24 (resume print). For this to work, the coordinates must have been set before. That’s the G92 line, in front of G60.
                          2. M486 S-1 - the context is object cancellation, but I don’t quite understand the meaning. In my resurrect.g, the parameter was T-1, which is not documented but could have meant something like „don’t cancel objects“.
                          3. G1 F2500.0 P0 - this one sets the feed rate, but the P0 is special - from the GCode Reference: „Pnnnn (supported only in some builds of RepRapFirmware)“. I once figured out the port bits (IOBITS), but I have no guess whether P0 is used by our RRF or simply ignored.
                          All of the other entries have a potential meaning with 3D printers, depending on the setup, but I have not the faintest idea which entries you really need for your mill: do you heat a nozzle, use multiple coordinate systems or do you extrude something? OK, just see your latest post - I’ll go through that in a minute … [contemplating] … 😔
                            @nightowl999 After some contemplation, I commented your commented resurrect.g:
                            ; >>> These two lines belong together and prepare the latter use of M24
                            ; >>> ALL tools are deselected or, in a sense, deactivated. I’m not sure, but I think that in CNC mode, this would prevent any motorized tool from spinning?
                            ; >>> At the time this macro is generated, these data can directly be read from the object model - in a way, you "store" them in resurrect.g for later use
                            ; >>> Yes.
                            ;  >>> Needed to activate G10 L2 P1
                            ; >>> Fine. One problem less :-)
                            ; >>> Don’t know either - do your .gcode files contain G2 oder G3 commands? I think the larger problem is to get to know the proper command in use from the object model: G17, G18 or G19
                            ; >>> Not quite: the first G0 puts Z 2 mm above the saved height (to ensure lee-room for the following X/Y move), the third G0 goes to the bone.
                            ; >>> That's suitable for 3D Printers, don't know how to best navigate a tool on your router ..
                            ; >>> How can I translate "extrusion rate" into the CNC world? Are any "extruders" in use?
                            Fine. That's less work than needed for a 3D Printer to recover properly.
                            In the next step, I have to figure out what trick you apply to manage your spindle. Was a good idea to add your pause/resume scripts to your post 👍
                            • Nightowlundefined
                              @infiniteloop Thank you 👍
                              In response to your comments, here are mine...
                              Line 13 - M3 would stop the spindle spinning
                              Line 19 - I know where they are, but at what point can the values be 'recovered' and saved
                              Line 52 - Not in config.g, but I CAN find G3 in the toolpath (gcode) files (e.g. "G3X31.755Y28.580I3.175J0.000" from a Vectric CAD file (these are G2 - clockwise, and G3 - counterclockwise, arc movements)
                              Line 60 - OK, understood
                              Line 61 - I think movement is controlled by G1 X*Y*X*  with speed defined with F*, e.g. G1X49.124Y56.098F3683.0
                              Line 64 - No, there are no extruders
                                @nightowl999 OK, now I have edited (faked) a resurrect.g, easy to read as it is really short. I've reflected some of your comments…
                                G60 S1					; save to slot 1 for latter use of M24
                                T-1 P0					; this enables the macros tpreN.g and tpostN.g to be called by the following T0
                                T0						; change(!) to tool T0, call the corresponding macros
                                M3 S10000				; set spindle speed - don’t worry, we create a macro with this line like we created HelloWorld :-)
                                G10 L2 P1 X147.00 Y584.00 Z67.00	; restore the coordinates for coords-system #1
                                G17					; or G18, G19 - needed for circular moves
                                M23 "0:/gcodes/Calibration Toolpath.gcode"		; select the interrupted CNC file
                                G0 F6000 Z66.000			; rapid move to saved Z height
                                With the G0 movements, formerly known as line 61, you misunderstand my concerns: It's not the syntax, but what path is safe for these head moves on a CNC? Are you fine with the movements as they are done in resurrect.g?
                                So, your homework for now: carefully check my faked resurrect.g, especially with regard to the position of the M3 command: shall the spindle start that early in the recovery process?
                                  @nightowl999 In case you can put the M3 before resurrect.g, the solution is pretty simple: Here is a macro which just stores the spindle speed in the file "RestoreSpindleSpeed.g", which in turn can be called from your resurrect-prologue.g. The only thing left to figure out is how to insert the call of "SaveSpindleSpeed.g" into the M911 command.
                                  ; SaveSpindleSpeed.g
                                  ; Macro to store the actual spindle speed (RPM) at the time this is called
                                  ; To restore the saved datum, call the macro "RestoreSpindleSpeed.g".
                                  ; Requires RRF 3.4 and a CNC configuration with valid spindles[0] entry in the object model
                                  var fName = "RestoreSpindleSpeed.g"
                                  echo >{var.fName} "; "^var.fName
                                  echo >>{var.fName} "; Spindle speed saved from running """^{job.file.fileName}^""" CNC file"
                                  echo >>{var.fName} "M3 S"^{spindles[0].active}
                                  • Nightowlundefined
                                    @infiniteloop said in Power failure and resurrection on a CNC machine:
                                    It's a very long time since I've had homework! 🤣
                                    With regard to the G0 movements, I need to ask a question. If the XYZ values are saved when the power loss workflow starts (based on the M911), then these should be fine in this circumstance, but would change when overwritten by the next power loss event. Have I got that right?
                                    It was suggested to me that the spindle should start before the axes move, as it would then cut its way through an obstruction, rather than not and end up it breaking and damaging the stock.
                                    The most important axis save is the Z axis. With a power failure X and Y can physically stay where they are, although I appreciate their respective 3 dimensional locations must be saved as the axes must be re-homed after restarting.
                                    Note: I get that a 3D printer should not re-lay material a second time following restart, but this is not an issue for the CNC. As the part to be cut has already been cut, it will only cut air.
                                      Perfectly!
                                      Fine, than you can try my latest macro 😁
                                      Yeah, I ask because, with 3D printers, all X/Y moves above the current Z-height of the print are perfectly safe. That's what resurrect.g assumes. However, with routers, this might be different - I simply don't know that.
                                      I have been looking in how to insert a macro call into M911 - alas, the reality check on my printer fails: although configured, M911 does not execute on a simulated power loss. Could you help me out with that?
                                      It's simple: out-comment the M911 line in your config, then put something like this below:
                                      M911 S13.1 R24.0 P"M98 P""SaveSpindleSpeed.g"" M913  X0 Y0  G91 M83 G1 Z3 E-5 F1000"
                                      Parameters can be different on your milling machine (especially S and R of M911).
                                      If you have put the "SaveSpindleSpeed.g" macro into /sys before, you should find the spindle speed at power-off in the macro "RestoreSpindleSpeed.g" after you have repowered your mill.
                                      • Nightowlundefined
                                        @infiniteloop
                                        Just so I'm clear (sorry), do I need to run a project file and power off during that, or will the file be generated without running a project file?
                                        Also, there isn't a file of that name in the \sys folder yet.
                                        Also also 🙂 I probably don't need to include anything after Y0 as I don't have an extruder (except perhaps the Z3?)
                                        • Nightowlundefined
                                          Nightowl @Nightowl
                                          @infiniteloop
                                          Talk about slow! I'm not getting topic updates, so missed the bit about writing the macro.
                                          I've done it now and, with the spindle running, switched off the machine at the mains, then turned it back on again.
                                          This is the resulting SavedSpindleSpeed.g file...
                                          I've also written a RestoreSindleSpeed.g file with just a REM line at Line 1, and this is what's in it when I run the SavedSpindleSpeed.g file...
                                          ; RestoreSpindleSpeed.g
                                          ; Spindle speed saved from running "null" CNC file
                                          M3 S0
                                          ;EOF
                                            I've also written a RestoreSindleSpeed.g file with just a REM line at Line 1.
                                            Then, something goes wrong. The macro RestoreSpindleSpeed.g is generated by a call of SaveSpindleSpeed.g. So, if you have put SaveSpindleSpeed.g into the M911 line in your config,g, then cut power off …
                                            After repowering the machine, RestoreSpindleSpeed.g should be to find in your /sys folder of the SD card. Every time you see it in /sys, you can delete it right away. It is just needed until you have run your resurrect.g - which in turn calls resurrect-prologue.g, into which you - hopefully - have insert the line
                                            M98 P"RestoreSpindleSpeed.g"
                                            As long as no job is in progress during the power fail, you will get "null" as CNC file name, and if the spindle speed is 0, the resulting M3 S0 is ok.
                                            That's right for your router.
