    Power failure and resurrection on a CNC machine
    CNC
    7.4k
    • infiniteloopundefined
      infiniteloop @Nightowl
      @nightowl999 said in Power failure and resurrection on a CNC machine:
      Nope. It's just my 24V PSU
      If you put your UPS on that, the Duet won't notice the loss of mains power: Without a voltage drop, M911 won't be executed … until the UPS runs out of juice. But then, you face the same situation as now.
        What use is a 5V supply if it's on the same mains circuit?
        You could either use a large capacitor, a tiny UPS or a power bank to keep the 5V alive for a while.
        Nightowlundefined 1 Reply Last reply Reply Quote 1
        • Nightowlundefined
          Nightowl @infiniteloop
          @infiniteloop
          If you don't mind, is this something you would plug into the Duet's USB port, and would the power bank stay charged/charging whilst connected, then slowly (slower than the PSU) drain down giving more time to save what I need to save?
          Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
          I'm still on my learning curve, so take everything I say with caution!
          RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
            Never. All the Duet boards I know of (don't know all of them) have an optional 5V input.
            That depends on the power bank. Sorry, but due to my limited knowledge, I can't give you recommendations for specific devices. Have you searched the forum on this topic yet? I didn't, but I stumbled across some related posts in the past. πŸ‘
            • Nightowlundefined
              @infiniteloop OK, thank you. I'll ask this question separately then, burt I didn't want to seem impatient πŸ™‚
              Again, I really appreciate the time and effort you've put in to help me with this - you've been brilliant πŸ‘ πŸ‘
                Maybe you search before you ask? Chances are good that then, your questions are more specific. Fore example, I still face the miracle that my Duet doesn't execute the M911 command sequence if I shut off my large power supply but keep the 5V rail alive. Remember, I came across that when I ran some macro tests for this thread on my Duet.
                So I'll dive into the ocean of Duet3D documentation and figure out how and when resurrect.g is triggered. This, in turn, seems to depend on how I configure and supply my various voltages.
                What I mean is: if you ask how to connect a UPS (or a power bank), the replies don't include the aspect of recovery from power failure. Is the way we elaborated in this thread still viable, or do you then need a different solution? Or: depending on your power setup, you might be able to came along with a simple capacitor - which won't work well if all your steppers suck from that, too.
                I suggest you go to the hardware section first (as a first read, I suggest this, this and something like this) and figure out how to separate the 5V from the rest. If you got the idea, ask the forum - not the other way round, because then, there's too much noise in the replies.
                • Nightowlundefined
                  Nightowl
                  Thanks, @infiniteloop. I do try to search the forums and the documentation first, but I don't seem to find anything descriptive enough to work from so ask on the forum.
                  Of course, as I get to know stuff, I'll be asking fewer questions and giving more help πŸ™‚
                  Thanks again, my friend πŸ‘
                  • Nightowlundefined
                    Nightowl
                    @infiniteloop
                    So maybe the issue may not be power decline related...
                    I changed a couple of things in the M911 line in the config.g file from:
                    M911 S23 R23.5 P"M98 P""SaveSpindleSpeed.g"" M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                    ...to...
                    M911 S23 R23.5 P"M913 X0 Y0 G91""M98 P""SaveSpindleSpeed.g"
                    ...effectively deleting the printer stuff and changing the file order, although I'm not sure if the latter made any difference. I also raised the threshold for power loss.
                    Now, the ResumeSpidleSpeed.g file is fully formed, which is great, but I'm getting a different error, twice, when I enter M916 in the MDI:
                    M292 Error: No P parameter and no active tool with spindle
                    M916 Error: No P parameter and no active tool with spindle
                    This clearly relates to the spindle - again - so I think the SaveSpindleSpeed.g file will need to edited to add those variables from the Object Browser.
                    I'm going to use your lead to see if I can finish this off....
                      @nightowl999
                      There's something wrong: the double quotation marks following G91 should not be there (and you can skip G91 completely), then, a second quotation mark to end the M98 argument is missing, finally, the closing quotation mark of M911 is missing, too. So try this instead:
                      M911 S23 R 23.5 P"M913 X0 Y0 M98 P""SaveSpindleSpeed.g"""
                      Let's try and see if the M292 and M916 errors persist.
                      Nightowlundefined 3 Replies Last reply Reply Quote 0
                      • Nightowlundefined
                        @infiniteloo
                        Ooh, that's a lot of quotation marks...
                        I'll let you know how it goes...
                        • Nightowlundefined
                          @infiniteloop
                          That change truncated the writing of the RestoreSpindleSpeed. g
                          This is all I got...
                          ; RestoreSpindleSpeed.g
                          ; Spindle speed saved from running "0:/gcodes/Calibration Toolpath.gcode" CNC file
                          ; set up the global variable abort_process so we can abort further execution of resurrect.g:
                          if {!exists(global.abort_process)}
                              global abort_process = true
                          else
                              set global.abort_process = true
                          • Nightowlundefined
                            @infiniteloop
                            I deleted the RestoreSpindleSpeed.g to see how much SaveSpindleSpeed.g would write, but there was nothing. Running the SaveSpindleSpeed.g file from the MDI produced the file, but obviously it didn't have any proer values
                              That's what I expected. Due to the misplaced quotation marks, M911 didn't execute properly - I think that even resurrect.g has been malformed by that: this would explain the "No P parameter…" errors.
                              Sigh. One measure of last resort is to trim the execution time of SaveSpindleSpeed.g - with luck, we gain some nanoseconds. So make a copy of your actual SaveSpindleSpee.g file and put this into the macro, instead:
                              var fName = "RestoreSpindleSpeed.g"
                              echo >>{var.fName} "if {!exists(global.abort_process)}"
                              echo >>{var.fName} "    global abort_process = true"
                              echo >>{var.fName} "else"
                              echo >>{var.fName} "    set global.abort_process = true"
                              echo >>{var.fName} "M291 S3 R""Resurrect:"" P""Continue with <"^{job.file.fileName}^">?"""
                              echo >>{var.fName} "set global.abort_process = false"
                              echo >>{var.fName} "M3 S"^{spindles[0].active}
                              With luck, this will work, depending on the current load on the Duet. But I have to insist: that's not good practice, it's more like a ride on a razor blade.
                              Nightowlundefined 2 Replies Last reply Reply Quote 0
                              • Nightowlundefined
                                @infiniteloop
                                Sorry, about this, but I tried something while you were cogitating...
                                I edited the M911 file to this:
                                M911 S23 R 23.5 P"M913 X0 Y0 M98 P"SaveSpindleSpeed.g"
                                ...and it worked, apart from the spindle errors. The SavedSpindleSpeed was fully formed, too.
                                I don't think it's a timing thing afterall. The "processing" stays onscreen in the DWC for a few seconds, perhaps 2 or 3?
                                • Nightowlundefined
                                  @infiniteloop
                                  This is the file:
                                  ; Spindle speed saved from running "null" CNC file
                                  else
                                  ; now comes the dialog:
                                  M291 S3 R"Resurrect:" P"Continue with <null>?"
                                  ; we will only arrive here if the dialog was closed with OK:
                                  M3 S0
                                  ;EOF
                                    That's why I decidedly put the macro call at the beginning of the M911 sequence 😸
                                    Nightowlundefined 1 Reply Last reply Reply Quote 0
                                    • Nightowlundefined
                                      @infiniteloop
                                      OK, I'll change them back...
                                        This is the file:
                                        We are out of sync. delete that and look at the file resulting from the next power outage.
                                        • Nightowlundefined
                                          @infiniteloop
                                          File deleted. I'm just changing the M911 line back...
                                          And now I'm going to try again...
                                          And RestoreSpindleSpeed .g only got to line 6...
                                          This is the M911 line in config.g...
                                          M911 S23 R23.5 P"M98 P""SaveSpindleSpeed.g"" M913 X0 Y0"	; set voltage thresholds and actions to run on power loss
                                            At that point, remaining power has gone.
