Can not see files on my panel due i7, duet 3
I need to start a print off line but I can not view any files on the Panel Due. I have had it for a year and everything else works, I can see when a print is going, warm up the hot end, ect but I can not start prints. The SD card icon says zero files. I have the 4 pin connector hooked up. I don't care how I just need to be able to start a print off line.
It would help to know your firmware versions on the Duet and the PanleDue.
@phaedrux panel due is 1.23.2 and duet 3 is 3.1.1 I think
I think you'll need to update the panel for firmware to at least 1.25
@phaedrux how do I do that? Can I do it from the web interface?
You'll need to use USB from a PC and bossa software to flash it.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
Ideally you should update both your paneldue and duet as they are both quite out of date. But I think getting the panel to at least 1.25 should get it working fully with rrf3
@phaedrux oh gezz okay that's a tomorrow problem I'll update you tomorrow. Thank you!
@corvodewittv2 Well I tried updating my firmware and now my screen is just a backlight. How do I know I have the right version.
@phaedrux Replied to myself please see last post
@phaedrux Found the right one but it doesn't seem to display all my print files?
Does it display any files?
What firmware version did you land on?
How many files do you have?
