    I could use some help
    682
    64.7k
      droftarts administrators @A Former User
      @mac Try
      M92 X40.00 Y40.00 Z2000.00 E420.00
      A Former User? 2 Replies Last reply Reply Quote 0
        A Former User @droftarts
        @droftarts ahhhhh, where do I half the steps?
          @droftarts you're saying type that in to the command line in DWC, and send it, correct?
          • fcwiltundefined
            fcwilt @A Former User
            @mac
            I recall from the video that the endstops for X and Y were at the low (min) end of the axis.
            IF that is true you need to change your M574 commands to use X1 and Y1.
            And your M574 for the Z axis is incomplete - it has no P parameter.
              @mac said in I could use some help:
              Yes. And if it works, add it to config.g, and then set it like that in the configuration tool so it outputs correctly next time.
              A Former User? 3 Replies Last reply Reply Quote 0
                @droftarts okay, I did that first command (M92 etc. that you suggested).
                I feel like I'm on thin ice here. Obviously, I'm more comfortable with using RRF to make these changes?
                But maybe that's the problem?
                I'm having a hard time going forwards at this point.
                  @droftarts "add it to config.g" means what, exactly?
                  fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  • fcwiltundefined
                    You already have an M92 and an M574 in your config.g file.
                    Just edit the file via the DWC and enter the new values for those commands - if those values have changed.
                    And read what I posted about the relationship of M92 and M574.
                      A Former User @fcwilt
                      @fcwilt on RRF Config Tool, Endstop Configuration, X-Switch-High end, Y-Switch-High end, Z-Z-probe-Low end.
                      Change to?
                      • fcwiltundefined
                        But maybe that's part of the problem?
                        I do think that relying on the configuration tool keeps you from learning and understanding all that is going in the various files.
                          It means edit it in DWC, by going to System, then clicking config.g, then edit and save. That changes it on the machine. You need to reset the board (turn power on and off) to get it to read config.g again at start up, which it will ask you when you save.
                          Sending the command directly, in the 'Gcode console', will execute the command and change the setting immediately, but will be overridden by the contents of config.g the next time you turn off and turn on the printer.
                            @fcwilt indeed.
                              @droftarts I actually understand what you just wrote. Thanks!
                              • fcwiltundefined
                                Change to?
                                Sorry, I don't use that tool.
                                You posted part of your config.g file showing M574 X2 S1 and M574 Y2 S1.
                                If your endstops are, in fact, at the low (min) end of the X and Y axes, X2 needs to be X1 and Y2 needs to be Y1.
                                Just edit your config.g file in the DWC editor. No need to use the config tool for such simple changes.
                                  @droftarts I typed that into the command line, and sent it (somewhere). What should I have done after that?
                                    A Former User @A Former User
                                    @mac M92 X40.00 Y40.00 Z2000.00 E420.00
                                      @droftarts and to confirm if that M92 command worked, I need to Home X again, correct?
                                        @droftarts The M92 command lowered then raised the X-axis. The printhead shimmied side to side, but that's it.
                                          @fcwilt What should the P for the Z be?
                                          fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
                                          • fcwiltundefined
                                            I don't know. You said at one point you had a Z endstop. You must have connected it to some input pin.
                                            Is it still connected to that same pin?
