    Unable to get on DWC
    Firmware installation
    346
      jay_s_uk @darbyad85
      @darbyad85 did you update anything yesterday?
      • darbyad85undefined
        darbyad85
        @jay_s_uk I've updated the firmware and it doesn't seem to have solved the problem. M552 61 is confirming I am connected and the right IP address for DWC but all I get is a blue bar saying 'Connecting...' with no connection
          jay_s_uk @darbyad85
          @darbyad85 did you update DWC at the same time? thats probably the issue
            darbyad85
            I updated the wifi and rap/rep at the same time, is there also an update for the DWC
            I was on version 2.03 but used the Duet 2 and 3 firmware 3.0 as advised - is there something else i have missed?
            Thanks
              jay_s_uk @darbyad85
              @darbyad85 do you know what firmware version you ended up with? Was it RRF 3.0 or 3.4.1?
                darbyad85
                I have 3.0 i didnt upgrade to 3.4.1
                I have found the DWC zip file that is part of 3.0 - can i just install the same way i did to get to version 3.0 or do i delete and install all together?
                  jay_s_uk @darbyad85
                  @darbyad85 you can just delete the contents of the www folder and replace it with the contents of the dwc zip file
                    darbyad85
                    thank you, do I need to perform M997 S0?
                      jay_s_uk @darbyad85
                      @darbyad85 no, DWC files are just held on the SD card. that should get you up and running
                        darbyad85
                        thanks so much - I am indeed up and running!
                          Now that you're at 3.0 you should probably update to 3.4.1
                          3.0 was a very early release, much has changed.
                          Updating now is as simple as uploading a single zip file to the system tab in DWC. Do not decompress it first.
                          https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.1/Duet2and3Firmware-3.4.1.zip
                          And if you're coming from 2.03 you should probably generate a new config file set.
                          https://configtool.reprapfirmware.org/Start
