    Problems with Duet 3 Mini 5+ WiFi
    3.8k
      Did you try that lower speed command?
      Unforgivenllundefined 1 Reply Last reply Reply Quote 0
      • Unforgivenllundefined
        Unforgivenll @Phaedrux
        @phaedrux I did try that and it didn't work. I tried my old Tevo motor at 850ma. It worked fine. The $200 worth of Moons motors are literally days old. I did see a discussion somewhere where they might have an incompatibility with the steppers. I think it was Stealth Chop in particular. I have no idea how to test that. I'm not an expert by any means but I generally make my way through electronics projects just fine. This is maybe the 3rd or fourth time asking for help ever. I'm just not having much positive movement with this Duet build. I'm not blaming anything, or anyone. It's probably my fault. Just putting it out there.
          I believe they should be in spread cycle by default instead of stealthchop but we can force it by adding D2 to the M569 command for X Y Z.
          M569 P0.0 S1                                                 ; physical drive 0.0 goes forwards
          M569 P0.1 S1                                                 ; physical drive 0.1 goes forwards
          M569 P0.2 S1                                                 ; physical drive 0.2 goes forwards
          Add the D2 after the S1
          Unforgivenllundefined 2 Replies Last reply Reply Quote 0
            @phaedrux Unfortunately it didn't change anything.
              @phaedrux I'm going to use my old motors for the time being. They are working just fine. I have X and Y wired up without any issues. If you don't mind, could you help me with the dual z? I want to add the second motor to E0. I read the documentation a few times and I'm not sure if I'm understanding it correctly. My full build area is 310x370.
              Again, I really appreciate your help. Thank you very much.
                Yeah those Moons motors just aren't the right specs for a 3d printer. Inductance is too high. Not sure what else to say about that.
                To add a second driver to the Z axis you need to tell it that the Z axis has 2 drivers. This is done in the M584 command where the drivers are mapped to the axis.
                The mini 5 doesn't have a driver labeled as E0 as far as I'm aware, so assuming you mean driver 3 on the mainboard.
                M584 X0.0 Y0.1 Z0.2 E121.0
                Would become
                M584 X0.0 Y0.1 Z0.2:0.3 E121.0
                Now when a G1 Z command is sent, both Z motors will act as one.
                Now that you have dual z axis you can do fancier things like this: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
                  @phaedrux Thank you. I don't know why I thought it was labeled EO. When looking at the samples on the page you linked I'm not sure how that gets setup. I'm sorry I guess I'm a little slow here.
                    You mean the auto leveling? Did you see the examples?
                    https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling#examples
                    You tell the firmware which drivers are in each axis.
                    You tell the firmware where your lead screws approximately are.
                    Then you setup bed.g to probe near those lead screws and it makes the correction.
                      @phaedrux I'm not understanding exactly how to figure out the variables given the example. G208 and G30 especially. I see the explanation and it makes sense, but looking at the measurements on G30 don't make any sense to me.
                      • fcwiltundefined
                        fcwilt @Unforgivenll
                        @unforgivenll said in Problems with Duet 3 Mini 5+ WiFi:
                        Could you elaborate a bit on what it is you don't understand?
                          Well your M208 is already set for your bedsize, so that doesn't change.
                          The points for the G30 in bed.g are going to depend on where your leadscrews are. If it's a cartesian it's going to be a point on the left and right side of the bed where the probe can reach.
                            Unforgivenll @Unforgivenll
                            @unforgivenll Okay, is this what it should look like?
                            M584 X0.0 Y0.1 Z0.2:0.3 E121.0E1
                            M671 X-25:335 Y0:0 S0.5 ; leadscrews at left (connected to Z) and right
                            G28 ; home
                            G30 P0 X25 Y155 Z-99999 ; probe near a leadscrew, half way along Y axis
                            G30 P1 X285 Y155 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                            Phaedruxundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                              Phaedrux Moderator @Unforgivenll
                              The E1 at the end isn't right.
                              Y0:0 is only correct if Y0 is the center of the bed and that's also where the lead screws are located. If Y0 is the front of your bed, and the lead screws are in the middle, the Y value would be approximately half your Y max value. Does that make sense? If your Y position in your G30 commands is correct, it should be Y155 as well.
                              • fcwiltundefined
                                G28 ; home
                                Your G30s are probing "near a leadscrew" at Y=155 yet your M671 says they are at Y=0.
                                Usually they are same or similar.
                                  Unforgivenll @fcwilt
                                  bed.g @fcwilt My Y min is actually at the back of my bed. I don't know if that makes a difference. I think I know where this is placed in config.g but I have no idea where it is placed in bed.g. The E1 is a typo, I'm on my phone and was copy/pasting.
                                  So it should be ?
                                  M671 X-25:335 Y155:155 S0.5 ; leadscrews at left (connected to Z) and right
                                  G28 ; home
                                  I asked where to put the new bed config info because there is some there already. Do I keep what's there or do I replace it with the new config?
                                  bed.g
                                  • fcwiltundefined
                                    So it should be ?
                                    G28 ; home
                                    IF your leadscrews line up with the probe when the probe is at Y=155 then then your M671 and G30s are good.
                                      @fcwilt Thank you. I asked where to put the new bed config info because there is some there already. Do I keep what's there or do I replace it with the new config?
                                      bed.g
                                      • fcwiltundefined
                                        bed.g
                                        I like to keep related things together.
                                        So my bed.g file has all the commands needed to level the bed.
                                        Some of the commands in my bed.g are often put in config.g but I don't do that.
                                        The M584 should stay in config.g since it is fundamental to the printer working.
                                        The M671, G28 and the G30s, can all go into bed.g
                                        There should be no G28s or G30s in config.g ever.
                                        And if there is a M671 in config.g, remove it and rely on the one in bed.g
                                          @fcwilt Thank you. Here's my configs again if you want to look at them. I'm working on sensor less homing and setting my Bltouch height from the bed next. It will probably be awhile before you hear from me again as I have to wait for some parts to proceed. I'm sure you won't mind the peace. I appreciate everything.
                                          config.g
                                          bed.g
                                          • fcwiltundefined
                                            config.g
                                            bed.g
                                            In the future if you would copy-and-paste the contents of files using the </> it makes it easier on responders. They don't need to download a file to view.
                                            Each </> tag creates a scrollable region right within your post, as you can see below.
                                            ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
                                            ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 22 2022 17:05:21 GMT-0400 (Eastern Daylight Time)
                                            M575 P1 S1 B57600                                            ; enable support for PanelDue
                                            G90                                                          ; send absolute coordinates...
                                            M83                                                          ; ...but relative extruder moves
                                            M550 P"SLR3DP"                                               ; set printer name
                                            ; Wait a moment for the CAN expansion boards to start
                                            G4 S2
                                            M551 P"554306"                                               ; set password
                                            M552 S1                                                      ; enable network
                                            M586 P0 S1                                                   ; enable HTTP
                                            M586 P1 S0                                                   ; disable FTP
                                            M586 P2 S0                                                   ; disable Telnet
                                            M569 P121.0 S1                                               ; physical drive 121.0 goes forwards
                                            M584 X0.0 Y0.1 Z0.2:0.3 E121.0                               ; set drive mapping
                                            M350 X16 Y16 Z16 E16 I1                                      ; configure microstepping with interpolation
                                            M92 X80.00 Y80.00 Z400.00 E420.00                            ; set steps per mm
                                            M566 X900.00 Y900.00 Z60.00 E120.00                          ; set maximum instantaneous speed changes (mm/min)
                                            M203 X6000.00 Y6000.00 Z180.00 E1200.00                      ; set maximum speeds (mm/min)
                                            M201 X500.00 Y500.00 Z20.00 E250.00                          ; set accelerations (mm/s^2)
                                            M906 X850 Y850 Z850 E390 I30                                 ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S30                                                      ; Set idle timeout
                                            M208 X0 Y0 Z0 S1                                             ; set axis minima
                                            M208 X310 Y370 Z400 S0                                       ; set axis maxima
                                            M574 X1 S3                                                   ; configure sensorless endstop for low end on X
                                            M574 Y1 S3                                                   ; configure sensorless endstop for low end on Y
                                            M574 Z1 S2                                                   ; configure Z-probe endstop for low end on Z
                                            M950 S0 C"121.io0.out"                                       ; create servo pin 0 for BLTouch
                                            M558 P9 C"121.io0.in" H5 F120 T6000                          ; set Z probe type to bltouch and the dive height + speeds
                                            G31 P500 X50 Y-55 Z2.5                                       ; set Z probe trigger value, offset and trigger height
                                            M557 X15:215 Y15:195 S20                                     ; define mesh grid
                                            M308 S0 P"temp0" Y"thermistor" T100000 B4138                 ; configure sensor 0 as thermistor on pin temp0
                                            M950 H0 C"out0" T0                                           ; create bed heater output on out0 and map it to sensor 0
                                            M307 H0 B1 S1.00                                             ; enable bang-bang mode for the bed heater and set PWM limit
                                            M140 H0                                                      ; map heated bed to heater 0
                                            M143 H0 S120                                                 ; set temperature limit for heater 0 to 120C
                                            M308 S1 P"121.temp0" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin 121.temp0
                                            M950 H1 C"121.out0" T1                                       ; create nozzle heater output on 121.out0 and map it to sensor 1
                                            M307 H1 B0 S1.00                                             ; disable bang-bang mode for heater  and set PWM limit
                                            M143 H1 S280                                                 ; set temperature limit for heater 1 to 280C
                                            M950 F0 C"121.out1" Q500                                     ; create fan 0 on pin 121.out1 and set its frequency
                                            M106 P0 S0 H-1                                               ; set fan 0 value. Thermostatic control is turned off
                                            M950 F1 C"121.out2" Q500                                     ; create fan 1 on pin 121.out2 and set its frequency
                                            M106 P1 S1 H1 T45                                            ; set fan 1 value. Thermostatic control is turned on
                                            M563 P0 D0 H1 F0                                             ; define tool 0
                                            G10 P0 X0 Y0 Z0                                              ; set tool 0 axis offsets
                                            G10 P0 R0 S0                                                 ; set initial tool 0 active and standby temperatures to 0C
                                            ; bed.g
                                            G29  ; probe the bed and enable compensation
                                            G28 ; home
                                            Now as to your bed.g file:
                                            You have a G29 which some folks do include but bed.g is really meant to handle bed leveling. G29 is related to Mesh Bed Compensation - something else entirely.
                                            G30 executes bed.g and should level the bed.
                                            G29 executes mesh.g, if found, and it should create the height map needed for Mesh Bed Compensation.
                                            And creating the height map should only happen after leveling the bed. Also prior to creating or loading a height map you need to set the Z=0 Datum using a single G30 at your chosen reference point. Many folks use the first point of the height map mesh, some folks (like me) use the center of the bed.
                                            As I mentioned I like to keep related things together so my mesh.g file has only the commands needed to create the height map.
                                            Unforgivenllundefined 1 Reply Last reply Reply Quote 1
