    Resetting the 3d printer while printing
    1.1k
    • Kevvvundefined
      Kevvv @Phaedrux
      @phaedrux
      ![alt text](f1b9dc48-ed44-4c8c-8307-7f6ce84b993d-1654366464662.jpg image url)
      ![alt text](e746f01d-e0ff-4ea9-8fe4-9470726b9828-1654366464667.jpg image url)
      ![alt text](db118dd6-5193-4c8d-9c85-4ca1fc636086-1654366464672.jpg image url)
        Can you remove the SD card from the Duet and power it on? Does the heated bed still heat up immediately?
        Kevvvundefined 1 Reply Last reply Reply Quote 0
        • Kevvvundefined
          Kevvv @Phaedrux
          @phaedrux
          ![alt text](1f3d7596-4e0a-4040-8e5d-a89a7fee8cc9-1654368115509.jpg image url)
          Led is always on.
            I think the mosfet has failed in the on position. If this is the case a warranty replacement would be required. When and where did you purchase the Duet3?
            • Kevvvundefined
              Kevvv @Phaedrux
              @phaedrux
              I bought it on August 4, 2020, in the Hobbystore store in Poland (he is your distributor).
                When did the bed heating issue begin? Did it ever work correctly?
                • Kevvvundefined
                  Kevvv @Phaedrux
                  @phaedrux
                  I connected the bed heater a few days ago but this is my first attempt with this heater and I noticed that the diode is on all the time.
                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                      dc42 administrators @Kevvv
                      @kevvv before you return your board, please disconnect the bed heater from it, then power up and check whether the bed heater LED still turns on immediately. If it does then return the board for replacement. If it doesn't then you have a short circuit between your bed heater and ground.
                      • Kevvvundefined
                        Kevvv @dc42
                        ![alt text](7aed126e-d31b-44d4-b71e-1d12d5b36121-1654451468209.jpg image url)
                        Led is always on.
