    My config.g was reset
    • Velviaundefined
      Velvia
      My config.g file is suddenly empty? What happened? I just reset my printer, and now all my settings are gone.
      ; Configuration file for Duet 3 (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 15 2022 16:15:51 GMT+0200 (Central European Summer Time)
      M575 P1 S1 B57600                                  ; enable support for PanelDue
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Duet 3"                                     ; set printer name
      M665 R272 L503 B173 H355                           ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0.618 Y-0.625 Z0.007 A0.08 B0.05             ; put your endstop adjustments here, or let auto calibration find them
      M579 X1.0 Y1.0 Z1.0								   ; XYZ scaling factor
      M569 P0.0 S1                                       ; physical drive 0.0 goes forwards X
      M569 P0.1 S1
      This is all that is left
      Homegrown, grass fed and organically built 350mm delta
      • fcwiltundefined
        fcwilt @Velvia
        @velvia
        You should have a config.bak file.
        If so check it's contents.
        Velviaundefined 1 Reply Last reply Reply Quote 0
        • Velviaundefined
          Velvia @fcwilt
          @fcwilt I copied everything from there, to config.g, but now the same happend to the bak file. Copied everything to a txt file for now.
          • fcwiltundefined
            fcwilt @Velvia
            @velvia
            Hit the "reload" or "refresh" button on your browser.
            See if that helps.
              Did you edit and save the config.g file before the reset?
              Firmware version and board type?
              • Velviaundefined
                Velvia @Phaedrux
                @phaedrux I save every time I make an edit. Duet 3 6HC, 3.4.1
                  droftarts administrators @Velvia
                  @velvia The config.g file disappearing on save is an annoying and infrequent bug that we have been trying to chase down for a while, though have made progress on recently. See @chrishamm's post in this thread for an updated version of the firmware that may fix this issue: https://forum.duet3d.com/post/285788
