    Documentation best practice
    17
    1.8k
    • AS-3D Druckundefined
      AS-3D Druck
      Prusa made everything perfect.
      http://manual.prusa3d.com/Guide/1.+Introduction/123
      http://manual.prusa3d.com/c/English_manuals
      Best regards
      AS-3D Druck / Andre
      • PlasticMetalundefined
        PlasticMetal
        I hadn't seen Prusa's docs before, but I see they Dozuki, as does SeeMeCNC. A nice feature of that system is the user can click to generate a PDF, for local reference.
        • botundefined
          bot
          Wow… also the ability to comment on individual steps. Whatever that is, I'm sold.
          *not actually a robot
          • JohnOCFIIundefined
            JohnOCFII
            @AS-3D:
            Agreed - their manuals are very good. Also, the ability to comment on sections was very helpful to me when I built my MK2. Some good hints from users that had gone before. Also, the ability to easily see larger version of the photos is very helpful too.
            • DjDemonDundefined
              DjDemonD
              I think your documentation is great but I came to Duet like probably the majority of users with experience in 3D printing. It does seem this user group doesn't really struggle but certainly some beginners would find a lot of it very confusing.
              I like the idea of having each guide separated into Quick Start/Basics and then the full in-depth explanation that we currently have.
              www.precisionpiezo.co.uk
              • kingfisherundefined
                kingfisher
                I was going to suggest Prusa as a good example too.
                But I also think the current Documentation and Wiki is very good
                Setting up from scratch was fairly easy (After a previous ramps build, so like DjDemonD I'm not a complete NOOB)
                The only time I've slipped up is after making changes thanks to firmware updates (Eg Dual Z leveling) I didn't go back and read the manual (So even the best documentation wouldn't have helped me!)
                Oh & Duet Documentation is a million times better than Smoothieware 😉
                • JustDaveundefined
                  JustDave
                  I recommend treating it as a living document, constantly attended to and updated when required as things change. There are few things worse than a static document with known deficiencies or errors that are never updated and cause needless headaches for all future users.
                  In general, I do not find that to be the case with Duet's documentation; but there is room for improvement in the WIKI. I have found that I cannot even find something I just stumbled across previously. And I finally just bookmarked the page with supported G-Code out of frustration with trying to figure out how I got there the last time. I don't know, maybe I am missing something like an accurate index or site map.
                  • botundefined
                    bot
                    @JustDave:
                    I agree, navigability of the current system is the only area that really needs improvement.
                    • Martin_Sundefined
                      Martin_S
                      A good step by step guide with lots of pictures would be a huge help for first time users. It should be more newbie orientated.
                      Maybe one for Cartesian, one for Delta and one for CoreXY? I mean example builds.
                      The wiki is great, the information is extremely detailed and I really thank the devs for constantly updating it. But to be honest, in some occasions, it feels overwhelming. Many of us don’t like to tweak with the software, we just want to print, make, build and do all sorts of mechanical stuff, so when it is firmware related we feel lost.
                      And take in consideration that a lot of people with 3d printers may know a lot of 3d printing but know nothing about compiling a firmware. The Rostock Max for example: You assemble the printer, then upload the pre-configured firmware and you are good to go. You only need to mess with the firmware if you change something. I'm sure there are a lot of other printers that follow this same situation.
                      In my particular case, it passed more than a year before I decided to buy a Duet, and it was not because of a money issue. It was because I couldn't figure out how to replace the Rambo and use the Duet. There was too much information on the Wiki and I couldn't understand it. I felt stupid because, if I had to ask in the forum, I didn't even know what to ask. All these new concepts were very confusing to me. Until I read mhackneys DuetWifi conversion guide (http://www.sublimelayers.com/2016/12/converting-seemecnc-rostock-max-v3-to.html), that made me pull the trigger.
                      So, thank you Michael, this is by far the best upgrade done to the printer.
                      Sorry for my English, it's hard to express myself in another language.
                      Keep up the good work, I love my Duet.
                      Martin
                      If it ain't broke, fix it till it is =)
                      • Yonkimanundefined
                        Yonkiman
                        @bot:
                        I was just going to suggest exactly that - great to know there's already a solution. The ability to easily give feedback as you're following directions should very quickly highlight what areas need what improvements.
