    Power failure and resurrection on a CNC machine
    CNC
    7.4k
    • infiniteloopundefined
      infiniteloop @Nightowl
      @nightowl999 This time, the debugging session took not as long as I expected, so here’s some fish for the cat: 😸
      ; --- just a sample resurrect.g file: don't ever execute! ---
      √M141 P0 S50.0										; activate chamber heater
      √G29 S1												; load the height map from file and activate bed compensation
      √T-1 P0												; de-select tools, don't run macros
      √G92 X-101.068 Y6.281 Z9.100							; set position of head without moving it
      √G60 S1												; store current position in slot #1
      M98 P"resurrect-prologue.g"
      √M116												; wait for all temperatures to reach their set values
      √M290 X0.000 Y0.000 Z0.100 R0						; restore babystepping offsets
      √G10 L2 P1 X0.00 Y0.00 Z0.00							; L=2: this sets the origin of the coordinate system number
      G10 L2 P2 X0.00 Y0.00 Z0.00							;	 specified by the P parameter (1 to 9) to the specified X, Y, X... values
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      G54													; select coordinate system #1
      √G10 P1 S0 R0										; set active(S) and standby(R) temperatures for tool #1
      √T1 P0												; select tool #1, don't run macros
      √G10 P0 S230 R225									; set active(S) and standby(R) temperatures for tool #0
      √T0 P6												; select tool #0, run macros (0b0110) - tfree=1, tpre=2 and tpost=4
      M106 S0.70											; set fan speed (fan defaults to #0)
      √M106 P0 S0.70										; 	now, with dedication to every possible fan
      √M106 P1 S0.00
      M106 P2 S0.00
      M106 P5 S0.00
      M106 P7 S0.00
      M106 P8 S0.00
      √G92 E0.00000										; set position of extruder without moving it
      √M83													; extruder to relative
      √M23 "0:/gcodes/Grundplatte II.gcode"				; select file for printing
      √M26 S8015948 P0.000									; set pointer into file (P=proportion of the first move to be skipped, default 0.0, must be less than 1.0)
      √G0 F6000 Z11.200									; place Z 2 mm above the printing position
      √G0 F6000 X-91.068 Y6.281							; drive X and Y to the printing position
      √G0 F6000 Z9.200										; lower Z for 2 mm into its printing position
      √G1 F3000.0 P0										; use speed F, set port bits to 0 (remainder from RRF 2?)
      G21													; set units to mm
      √M24													; resume print (after a pause)
      That’s an older resurrect.g file that I used as a first template for my own recovery macro. I’ve added comments to understand what’s going on, every GCode I then implemented in my counterpart has a checkmark.
      Depending on the editor and font used, the comments are badly misaligned. For better readability, you might want to paste the content of the black box into your editor of choice and ameliorate the text at will. 😜
      Recently generated "resurrects" look a bit different, so I suggest you to publish your latest resurrect.g - I'd like to have a look at that.
      Nightowlundefined 1 Reply Last reply Reply Quote 0
      • Nightowlundefined
        Nightowl @infiniteloop
        @infiniteloop
        Here is the latest resurrect.g file:
        ; File "0:/gcodes/Calibration Toolpath.gcode" resume print after power failure at 2022-05-29 16:49
        G21
        G92 X182.895 Y658.930 Z66.000
        G60 S1
        T-1 P0
        M116
        M290 X0.000 Y0.000 Z0.000 R0
        ; Workplace coordinates
        G10 L2 P1 X147.00 Y584.00 Z67.00
        G54
        M106 S0.50
        M106 P0 S0.50
        M116
        G92 E0.00000
        M83
        M486 S-1
        G17
        M23 "0:/gcodes/Calibration Toolpath.gcode"
        M26 S249
        G0 F6000 Z68.000
        G0 F6000 X182.895 Y658.930
        G0 F6000 Z66.000
        G1 F2500.0 P0
        G21
        M24
        I was under the impression this file was overwritten with a new one every time there was a 'power failure', and it wasn't user-editable?
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
          @nightowl999 said in Power failure and resurrection on a CNC machine:
          Your first impression is correct. Whether resurrect.g is write-protected or not? Can't tell you as I currently have no such file at hand …
          Nevertheless, here's the first lesson - by the way, it demonstrates how M911 generates resurrect.g, up to the fact that the generated file will always be overwritten when we call M98 P"MWriter.g" again 😊
          ; MWriter aka macro writer
          ; Creates the macro "HelloWorld.g" on the SD card which in turn can be executed
          ; Requirements: RRF v3.4
          ; To keep things simple, we use the /sys directory - which makes sense as any recovery macros should live in there.
          ; For development and tests, I use DWC, mainly with the "System" tab
          var fName = "HelloWorld.g"			; this is the filename for the macro to create
          ; Here, we create the file - note the use of a single ">" with echo: this overwrites any existing file with this name.
          echo >{var.fName} "; HelloWorld.g"
          ; with ">>", echo appends something to the now existing file:
          echo >>{var.fName} "; Macro file created by macro ""MWriter.g"""	; we always write strings - note how to put a string into it (""MWriter.g"")
          echo >>{var.fName} ""												; empty line for better readability
          echo >>{var.fName} "M291 S2 R""Hello World"" P""Moin Moin"""		; message box, blocking (S2), with title (R) and message (P), localized :-)
          echo >>{var.fName} ";EOF"											; ... old habit of mine
          ;EOF																; same habit ...
          Oh, and thanks for your resurrect.g - I'll try to study it. Did you make a copy and added comments?
          • Nightowlundefined
            @infiniteloop
            Yes, here it is, but I'm not sure if I've done it correctly...
            G21					; sets units to mm
            G92 X182.895 Y658.930 Z66.000		; sets the position for X, Y and Z
            G60 S1					; save memory slot number
            T-1 P0					; deselects the tool
            M98 P"resurrect-prologue.g"		; runs the user-defined resurrect-prologue.g
            M116					; wait for all temperatures to reach set value
            M290 X0.000 Y0.000 Z0.000 R0		; sets babystepping (not CNC)
            G10 L2 P1 X147.00 Y584.00 Z67.00	; origin of coordinate system number
            G10 L2 P2 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P3 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P4 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P5 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P6 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P7 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P8 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G10 L2 P9 X0.00 Y0.00 Z0.00		; as above for 3D printers
            G54					; select coordinate system 1
            M106 S0.50				; turns the fan on at half speed
            M106 P0 S0.50				; turns user-configured fan on
            G92 E0.00000				; sets the position for the extruder
            M83					; sets extruder to relative mode
            M486 S-1				; Indicate a non-object, purge tower, or other global feature
            G17					; select XY plane for arc moves
            M23 "0:/gcodes/Calibration Toolpath.gcode"	; selects the file previously running
            M26 S249				; set file offset from the start of the interrupted file
            G0 F6000 Z68.000			; rapid move to above saved Z height
            G0 F6000 X182.895 Y658.930		; rapid move to saved XY axes
            G0 F6000 Z66.000			; reaped move to saved Z height
            G1 F2500.0 P0				; controlled linear move  relating to output pins
            M24					; start/resume SD print
            infiniteloopundefined 2 Replies Last reply Reply Quote 0
              Thx, and well done! From a first glance, I get the impression that this resurrect.g is missing all the things which are specific to CNC routers.
              Could you please try to edit this commented version and insert comment lines with the CNC specific commands you miss? Think carefully, the sequence of commands is essential, else you can wreck your machine in the worst case.
              With this "script" ready, we can see if the required additions can be called from resurrect-prologue.g or if we have to write the whole M911 stuff ourselves.
              Nightowlundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • Nightowlundefined
                @infiniteloop Whew, let's see how this goes...
                G60 S1					; I think a user-defined save slot can be 0, 3, 4 or 5 (0 is default)
                ? T-1 P0				; I'm not sure why the tool is deselected
                Assuming this data has been saved in the state.restorePoints nodes...
                T0					; select the last tool used - this should be stored in the relevant state.restorePoints[*].toolNumber
                Set savedSpindleSpeed			; select the last tool's spindle speed - this should be stored in the relevant state.restorePoints[0].spindleSpeeds
                ; M116					; not relevant for CNC
                ; M290 X0.000 Y0.000 Z0.000 R0		; not relevant for CNC
                G10 L2 P1 X147.00 Y584.00 Z67.00	; I think this is necessary
                ; G10 L2 P2 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P3 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P4 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P5 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P6 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P7 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P8 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ; G10 L2 P9 X0.00 Y0.00 Z0.00		; not relevant for CNC
                ? G54					; select coordinate system 1
                ; M106 S0.50				; not relevant for my CNC
                M106 P0 S0.50				; turns user-configured fan on (I've got a case fan configured)
                ; G92 E0.00000				; not relevant for CNC
                ; M83					; not relevant for CNC
                ? M486 S-1				; not relevant for CNC
                ? G17					; not sure if this is relevant for CNC - it's not in the config.g file
                ? G1 F2500.0 P0				; controlled linear move relating to output pins
                Before the power failure happens, I know where the spindle information is held, as I use that in my pause.g (which includes a test M28/M29 script) and resume.g files. These may help, so I've added them below...
                ; pause.g
                M28 savedCNC.g
                echo "Duet and RepRap are fantastic"
                M29
                set global.savedSpindleSpeed = spindles[0].active ; sets the global variable
                echo "Spindle speed saved at " ^ {global.savedSpindleSpeed} ^ "RPM" ; shows saved spindle speed in the Console
                G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} F2400 ; move the Z axis to a safe height
                G0 X273.5 Y560 ; move XY to a safe place
                M5 ; turn the spindle off
                ; resume.g
                if state.currentTool =-1
                	echo "No tool active.  Selecting tool zero"
                	T0 ; select tool zero
                if state.currentTool >= 0
                	echo "Spindle state on tool ", state.currentTool, " is ", spindles[state.currentTool].state
                if {state.currentTool >= 0} & {tools[state.currentTool].spindleRpm >= 0}
                	M3 S{global.savedSpindleSpeed} ; resume saved spindle speed
                	G4 S1 ; wait 1 second to allow the spindle to spin up
                	echo "Spindle speed resumed at " ^ {global.savedSpindleSpeed} ^ "RPM" ; this should show the setting was successful
                G0 R1 X0 Y0 ; move X and Y back to saved work XY location
                G1 R1 Z0 F240 ; move Z slowly down to saved work Z location
                infiniteloopundefined 1 Reply Last reply Reply Quote 1
                  @nightowl999 Some remarks to your resurrect.g:
                  1. G60 S1 - this saves the current coordinate values in the memory slot which is later referred to from M24 (resume print). For this to work, the coordinates must have been set before. That’s the G92 line, in front of G60.
                  2. M486 S-1 - the context is object cancellation, but I don’t quite understand the meaning. In my resurrect.g, the parameter was T-1, which is not documented but could have meant something like „don’t cancel objects“.
                  3. G1 F2500.0 P0 - this one sets the feed rate, but the P0 is special - from the GCode Reference: „Pnnnn (supported only in some builds of RepRapFirmware)“. I once figured out the port bits (IOBITS), but I have no guess whether P0 is used by our RRF or simply ignored.
                  All of the other entries have a potential meaning with 3D printers, depending on the setup, but I have not the faintest idea which entries you really need for your mill: do you heat a nozzle, use multiple coordinate systems or do you extrude something? OK, just see your latest post - I’ll go through that in a minute … [contemplating] … 😔
                    @nightowl999 After some contemplation, I commented your commented resurrect.g:
                    ; >>> These two lines belong together and prepare the latter use of M24
                    ; >>> ALL tools are deselected or, in a sense, deactivated. I’m not sure, but I think that in CNC mode, this would prevent any motorized tool from spinning?
                    ; >>> At the time this macro is generated, these data can directly be read from the object model - in a way, you "store" them in resurrect.g for later use
                    ; >>> Yes.
                    ;  >>> Needed to activate G10 L2 P1
                    ; >>> Fine. One problem less :-)
                    ; >>> Don’t know either - do your .gcode files contain G2 oder G3 commands? I think the larger problem is to get to know the proper command in use from the object model: G17, G18 or G19
                    ; >>> Not quite: the first G0 puts Z 2 mm above the saved height (to ensure lee-room for the following X/Y move), the third G0 goes to the bone.
                    ; >>> That's suitable for 3D Printers, don't know how to best navigate a tool on your router ..
                    ; >>> How can I translate "extrusion rate" into the CNC world? Are any "extruders" in use?
                    Fine. That's less work than needed for a 3D Printer to recover properly.
                    In the next step, I have to figure out what trick you apply to manage your spindle. Was a good idea to add your pause/resume scripts to your post 👍
                    • Nightowlundefined
                      @infiniteloop Thank you 👍
                      In response to your comments, here are mine...
                      Line 13 - M3 would stop the spindle spinning
                      Line 19 - I know where they are, but at what point can the values be 'recovered' and saved
                      Line 52 - Not in config.g, but I CAN find G3 in the toolpath (gcode) files (e.g. "G3X31.755Y28.580I3.175J0.000" from a Vectric CAD file (these are G2 - clockwise, and G3 - counterclockwise, arc movements)
                      Line 60 - OK, understood
                      Line 61 - I think movement is controlled by G1 X*Y*X*  with speed defined with F*, e.g. G1X49.124Y56.098F3683.0
                      Line 64 - No, there are no extruders
                        @nightowl999 OK, now I have edited (faked) a resurrect.g, easy to read as it is really short. I've reflected some of your comments…
                        G60 S1					; save to slot 1 for latter use of M24
                        T-1 P0					; this enables the macros tpreN.g and tpostN.g to be called by the following T0
                        T0						; change(!) to tool T0, call the corresponding macros
                        M3 S10000				; set spindle speed - don’t worry, we create a macro with this line like we created HelloWorld :-)
                        G10 L2 P1 X147.00 Y584.00 Z67.00	; restore the coordinates for coords-system #1
                        G17					; or G18, G19 - needed for circular moves
                        M23 "0:/gcodes/Calibration Toolpath.gcode"		; select the interrupted CNC file
                        G0 F6000 Z66.000			; rapid move to saved Z height
                        With the G0 movements, formerly known as line 61, you misunderstand my concerns: It's not the syntax, but what path is safe for these head moves on a CNC? Are you fine with the movements as they are done in resurrect.g?
                        So, your homework for now: carefully check my faked resurrect.g, especially with regard to the position of the M3 command: shall the spindle start that early in the recovery process?
                          @nightowl999 In case you can put the M3 before resurrect.g, the solution is pretty simple: Here is a macro which just stores the spindle speed in the file "RestoreSpindleSpeed.g", which in turn can be called from your resurrect-prologue.g. The only thing left to figure out is how to insert the call of "SaveSpindleSpeed.g" into the M911 command.
                          ; SaveSpindleSpeed.g
                          ; Macro to store the actual spindle speed (RPM) at the time this is called
                          ; To restore the saved datum, call the macro "RestoreSpindleSpeed.g".
                          ; Requires RRF 3.4 and a CNC configuration with valid spindles[0] entry in the object model
                          var fName = "RestoreSpindleSpeed.g"
                          echo >{var.fName} "; "^var.fName
                          echo >>{var.fName} "; Spindle speed saved from running """^{job.file.fileName}^""" CNC file"
                          echo >>{var.fName} "M3 S"^{spindles[0].active}
                          • Nightowlundefined
                            @infiniteloop said in Power failure and resurrection on a CNC machine:
                            It's a very long time since I've had homework! 🤣
                            With regard to the G0 movements, I need to ask a question. If the XYZ values are saved when the power loss workflow starts (based on the M911), then these should be fine in this circumstance, but would change when overwritten by the next power loss event. Have I got that right?
                            It was suggested to me that the spindle should start before the axes move, as it would then cut its way through an obstruction, rather than not and end up it breaking and damaging the stock.
                            The most important axis save is the Z axis. With a power failure X and Y can physically stay where they are, although I appreciate their respective 3 dimensional locations must be saved as the axes must be re-homed after restarting.
                            Note: I get that a 3D printer should not re-lay material a second time following restart, but this is not an issue for the CNC. As the part to be cut has already been cut, it will only cut air.
                              Perfectly!
                              Fine, than you can try my latest macro 😁
                              Yeah, I ask because, with 3D printers, all X/Y moves above the current Z-height of the print are perfectly safe. That's what resurrect.g assumes. However, with routers, this might be different - I simply don't know that.
                              I have been looking in how to insert a macro call into M911 - alas, the reality check on my printer fails: although configured, M911 does not execute on a simulated power loss. Could you help me out with that?
                              It's simple: out-comment the M911 line in your config, then put something like this below:
                              M911 S13.1 R24.0 P"M98 P""SaveSpindleSpeed.g"" M913  X0 Y0  G91 M83 G1 Z3 E-5 F1000"
                              Parameters can be different on your milling machine (especially S and R of M911).
                              If you have put the "SaveSpindleSpeed.g" macro into /sys before, you should find the spindle speed at power-off in the macro "RestoreSpindleSpeed.g" after you have repowered your mill.
                              • Nightowlundefined
                                @infiniteloop
                                Just so I'm clear (sorry), do I need to run a project file and power off during that, or will the file be generated without running a project file?
                                Also, there isn't a file of that name in the \sys folder yet.
                                Also also 🙂 I probably don't need to include anything after Y0 as I don't have an extruder (except perhaps the Z3?)
                                • Nightowlundefined
                                  Nightowl @Nightowl
                                  @infiniteloop
                                  Talk about slow! I'm not getting topic updates, so missed the bit about writing the macro.
                                  I've done it now and, with the spindle running, switched off the machine at the mains, then turned it back on again.
                                  This is the resulting SavedSpindleSpeed.g file...
                                  I've also written a RestoreSindleSpeed.g file with just a REM line at Line 1, and this is what's in it when I run the SavedSpindleSpeed.g file...
                                  ; RestoreSpindleSpeed.g
                                  ; Spindle speed saved from running "null" CNC file
                                  M3 S0
                                  ;EOF
                                    I've also written a RestoreSindleSpeed.g file with just a REM line at Line 1.
                                    Then, something goes wrong. The macro RestoreSpindleSpeed.g is generated by a call of SaveSpindleSpeed.g. So, if you have put SaveSpindleSpeed.g into the M911 line in your config,g, then cut power off …
                                    After repowering the machine, RestoreSpindleSpeed.g should be to find in your /sys folder of the SD card. Every time you see it in /sys, you can delete it right away. It is just needed until you have run your resurrect.g - which in turn calls resurrect-prologue.g, into which you - hopefully - have insert the line
                                    M98 P"RestoreSpindleSpeed.g"
                                    As long as no job is in progress during the power fail, you will get "null" as CNC file name, and if the spindle speed is 0, the resulting M3 S0 is ok.
                                    That's right for your router.
                                    • Nightowlundefined
                                      @infiniteloop
                                      So I tried to experiment a little...
                                      I ran a small gcode file which set the spindle speed to 18,000rpm then initiated a power cut.
                                      When I ran the RestoreSpindleSpeed.g from the MDI, the spindle started up - at 18,000rpm.
                                      This is the file:
                                      ; Spindle speed saved from running "0:/gcodes/Calibration Toolpath.gcode" CNC file
                                      M3 S18000
                                      I've now added the M98 line to resurrect-prologue.g file, so it looks like this:
                                      ; resurrect-prologue.g
                                      M98 "RestoreSpindleSpeed.g"
                                        This is the file:
                                        That's what I've expected. The only thing I miss is my beloved ";EOF" at the end of RestoreSpindleSpeed.g 😊
                                        Now the big question: does this setup what you want or do you need additional functions to be restored after a power off? With the same technique, we could generate a complete replacement or a better suited version of resurrect.g.
                                        • Nightowlundefined
                                          @infiniteloop
                                          That's awesome, thank you 👍
                                          Because this is following a power failure, and from a safety perspective, there are some procedures I will need to initiate from starting up after the power failure (it's never my intention to be away from the machine while it's running, by the way).
                                          I understand the machine must be homed, so it knows where it is, return to its last known XY location, remember what file it was running, remember where in that file it had got to, then wait for me to say OK for it to carry on. At the 'carry on' it should start the spindle and plunge slowly down to it's last known Z height then continue the project.
                                          Simples!
                                          I think the parameters for most of that will be in the resume.g file?
                                          I've added the EOF line!
                                            That depends. Currently, your resume.g is mainly meant to be called after a pause - I doubt you want this to permanently call for permission to continue. Also, at that stage of resurrect.g, i.e. when resurrect.g calls resume.g, the spindle is already running. Nothing to dream of - you want to be asked before.
                                            A better place to ask might be your resurrect-prologue.g. From there, you can cancel further execution of resurrect.g.
                                            The question here is: does resurrect.g what you want? As I said, we can insert a dialog in the prologue which then asks for permission to continue … but are you fine with the part of resurrect.g which follows on the call of the prologue?
