    I could use some help
    682
    65.0k
      A Former User @droftarts
      @droftarts and to confirm if that M92 command worked, I need to Home X again, correct?
        A Former User @A Former User
        @droftarts The M92 command lowered then raised the X-axis. The printhead shimmied side to side, but that's it.
          A Former User @fcwilt
          @fcwilt What should the P for the Z be?
          fcwiltundefined A Former User? 2 Replies Last reply Reply Quote 0
          • fcwiltundefined
            fcwilt @A Former User
            @mac said in I could use some help:
            I don't know. You said at one point you had a Z endstop. You must have connected it to some input pin.
            Is it still connected to that same pin?
              @droftarts
              M574 X1 S1 P"!io5.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io5.in
              M574 Y1 S1 P"!io6.in"                              ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io6.in
              M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                @mac whoa, I did it!
                • fcwiltundefined
                  You did what?
                    @fcwilt I got the code to appear like you did, with the black background.
                    A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                      @droftarts I also saw the Save button in the X 0:/sys/config.g ? G-Code Reference (disk image) Save
                      • fcwiltundefined
                        You are making good progress!
                        Now with the endstops configured what we believe to be correct you can check their operation using the Object Model Browser.
                        You did get that up and running didn't you? I think I recall you did.
                        Or you can execute M119 from the DWC console and it will display the state of the endstops.
                        To verify their operation you have to find a way to hold them closed so you can execute the M119 and see what is reported.
                        And, of course, you want to execute M119 when they are not closed to see what is reported.
                          @fcwilt The Z Endstop is plugged into io_2 (right above i0_3, which is the BLTouch). The green wire is attached to GND (middle hole), and the white wire is attached to io2. in.
                            @fcwilt I have to go feed my daughter's horse. Back in twenty.
                            • fcwiltundefined
                              Then the command should be:
                              M574 Z1 S1 P"!io2.in" but using the ! character assumes you have connected the white wire to the NC connection on the endstop switch.
                              If you HAVE NOT connected the wire to the NC connection of the endstop switch DO NO include the ! character.
                              And then we need to us M119 to verify the operation of each endstop switch to be sure they are working and generating the correct states for closed and open.
                                @fcwilt The WHITE WIRE is connected to the NO.
                                  @droftarts
                                  M574 Z1 S2 P"io2.in"                                       ; configure Z-probe endstop for low end on Z
                                    @droftarts I LOVE doing that!
                                    • fcwiltundefined
                                      OK now that we think the M574 commands are all correct you need to verify the endstop switches are all working.
                                      So switch to the DWC Console and type in M119 and press the enter key.
                                      Please post back what you see displayed as a result of the M119.
                                        @droftarts M119 reports: "X not stopped: Y not stopped, Z no endstop, Zprobe: not stopped
                                          @droftarts
                                          M552 S1                                            ; enable network
                                          M586 P0 S1                                         ; enable HTTP
                                          M586 P1 S0                                         ; disable FTP
                                          M586 P2 S0                                         ; disable Telnet
                                          M569 P0.0 S1                                       ; physical drive 0.0 goes forwards
                                          M569 P0.1 S1                                       ; physical drive 0.1 goes forwards
                                          M569 P0.2 S1                                       ; physical drive 0.2 goes forwards
                                          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
                                          M584 X0.0 Y0.1 Z0.2 E0.3                           ; set drive mapping
                                          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z4000.00 E420.00                 ; set steps per mm
                                          M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
                                          M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z200.00 E250.00               ; set accelerations (mm/s^2)
                                          M906 X600 Y600 Z600 E600                           ; set motor currents (mA)
                                          M84 S0
                                            @droftarts check out the existing M92 line.
                                            droftartsundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
