    Suggestion for a simpler, less error prone, way of bed levelling
    Firmware wishlist
    9
    29
    2.1k
      deckingman @fcwilt
      @fcwilt said in Suggestion for a simpler, less error prone, way of bed levelling:
      @deckingman said in Suggestion for a simpler, less error prone, way of bed levelling:
      bed is mechanically flat and level ... so I don't use any form of firmware compensation
      I have tried tool plate aluminum and 3rd party bed upgrades and they all, to date, require Mesh Bed Compensation to get the first layer to stick.
      What is you secret?
      The usual suspect in that case is that the frame is twisted. You can think of the bed as being a plane - hence we use (or should use) 3 screws or attachment points because 3 points define a plane. So we can level that plane but level it with reference to what? If you have X and Y running on members at the top of the frame, then it will be level with respect to those top members. But what if the frame isn't perfectly square? You have level plane but levelled with respect to a twisted frame, so the height of the nozzle above the bed, will only be correct at the 3 attachment points and might be different at other points on the bed (because the height of the nozzle is affected by the frame member that the gantry runs on and not just the position of the bed).
      Assuming we have 3 lead screws, then the bed plane needs to be level with respect to a plane defined by the attachment points of those 3 screws, and the XY hot end gantry also needs to form a plane which is parallel to those other two. Levelling just the bed, without reference to the hot end XY plane only works if the frame is perfectly square. And remember that if you want to do edge to edge printing as I can do, then the frame members have to be square and parallel within about 0.1mm from end to end. Not many people bother to check and adjust that.
      I actually did a YouTube video on it some time back with an explanation of how to measure and adjust the frame if necessary. The logic applies to whatever method you use to level the bed. https://www.youtube.com/watch?v=H9O1r46Izn8&t=2s
      So in essence you would treat one point as the reference and make the other two match that?
      Or did I fail to understand.. again.
      That's exactly right and is no different to the current method. You always adjust two points with reference to a third.
      fcwiltundefined 2 Replies Last reply Reply Quote 0
      • fcwiltundefined
        fcwilt @deckingman
        @deckingman
        I will be watching the video.
        Bear with me if I use the wrong terms here.
        I have always assumed (bad thing to do, I know) that to print 0.1mm layers you would seek 0.005mm (5% of layer height) nozzle-to-bed accuracy over the desired printing area.
        Given the many possible things getting in the way of achieving that accuracy, it seemed impossible that I could achieve construction to that sort of precision. At least, given the skills and the tools I have.
        I did have one printer where the X gantry rode on two linear guide rails making up the Y axis. It was clear the two guide rails were not lying in the same plane. I resorted to creating 4 point heightmaps and adjusting the relevant frame pieces over and over striving to get the guide rails lined up.
        It was a frustrating trial-and-error process but eventually I got decent results - decent meaning I got fed up trying to do better.
        I would imagine a good machine shop would have the skills and equipment and would know how to quickly and properly make the needed adjustments to the frame.
        Thanks for your contributions to us all.
        • sinned6915undefined
          sinned6915 @deckingman
          @deckingman the CRITICAL requirement for bed leveling is maintaining a symmatric pattern of probe points to Z-points (either leadscrews or adjusters).
          If your coordiantes are not sympathetic the math will not yield good results.
          On a machine with 4 screws/levelers, its easy to see the concentric outlines offset from each other relative to the bed center.
          On a 3-screws machine its a little bit harder. Here is an exaggerated picture that I think illustrates the point.
          • fcwiltundefined
            fcwilt @deckingman
            @deckingman
            I watched the video and it made perfect sense.
            I used to think it would require some sort of "outside" reference like a granite surface plate to get everything adjusted correctly.
            I am going to try your approach and see what state my printers are in.
            One thing you didn't mention in detail was the flatness of the bed itself.
            My supplier of tool plate specs it as flat with 0.015" which works out to 0.381mm - not very flat. Another supplier has flatter stuff if you get 0.5" thick or better but even then it is spec'd at 0.005" which works out to 0.127mm - better but still varying by more than one layer height for 0.1mm layer height printing.
            So just how flat is your bed and how did you achieve it?
            deckingmanundefined sinned6915undefined 2 Replies Last reply Reply Quote 0
              deckingman @sinned6915
              @sinned6915 said in Suggestion for a simpler, less error prone, way of bed levelling:
              I'd have to disagree somewhat. Firstly, only 3 points define a plane - any more than that defines some sort of curved surface. So, as I said in my opening post, if you have more than the optimum number (3) of attachment/adjustment points you would be trying to level a curved surface, not a plane which is a pointless exercise. Regarding probe points, if you watch my video that I posted a link to for @fcwilt , you'll see why you should always probe XY in a straight line across the centre of the bed in the Y direction, and front to back in a straight line across the centre of the bed in the X direction. This will negate the effect that a slope in the Y direction would have when measuring left to right and the effect that a slope in the X direction would have when measuring from front to back. It should go without saying that a straight line between left/right adjustment points should be parallel with X axis and the Y adjuster should be at right angles to that line and ideally, at the centre of that line.
                deckingman @deckingman
                The point I'm trying to make here is that to level a plane such as a build plate simply requires determining the slope of that plane from left to right and from front to back then ensuring that any adjustment will compensate for that slope. It largely doesn't matter what the distance between measurement points is except that the further they are apart the less likely the measurement error. It also doesn't matter where in space those measurement points are in respect to the bed plate, the printer frame, the nozzle or anything else. We just need to determine the slope of the line. Then we need to adjust one of the screws such that a line drawn between pivot points has the same magnitude slope (but in the opposite direction). It doesn't matter how far apart those pivot points are, or where they are with respect to the probe, the nozzle, the edge of the build plate or anything else. But I thought it would go without saying that, a line drawn between pivot points should be parallel with the line between probe points.
                To determine the slope of a straight line is a simple calculation, so I'm confused as to why it is necessary to use a least squares curve fit algorithm.
                sinned6915undefined 1 Reply Last reply Reply Quote 0
                  deckingman @fcwilt
                  @deckingman
                  I just used "Ecocast" from these people https://www.aluminiumwarehouse.co.uk/aluminium-plate-cut-to-order/. I have no idea what the flatness tolerance is - they don't say. But I do have a precision straight edge similar to this https://www.axminstertools.com/veritas-aluminium-straight-edge-610mm-24-701278 which is machined flat to a tolerance of 0.075mm over the entire length which I used to check it with. I couldn't see daylight anywhere so that's good enough for me. Had it been bowed in any way, I'd have used shims between the plate and frame such that tightening the fixing bolts would pull or push it into shape as necessary. In the event, I didn't have to bother.
                  Having said all that, I've never tried printing edge to edge at 0.1mm layer height. I can't think why I'd ever want to do a first layer like that on a bed that's 400mm square. But almost edge to edge at 0.3mm layer height works just fine without any ripples or curling so 0.1mm might also work. This is a video from 5 years ago and much has changed on the printer, but the bed is the same. https://www.youtube.com/watch?v=U733PMTou7M
                    @deckingman I agree with your point of simplicity to the defining the plane. I do not agree with the suppposition that the lines connecting the points of adjustment have to be parallel to the axis of motion. Look at Delta printer's for example.
                    Appliction of least squares is done when you have an over-defined system mathematically. It's a mathematical method that can be used to fit a curve, or a line, or a plane to a bunch of data points.
                    With 3 points and 3 degrees of freedom, it reduces to 1 exact solution. Your intersecting lines is an appropriate analogy and can proably be constructed to prove it.
                    I think the bigger issue is that most people don't understand/don't remember/can't visialize the geometric discussion we are trying to make. Just blindly throwing in some coordinates will not make for a corrected plane.
                    My point is the ideal probing locations should mimic the relative positions of the adjusting elements. Think similar triangles.
                      sinned6915 @fcwilt
                      @fcwilt said in My supplier of tool plate specs it as flat with 0.015" which works out to 0.381mm - not very flat. Another supplier has flatter stuff if you get 0.5" thick or better but even then it is spec'd at 0.005" which works out to 0.127mm - better but still varying by more than one layer height for 0.1mm layer height printing.
                      I have checked mine on a surface plate and its out 0.2 over 500mm in one direction. It looks like segment of a cylinder. The surface plate is 3' square and AA grade.
                      • fcwiltundefined
                        fcwilt @deckingman
                        @deckingman
                        Thank you for that link about your bed material.
                        I never thought about printing a thicker first layer just to get things started.
                          dc42 administrators @deckingman
                          @deckingman I agree that your suggested method would work.
                          However, if you probe 3 points on a bed with 3 attachment points, then the least squares calculation gives exactly the same result as your suggested method. You method requires the attachment points (or at least, the spacing between them) to be known, so I don't see that it is any simpler. The calculation is certainly simpler, however RRF includes a least-squares solver for delta printer calibration anyway.
                          The use of a least-squares solver gives you the chance to probe more points then attachment points, which for those of us who don't have a bad as flat as yours (or who have a gantry that sags a little) allows least-squares "averaging" to be done, so that the result is less sensitive to deviations from flatness at particular points.
                          deckingmanundefined 1 Reply Last reply Reply Quote 2
                          • fcwiltundefined
                            fcwilt @sinned6915
                            My granite surface plate is only 300mm by 300mm - not really big enough for any but my smallest bed.
                            I just checked my heightmaps and they all show mostly a gentle curve from "left to right" but basically flat from "front to back".
                            So you observation about a "cylinder" is consistent with what I see here.
                              deckingman @dc42
                              @dc42 said in Suggestion for a simpler, less error prone, way of bed levelling:
                              I think that's the nub of it. If you probe more than two points in one direction (which ideally should be close to the extremities of the bed), then you are no longer looking at whether the plate is level, but also trying to compensate for some unknown curvature or flatness. In simple terms, a saucer is level if one can fill it with a fluid and that fluid will not spill over the rim at any one point. For the purpose of levelling (as opposed to flatness compensation), the shape of the indentation and the position of the indentation within the rim, is irrelevant. If the rim is the same height all around, then it's level. Once it's level, then you can worry about whether it's flat but to try and do both at the same time is bound to lead to problems. But I can see I'm flogging a dead horse here so I'll just bugger off.
                                Two comments:
                                1. There would be nothing to stop you probing several points around the rim, and ignoring the interior.
                                2. I think the more realistic case for us is that the rim isn't level. As we're not actually trying to contain a liquid, I think it's reasonable to probe several points uniformly distributed around the rim, and do a least-squares fit to define a plane that deviates from the probed points on the rim as little as possible.
                                It's fair to say that if RRF did not already have a least-squares solver in it, I would have implemented a simpler system that constrains you to probe the same number of points as you have bed mounting points. Having the least squares solver already allowed me to implement a more general scheme, that is equivalent to the simpler scheme when you have that number of probe points.
                                Do you find the present scheme unsatisfactory, and if so, in what way? Your title suggests that the current method is error-prone: in what way?
                                • mrehorstdmdundefined
                                  mrehorstdmd
                                  I have a few observations that may be relevant.
                                  1. cast tooling plate is manufactured in large sheets (like 8' x 4' or larger). It is milled in that size and the flatness spec is applied over the entire sheet. Smaller pieces, cut from those large sheets, like we use for bed plates, will be flatter than the limits that apply to the large sheet. I have used 300x300 mm cast tooling plate beds, 1/4" and 8mm thick, in 4 printers and found it always flat enough to print edge to edge in a 0.2 mm layer - never tried thinner as I never had a reason to do so.
                                  2. I have seen many recently designed printers using cast tooling plate beds with heaters that are smaller than the bed plate by a wide margin. I don't know why they do that- maybe to save a few $ on the heater. I suspect that leads to bowing when the plate is heated because the cooler edges won't expand as much as the central portion of the plate. Probing multiple points and doing a least squares fit would help to minimize the variation in the first layer thickness on a bowed plate. I "probe" nine points with a piece of paper between the nozzle and bed when I use the manual bed leveling assistant, typically about once a year when I check the tram of the bed.
                                  3. I use 300x300 mm heaters on 300x300 mm bed plates. Here is a thermal image of the uninsulated 8mm plate in my corexy machine:
                                  The minimum point in the UL corner is about 7C below the center of the bed. If there were a 20 or 30 mm unheated margin around the plate what would the temperature difference be? How much would the plate bow? Maybe there's a simulator on the web somewhere that could provide an estimate.
                                  1. I have seen forum posts in which people claim their cast tooling plate beds were bent in shipping. I have never seen any mention of the truck tire tracks on the package that would be surely be there if the bed really were bent in shipping.
                                  • fcwiltundefined
                                    fcwilt @mrehorstdmd
                                    @mrehorstdmd
                                    Some of my cast tool plates are nice and flat, others not so much.
                                    The first four I got were good, got unlucky on the last one.
                                    But I still have to use Mesh Bed Compensation.
                                    I don't yet understand how others can manage without it.
                                      deckingman @dc42
                                      Not at all. As I said in my OP, it matters not one jot to me because I don't have a need to use it.
                                      I was going to bugger off but seeing as you asked, a quick gander at these forums will reveal a number of threads related to bed levelling in it's various guises where people seem to have misinterpreted the instructions or misunderstood how it works. Another quick gander at M671 shows a list of pre-requisites that people might get wrong. For example the number and position of lead screw/attachment points/adjustment screw points. All of which have to be with respect to an origin which people might get wrong. As long as one probes in a line parallel with a line passing through the attachment points (and why would one do otherwise?) then none of this matters - the only parameter that matters is the distance between attachment points in order to calculate the length of the line and therefore it's slope.
                                      I would also suggest that, the recommendation to probe near the lead screw positions is incorrect. For reasons that I detailed in this video tat I made over a year ago, https://www.youtube.com/watch?v=H9O1r46Izn8 with a 3 point system, a slope in the Y direction will affect the readings taken in the X direction. Whereas probing the X axis along a line that runs through the centre of the Y axis will negate that error. Likewise probing along the Y axis should be done on a line on the centre of the X axis.
                                      That video also explains how one can end up with a level bed, but it's not necessarily level with the XY gantry because there might be a some twist or misalignment of the frame. You could, if you felt like, incorporate a check whereby after levelling the bed across the centre, you then check all 4 corners. This will show up any misalignment although it could be due to either a twisted build plate, or (more likely) a misaligned or twisted frame. But I appreciate that most people will choose to use mesh compensation rather than correct the mechanical error.
                                      But hey, it was just a suggestion - wish I hadn't wasted my time..........
                                      A Former User? dc42undefined 2 Replies Last reply Reply Quote 0
                                      • appjawsundefined
                                        appjaws
                                        @deckingman you have not wasted your time, I am sure a large number of users will have appreciated your detailed explanation.
                                        appjaws - Core XYUV Duet Ethernet Duex5
                                        firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                        Ormerod 1-converted to laser engraver, Duet wifi
                                        OpenSCAD version 2024.03.18
                                        Simplify3D 5.1.2
                                          mrehorstdmd @fcwilt
                                          @fcwilt Mesh compensation can correct if the bed plate/print surface bows when heated, and/or the Y axis guide rails are not coplanar, and/or the print surface is not uniform thickness.
                                          I ensured coplanar Y axis rails by mounting them on tooling plate (two pieces cut from one piece, green in the image below) that is in turn mounted on a rectangular frame of 4040 t-slot.
                                          I use 0.7 mm PEI with a layer of adhesive for the print surface. I have no idea what the thickness specs are for either the PEI or the adhesive, but it has been good enough in the 4 printers I have used it on.
                                            A Former User @deckingman
                                            This post is deleted!
