    Only two of three towers are homing
    671
    • Velviaundefined
      Velvia
      When I use the "Home all" command, only two of my towers are homing. All towers move just fine when I use Z +/- movements. Any ideas?
      Homegrown, grass fed and organically built 350mm delta
        You're going to have to be a lot more specific. I assume this is a delta as you're talking about towers.
        Which two towers?
        Can you post your config.g and your homedelta.g files?
        Velviaundefined 1 Reply Last reply Reply Quote 0
        • Velviaundefined
          Velvia @Phaedrux
          @phaedrux Yes, a delta.homedelta.g config.g
          Tower Z and Y home just fine, but tower X does nothing. The stepper gets charged though.
          Edit, didn't know how to imbed the code:
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"Duet 3"                                     ; set printer name
          M665 R172.5 L303 B172 H355                         ; Set delta radius, diagonal rod length, printable radius and homed height
          M666 X0 Y0 Z0                                      ; put your endstop adjustments here, or let auto calibration find them
          M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
          M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
          M569 P0.2 S0                                       ; physical drive 0.2 goes forwards
          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z80.00 E690.00                   ; set steps per mm
          M566 X1000.00 Y1000.00 Z1000.00 E600.00            ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E6000.00        ; set maximum speeds (mm/min)
          M201 X1000.00 Y1000.00 Z1000.00 E10000.00          ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E850 I30                       ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 Z0 S1                                         ; set minimum Z
          M574 X2 S1 P"io1.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io1.in
          M574 Y2 S1 P"io2.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io2.in
          M574 Z2 S1 P"io3.in"                               ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io3.in
          homedelta
          ; homedelta.g
          ; called to home all towers on a delta printer
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 15 2022 16:15:51 GMT+0200 (Central European Summer Time)
          G91                       ; relative positioning
          ;*** Slow homing has been configured. Change F180 to F1800 below when your configuration is working
          G1 H1 X375 Y375 Z375 F360 ; move all towers to the high end stopping at the endstops (first pass)
          G1 H2 X-5 Y-5 Z-5 F1800   ; go down a few mm
          ;*** Slow homing has been configured. Change F180 to F360 below when your configuration is working
          G1 H1 X10 Y10 Z10 F180    ; move all towers up once more (second pass)
          G1 Z-5 F6000              ; move down a few mm so that the nozzle can be centred
          G90                       ; absolute positioning
          G1 X0 Y0 F6000            ; move X+Y to the centre
            Can you send M122 and M98 P"config.g" in the gcode console and copy paste the results here?
            @velvia said in Only two of three towers are homing:
            How exactly are you testing movement? What commands are sent or buttons used? How are you allowing movement if homing isn't succeeding?
            • Velviaundefined
              Velvia @Phaedrux
              @phaedrux said in Only two of three towers are homing:
              I use the Z buttons here. Then everything moves just fine. When I press "Home all", only Z and Y moves and homed correctly, X does nothing.
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
              Board ID: 08DJM-9P63L-DJ3S0-7JKF0-3S86T-TAJR8
              Used output buffers: 1 of 40 (10 max)
              Static ram: 149788
              Dynamic ram: 61988 of which 36 recycled
              Never used RAM 147020, free system stack 188 words
              Tasks: Linux(ready,79) HEAT(blocked,173) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,50) MAIN(running,1203) IDLE(ready,19)
              Owned mutexes: HTTP(MAIN)
              Last reset 01:39:23 ago, cause: software
              Last software reset at 2022-06-17 18:39, reason: User, none spinning, available RAM 146980, slot 1
              Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
              Error status: 0x00
              Aux0 errors 0,0,0
              Aux1 errors 0,0,0
              MCU temperature: min 35.1, current 36.3, max 37.6
              Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
              Driver 0: position 48328, standstill, reads 31221, writes 14 timeouts 0, SG min/max 0/0
              Driver 1: position 48328, standstill, reads 31221, writes 14 timeouts 0, SG min/max 0/0
              Driver 2: position 48328, standstill, reads 31221, writes 14 timeouts 0, SG min/max 0/0
              Driver 3: position 0, standstill, reads 31221, writes 14 timeouts 0, SG min/max 0/0
              Driver 4: position 0, standstill, reads 31224, writes 11 timeouts 0, SG min/max 0/0
              Driver 5: position 0, standstill, reads 31225, writes 11 timeouts 0, SG min/max 0/0
              Date/time: 2022-06-17 20:18:46
              Slowest loop: 0.99ms; fastest: 0.04ms
              === Storage ===
              Free file entries: 10
              DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              === MainDDARing ===
              === AuxDDARing ===
              Segments left: 0
              Movement lock held by null
              Telnet is idle in state(s) 0
              File is idle in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              Code queue is empty.
              === CAN ===
              Messages queued 23845, send timeouts 53662, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
              === SBC interface ===
              State: 4, failed transfers: 1
              Last transfer: 1ms ago
              RX/TX seq numbers: 13918/13918
              SPI underruns 0, overruns 0
              Number of disconnects: 0, IAP RAM available 0x2c8a8
              Buffer RX/TX: 0/0-0
              === Duet Control Server ===
              Duet Control Server v3.3.0
              Code buffer space: 4096
              Configured SPI speed: 8000000Hz
              Full transfers per second: 35.31, max wait times: 16.7ms/0.0ms
              Codes per second: 0.01
              Maximum length of RX/TX data transfers: 2620/960
              M98 P"config.g" only did this
                Phaedrux Moderator @Velvia
                It looks like your DSF version and firmware version have gone out of sync.
                Can you try sending sudo apt update and sudo apt upgrade on the pi and then run M122 again and post it here?
                Everything should be on 3.4.1 at this point.
                • Velviaundefined
                  Velvia @Phaedrux
                  I already did this prior to all this. I'll do it again.
                    Do you get any errors?
                    • Velviaundefined
                      Velvia @Phaedrux
                      Two errors in the beginning of "sudo apt upgrade", then everything else is fine.
                        Don't leave me in suspense. What are the errors?
                        • Velviaundefined
                          Velvia @Phaedrux
                          I don't remember. Was many hours ago, restarted the printer after that. Looked like it just failed to fetch the two first things. I'll try again tomorrow. Thanks a lot for the help so far!
                            You may want to download a fresh copy of the Duet Pi image and flash a new SD card. You can backup your printer config files and restore them. That may be easier than trying to get things back in sync on the current install.
                            Velviaundefined 1 Reply Last reply Reply Quote 1
                            • Velviaundefined
                              Velvia @Phaedrux
                              Thank you, I'll try that!
                              • Velviaundefined
                                Velvia @Velvia
                                Flashed new image, updated and upgraded, no errors. Problem persists. M122 gives this:
                                M122
                                Static ram: 149788
                                Never used RAM 147020, free system stack 200 words
                                Tasks: Linux(ready,81) HEAT(blocked,300) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,53) MAIN(running,1203) IDLE(ready,19)
                                Last reset 00:00:45 ago, cause: power up
                                Last software reset at 2022-06-17 22:28, reason: User, none spinning, available RAM 147848, slot 2
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU temperature: min 26.6, current 32.9, max 33.0
                                Supply voltage: min 23.9, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: position 48328, standstill, reads 58518, writes 14 timeouts 0, SG min/max 0/0
                                Driver 1: position 48328, standstill, reads 58518, writes 14 timeouts 0, SG min/max 0/0
                                Driver 2: position 48328, standstill, reads 58518, writes 14 timeouts 0, SG min/max 0/0
                                Driver 3: position 0, standstill, reads 58519, writes 14 timeouts 0, SG min/max 0/0
                                Driver 4: position 0, standstill, reads 58522, writes 11 timeouts 0, SG min/max 0/0
                                Driver 5: position 0, standstill, reads 58522, writes 11 timeouts 0, SG min/max 0/0
                                Date/time: 2022-06-17 23:55:38
                                Slowest loop: 0.46ms; fastest: 0.04ms
                                === Storage ===
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                === CAN ===
                                Messages queued 83, send timeouts 307, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48
                                RX/TX seq numbers: 57893/57893
                                Buffer RX/TX: 0/0-0
                                Duet Control Server v3.4.1
                                Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                Full transfers per second: 2642.73, max time between full transfers: 63.1ms, max pin wait times: 14.7ms/34.2ms
                                Codes per second: 2.78
                                Maximum length of RX/TX data transfers: 2732/544
                                  3.2.2
                                  Your firmware still isn't updating.
                                  Can you try sending M997 in the gcode console to manually initiate a flash of the firmware? Then check your firmware version again with M115. It should be 3.4.1 to match the version of DSF on the Pi.
                                  • Velviaundefined
                                    Velvia @Phaedrux
                                    @Phaedrux
                                    That worked, but problem persists:
                                    M115
                                    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.4.1 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2022-06-01 21:09:12
                                    Velviaundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                    • Velviaundefined
                                      Velvia @Velvia
                                      @velvia
                                      M122:
                                      M122
                                      RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode)
                                      Used output buffers: 1 of 40 (12 max)
                                      Static ram: 151000
                                      Dynamic ram: 64296 of which 96 recycled
                                      Never used RAM 135208, free system stack 154 words
                                      Tasks: SBC(ready,0.5%,448) HEAT(notifyWait,0.0%,321) Move(notifyWait,0.0%,267) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.0%,333) TMC(notifyWait,7.7%,92) MAIN(running,91.3%,1231) IDLE(ready,0.4%,30), total 100.0%
                                      Last reset 00:04:15 ago, cause: software
                                      Last software reset at 2022-06-18 00:59, reason: User, none spinning, available RAM 146980, slot 2
                                      Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      Step timer max interval 187
                                      MCU temperature: min 33.2, current 34.9, max 35.4
                                      Events: 0 queued, 0 completed
                                      Driver 0: standstill, SG min 0, mspos 776, reads 49468, writes 19 timeouts 0
                                      Driver 1: standstill, SG min 0, mspos 456, reads 49468, writes 19 timeouts 0
                                      Driver 2: standstill, SG min 0, mspos 968, reads 49468, writes 19 timeouts 0
                                      Driver 3: standstill, SG min 0, mspos 8, reads 49473, writes 14 timeouts 0
                                      Driver 4: standstill, SG min 0, mspos 8, reads 49476, writes 11 timeouts 0
                                      Driver 5: standstill, SG min 0, mspos 8, reads 49477, writes 11 timeouts 0
                                      Date/time: 2022-06-18 01:08:30
                                      Slowest loop: 53.25ms; fastest: 0.05ms
                                      === Storage ===
                                      DMs created 125, segments created 3, maxWait 40471ms, bed compensation in use: none, comp offset 0.000
                                      === MainDDARing ===
                                      Scheduled moves 5, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                      === AuxDDARing ===
                                      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                      Segments left: 0
                                      Code queue is empty
                                      === CAN ===
                                      Messages queued 2272, received 0, lost 0, boc 0
                                      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 1277/0/0
                                      Tx timeouts 0,0,1276,0,0,994 last cancelled message type 30 dest 127
                                      Transfer state: 5, failed transfers: 0, checksum errors: 0
                                      RX/TX seq numbers: 10160/10160
                                      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880
                                      Buffer RX/TX: 0/0-0, open files: 0
                                      Full transfers per second: 40.42, max time between full transfers: 84.5ms, max pin wait times: 54.0ms/14.7ms
                                      Codes per second: 0.29
                                      Maximum length of RX/TX data transfers: 3032/864
                                        Well it was worth a shot and likely fixed other future issues as having a mismatch like that will cause havok eventually.
                                        The only thing that stands out as odd to me is the motor direction config for X Y Z motors has X Y going forwards and Z going backwards.
                                        Which towers are not moving correctly during homing?
                                        Take a look at this test please: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta#testing-the-motors-and-endstops-individually
                                        • Velviaundefined
                                          Velvia @Phaedrux
                                          X
                                          This worked just fine. All towers moved individually as they should.
                                          Velviaundefined dc42undefined 2 Replies Last reply Reply Quote 0
                                          • Velviaundefined
                                            Velvia @Velvia
                                            @velvia
                                            That makes this so weird.
                                            H1 terminate the move when the endstop switch is triggered and set the axis position to the axis limit defined by M208. On delta printers, H1 also selects individual motor mode as for H2. Normally used with relative motor coordinates (see G91).
                                            homedelta.g
                                            ; homedelta.g
