I could use some help
@droftarts Since my bed on the Y axis was behaving, I decided to change the X-motor's rotation to REVERSED also. When I tested it, that didn't go well the first time. I thought because I reversed the green and white endstop connector at the same time, that may have had something to do with the print head's back-and-forth behavior.
So I left the X-motor reversed, and changed the endstop wiring back. Now, GRN is white, and i05.in is green. Because of that, the x-motor's behaving. It appears that it's limited movement to the left (where the endstop is), has to do with where the board thinks the left of the bed is.
Can you tell me, once again, HOW to tell my board where the LEFT ENDSTOP for the X-AXIS is?
I'll assume that the process is the same for the Y and Z axis, and go from there?
Mac
@droftarts Because the X, Y, and Z motors are seem to be happy being reversed, my assumption is A) the wiring to the main connectors is backwards, and B) I need to change the EXTRUDER motor to REVERSED as well?
@droftarts So, I just switched to Console, and there's this message: 6/26/2022, 8:23.46 AM / Event / G28 X (new line) Driver 0.2 warning: phase A may be disconnected, phase B may be disconnected
Lovely. That means the Y-axis motor has failed, right?
Mac
@droftarts false alarm, the Y motor's working, but it's stopping way short of the front of the printer. So it's doing what the X motor is doing. There's a clue in that, I think.
@droftarts okay, final update for today. I homed Y. It went all the way to the right (as far as it thinks it can go, I gather), and started coming down. When I looked at it head-on, I saw that the BLTouch was off the board (to the right). So, I turned the machine off.
Mac
@mac said in I could use some help:
The only thing you can do, with the current firmware, is to specify that the endstop is at the low end or the high end of the axis.
When you execute a G1 H1 move and the endstop sensor is activated the logical position of that axis is set to the axis min or max, as defined by the M208 values for that axis.
If the endstop is declared to be at the low end of the axis the min value is used.
If the endstop is declared to be at the high end of the axis the max value is used.
If, because of the actual location of the endstop sensor, the resulting logical position is not correct you have these options:
- adjust the position of the endstop sensor so it matches the M208 min or max value depending on the endstop being at the low or high end of the axis
- adjust the min or max value in M208 so it matches the position of the endstop sensor, again depending on the endstop being at the low or high end of the axis
- adjust the logical position to match the physical position using the needed combination of G1 moves and G92 setting of the logical position.F
@fcwilt yep, that’s what it gets down too. I’m going to change the setting to what they were in the beginning: Low, instead of high, using RRF, and see how that goes.
It's not guess work.
You know where the endstop is mounted, either at the min end of the axis, in which case the endstop setting is low, or at the max end of the axis, in which case the endstop settings it high.
And you can make a simple change like what via the DWC Gcode editor.
I believe you are encountering what some folks do when the use the configuration tool. It generates a complete set of files, which may or may not be correct. Folks install the files and hit homeall - and it doesn't work because of a wiring problem, bad part or configuration error.
The procedures I described for determining the max travel of an axis are part of checking the behavior of the printer step by step. And fixing each problem as you find one.
When I build a printer I take a very methodical, and perhaps boring, approach. One thing I will do is wire up one stepper at a time and verify it is working. Once all steppers are verified then I will move on the the endstop sensors. Again wiring up one at a time and verify it is working.
@fcwilt I think your's is a wonderful approach. Here's where I am at the moment.
In I/O Mapping, under Z-Probe, the Input Pin appears to be losing the (not assigned) assignment (not assigned). I can see that the BLTouch is bright red. I guess I'll have to pull the connector off the board to get that fixed. (I took your advice, and reinstalled my Z-axis end stop.)
On the Motors page of RRF: X is Forwards, Y is Forwards, Z is Backwards, and EO is Forwards now. I've been experimenting with hi and low endstop settings to see if I could get the Y-axis to behave. It's not happening so far.
On the Endstops page of RRF: X, Y, and Z are SWITCH, Low, High, Low. I have Y on High because I'm still trying to figure out what the settings should be. The range of Y seems to be only the front half of the printer (if that makes sense).
On the same page, No Z Probe is the choice.
On the Heaters Page I've gone back to Bang-Bang. I'm trying to get the printer to work by keeping it simple. The Heated Bed is set for a max of 33 degrees celcius. The Nozzle is set for 100 degrees celcius. The sensors are 4092's.
On the Fan page, Fan0 is full on, no thermostatic control, and Fan1 is the same.
Honestly, I don't understand the Tools page. What should I be trying to accomplish there?
I've turned off all display choices, so I guess this is a headless setup. I'm feeling a bit headless as well.
But I feel like I'm making some progress.
Mac
@fcwilt no progress, I think. I did change the y-axis endstop connector. It goes to i/06, so white wire to i/0 6_in, and green wire to GND, just like the X endstop connector next to it.
Home All: raises the x-rail, moves the bed towards the front, Z doesn't bring the z-rail down to the bed?
Home X: raises, moves the printhead to the right, and lowers the print head back again.
Home Y: raises the x-rail, and moves the bed forwards at the same time.
Home Z: raises the z-rail, turns the top fan for the print head on full speed, and that's it. -
Home Z: raises the z-rail, turns the top fan for the print head on full speed, and that's it.What you are trying to do is sort of what I talked about, testing "high level" things like "homing" before verifying that all the individual bits and pieces are working.
Think back to those "instructions" I suggested you try to verify that each axis was working (moving in the correct directions) and determine the max travel for each axis.
Were you able to complete those?
@droftarts my bad, sorry about that.
@fcwilt no, sadly, I was not.
I've made 3 videos of what's going on with my printer. The third one is almost on youtube.
For what good it will do.
Mac
I am trying. We have a language problem obviously. But I’m serious about getting my printer working. Your help has been very appreciated.
I’ll take these videos down when my printer's working as good as the XVico was.
Mac
@fcwilt I understand what you said. Each of has their own way. But both of us should be in the same journey, yes?
Mac
Well there is no point in worrying about why homing isn't working until you can verify that each axis is:
- moving in the correct directions
- moving by the correct amounts.
- that the axis limits in M208 are correct
- that the endstop settings in M574 are correct
- that the endstop switch is working
In the video you made of the X axis, when you were trying to jog in the -X direction, it failed to show what position the DWC was displaying for the X axis. If the firmware "thought" that the X axis was already at Xmin then it would not allow any further movement in the -X direction. Unless you had already disabled axis limits with M564 S0.
Let's re-visit what M564 does:
M564 H1 ; H1 = respect axis homed state M564 H0 ; H0 = ignore axis homed state M564 S1 ; S1 = respect axes limits M564 S0 ; S0 = ignore axes limits You can of course issue M564 with both an H and a S parameter:
M564 H1 S1 ; H1 = respect axis homed state, S1 = respect axes limits
When you tried to move in the +X direction by 10mm that worked. And then you were able to move in the -X direction by 10mm.
Which reinforces the idea that the X axis was already at the Xmin limit when you tried the first moves in the -X direction.
Normally homing X would have left the X axis in a state where it could travel from Xmin to Xmax.
It didn't, which says to me:
- the homing code is not correct
- that the endstop settings in M574 are not correct
Please post your X axis homing code, which should be in the file homeX.g
And the settings for your X axis endstop.
Well, yes.
But if our destination is 10 miles due west and I start out heading west and you start out heading east which of us is likely to get there first?
@fcwilt I think I would, my friend, because I would be speeding and igniting all the stop light!
I just read your above post, the serious one, I’ll call it. Thank you!
@droftarts I should have written X, it was the printhead on the X-axis coming down.
