Cannot get triggers to work with buttons
384
    mattyo
    I have recently moved across from a duet 2 to a duet 3 mini 5+.
    I am trying to setup my hardware buttons to trigger home etc. All were working on the duet 2, but I can't get them to work on the mini 5.
    I know it must be me doing something wrong but I can't work out what. I have tried different pins and even just hooking up a end switch to grnd and in pin.
    I am currently trying to use io6 but could use other. I have the reset working. So makes me think I am doing something wrong in the Config.g
    Any help would be much appreciated.
    Thanks Matt.
    Revised with the correct config.
    Down the bottom ;buttons
    ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 01 2022 15:23:52 GMT+1000 (Australian Eastern Standard Time)
    M550 P"BLV Rev" ; set printer name
    M669 K1 ; select CoreXY mode
    M918 P1 E4 F2000000 ; configure direct-connect display
    G4 S2 ; wait for expansion boards to start
    M575 P2 S0 B57600 ;BLV Neopixels
    M150 X1 Q3000000 ; set LED type to NeoPixel and set SPI frequency to 3MHz
    M150 R255 P128 S5 F1 ; set first 20 LEDs to red, half brightness, more commands for the strip follow
    M150 U255 B255 P255 S20 ; set next 20 LEDs to cyan, full brightness, finished programming strip
    ;M551 P"" ; set password
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P121.0 S1 ; physical drive 0.4 goes forwards
    M584 X0.0 Y0.1 Z0.2:0.4 E121.0 ; set drive mapping
    M671 X-40:385 Y0:0 S4 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
    M208 X0:345 Y345:0 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
    M92 X200.00 Y200.00 Z400.00 E397 ; set steps per mm
    M566 X900.00 Y900.00 Z25.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X20000.00 Y20000.00 Z600.00 E2000.00 ; set maximum speeds (mm/min)
    M201 X5000.00 Y5000.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X1600 Y1600 Z1600 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-13 Y-15 Z0 S1 ; set axis minima
    M208 X333 Y332 Z435 S0 ; set axis maxima
    M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
    M574 Y2 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io5.in
    ; Filament Runout
    M591 D0 P3 C"121.io_1" S1 ; simple sensor (high signal when filament present) connected to IO_4 for drive 0, enabled
    M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
    M558 P9 C"121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-14.00 Y54 Z1.55 ; set Z probe trigger value, offset and trigger height
    M557 X40:340 Y30:320 S80 ; define mesh grid
    M308 S0 P"temp2" Y"thermistor" T100000 B3950
    M307 H1 R5.072 K1.366:0.119 D2.65 E1.35 S1.00 B0 V23.9 ; enable bang-bang mode for the bed heater and set PWM limit
    M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin temp0
    M950 H1 C"121.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M143 H1 S300 ; set temperature limit for heater 1 to 280C
    M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
    M106 P0 C"Hotend" S1 H1 T45 ; set fan 0 name and value. Thermostatic control is turned off
    M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
    M106 P1 C"PartFan" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
    ; Buttons
    M950 J1 C"!io6.in" ; io6.in pin, inverted
    M581 E1 S0 T3 R0 ; Home All - trigger3.g
    undefined undefined 3 Replies Last reply 26 Jun 2022, 09:11 Reply Quote 0
      fcwilt @mattyo
      This post is deleted!
        fcwilt @mattyo
        undefined 1 Reply Last reply 26 Jun 2022, 09:53 Reply Quote 0
          droftarts administrators @mattyo
          @mattyo your Endstop and Zprobe sections still refer to Duet 2 pin names. See https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#endstops
          Can’t see anywhere you have defined a pin as I/O with M950, or set up triggers with M581. But maybe you don’t quite mean that? See https://docs.duet3d.com/en/User_manual/Tuning/Triggers
          undefined 1 Reply Last reply 26 Jun 2022, 09:45 Reply Quote 0
            mattyo @droftarts
            @droftarts
            Sorry I am an idiot I posted the old config from my duet2. That I had on the desktop. I will update. What a fool.
              mattyo @fcwilt
              @fcwilt @droftarts
              Revised. Sorry for the cconfusion.
              undefined 1 Reply Last reply 26 Jun 2022, 10:17 Reply Quote 0
                @mattyo
                M581 E1 S0 T3 R0
                E1 is the RRF2 assignment for the E1 endstop connection for Duet 2. Change it to P1, to refer to the trigger you created with M950.
                undefined 1 Reply Last reply 26 Jun 2022, 10:37 Reply Quote 0
                  mattyo @droftarts
                  @droftarts
                  Ok I thought I tried that. But will try again.
                  I got that from the example code on the wiki.
                  ; Input/Output
                  M950 J1 C"!io1.in" ; Input 1 uses io1.in pin, inverted
                  M581 P1 S0 T1 R1 ; Pause - built-in, no trigger.g needed
                  M950 J2 C"!io1.out" ; Input 2 uses io1.out pin, inverted
                  M581 E3 S0 T2 R0 ; ATX On - trigger2.g
                  M950 J3 C"!io2.in" ; Input 3 uses io2.in pin, inverted
                  M581 E4 S0 T3 R0 ; Home All - trigger3.g
                  M950 J4 C"!io2.out" ; Input 4 uses io2.out pin, inverted
                  M581 E5 S0 T4 R0 ; Disable Steppers - trigger4.g
                  undefined 1 Reply Last reply 26 Jun 2022, 11:08 Reply Quote 0
                    @mattyo Oh! That code is wrong! I’ll update it when I get the chance. The first one is right, but the others are RRF2 format. Thanks for pointing this out.
                    Edit: documentation updated.
                    undefined 1 Reply Last reply 27 Jun 2022, 00:39 Reply Quote 1
                      mattyo @droftarts
                      @droftarts Thanks very much. That sorted it.
                      • undefined mattyo has marked this topic as solved 27 Jun 2022, 00:39
                      6 out of 10
