    How to Wire an External MOSFET on a Mini 5 Plus
    797
    • random_task_1undefined
      random_task_1 @jay_s_uk
      @jay_s_uk
      Ok, thanks for the reply.
      Just to make sure I understand what you said there.
      I would put a + and - wire from my PSU to the Duet Mini 5 Power In terminals.
      Run a + and a - wire from the Duet Mini 5 BED OUT (OUT_0) to the + and - INPUT side of the MOSFET.
      Run a + and - from the MOSFET BED OUT to the normal input on the heated bed.
      Run the JST 2 wire connector from the Duet Mini 5 OUT 1 terminal to the MOSFET Signal connector.
        jay_s_uk @random_task_1
        @random_task_1 power in to duet mini for the bed power input.
        The 2 wire JST would go from bed out to the MOSFET.
        random_task_1undefined 2 Replies Last reply Reply Quote 0
          @jay_s_uk
          ok,
          I think I understand now thank you. will give that a try when I get back to the shop
            @jay_s_uk
            just to make sure I understand correctly, you are saying it is fine to use the 20 or 22 gauge wire and run from the bed outputs on the duet to the signal input on my mosfet? I have it connected that way but want to make sure I'm not about to fry something.
            • fcwiltundefined
              fcwilt @random_task_1
              @random_task_1
              I suggest you purchase a suitably rated SSR (solid state relay) . They are designed for this sort of thing are are going to be safer than just a simple MOSFET.
              random_task_1undefined 1 Reply Last reply Reply Quote 0
                random_task_1 @fcwilt
                @fcwilt I'm not opposed to getting an SSR, any suggestions on which one to get? the Duet documents list two options but none are available any longer.
                  @random_task_1 large MOSFETs are fine.
                  Wire it like this
                  Just use out0 in place of where it wires to the ramps board. Make sure you provide 24v power to the power inputs for out0
                  random_task_1undefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                    @jay_s_uk ok, thank you for that clarification.
                    • fcwiltundefined
                      fcwilt @jay_s_uk
                      @jay_s_uk
                      IF they are optically isolated.
                      I would still suggest a SSR as nothing is exposed.
                      Amazon has these in stock:
                      Crydom D2425 SSR, Panel Mount, 280Vac, 32Vdc, 25A
                      • Dad003undefined
                        Dad003
                        just be aware that some of these mossfet get really hot , i went throw a few of these before , hard to get a quality one , now i just use fast switching SSR . and it solved my problem .
                        • jumpedwithbothfeetundefined jumpedwithbothfeet referenced this topic
