    datum was not determined probing
    489
    • pabomanundefined
      paboman
      what this error mean ?
        jay_s_uk @paboman
        @paboman reprobe the bed height (i.e. home it) before loading the heightmap
        pabomanundefined 1 Reply Last reply Reply Quote 0
        • pabomanundefined
          paboman @jay_s_uk
          @jay_s_uk said in datum was not determined probing:
          I cant reprobe the bed it as i dont have the probe anymore.
          it was working until today....does the heightmap have an expiration date ??
          jay_s_ukundefined weed2allundefined 2 Replies Last reply Reply Quote -1
            jay_s_uk @paboman
            @paboman no, it doesn't. how do you home the bed?
            • pabomanundefined
              paboman @jay_s_uk
              its a delta, I home the printhead with G28
              ; Configuration file for Duet WiFi (firmware version 1.20 or newer)
              ; generated by RepRapFirmware Configuration Tool on Sun Feb 25 2018 16:19:34 GMT+0100 (ora solare Europa occidentale)
              M912 P0 S-4								; CPU Temp calibration S= hotend at room temp - Cpu cold boot temp
              G90        ; Send absolute coordinates...
              M83        ; ...but relative extruder moves
              ;M501									; Load config override at boot
              ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
              M665 L1146 R572.5 H1677.5 B500.0 X0.001 Y0.000 Z0.000		        ;L=rod R= delta radius H= height to trigger end stops B= Printable radius XYZ= tower corrections
              M666 X0.00 Y0 Z-0.5 A-0.01 B0.064 				        ;XYZ= endstops corrections(valori negativi alzano ugello) A= bed tilt in X B= bed tilt in Y
              M558 P5 H10 F600 T6000 I1                                               ; Set Z probe type to switch and the dive height + speeds (was P5)
              G31 P600 X0 Y0 Z12.16                                                   ; Set Z probe trigger value, offset and trigger height
              M557 R500 S100                                                          ; Define mesh grid R= probe Radius S= Mesh Spacing (was 50)
              M550 PAtlas MAGNUM	                                                ; Set machine name
              M552 S1        ; Enable network
              M587 S                                          ; Configure access point and IP addresses. You can delete this line once connected
              M586 P0 S1                                                              ; Enable HTTP
              M586 P1 S0                                                              ; Disable FTP
              M586 P2 S0                                                              ; Disable Telnet
              M569 P0 S1                                                              ; Drive 0 goes forwards
              M569 P1 S1                                                              ; Drive 1 goes forwards
              M569 P2 S1                                                              ; Drive 2 goes forwards
              M569 P3 S0                                                              ; Drive 3 goes forwards
              M350 X128 Y128 Z128 E16 I0                                              ; Configure microstepping without interpolation (was 16)
              M92 X640 Y640 Z640 E1166                                            	; Set steps per mm (mathematically has to be 640 was 659)
              M566 X3000 Y3000 Z3000 E1200                                            ; Jerk: Set maximum instantaneous speed changes (mm/min) (E was 1200)
              M203 X5000 Y5000 Z5000 E1200                                            ; Set maximum speeds (mm/min) (E was 1200)
              M201 X250 Y250 Z250 E500                                                ; Set accelerations (mm/s^2)(was 5000)
              M906 X1400 Y1400 Z1400 E450 I40                                            ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30        ; Set idle timeout
              M208 Z0 S1                                                              ; Set minimum Z
              M574 X2 Y2 Z2 S1                                                        ; Set active high endstops
              ; Hotend
              M143 H1 S320                                                            ; Set temperature limit for heater 1 to 320°C
              M307 H1 A315.3 C182.4 D3 S1						; H1= hotend1 A= Gain C= Constant D= Dead Time S= Max PWM
              M305 P1 x200                                                            ; Set thermistor + ADC parameters for heater 1
              ;M570 H1 P10 T20							; Heater Fault configuration H= hotend P=anomaly in seconds before fault T= Permitted excursion from the setpoint (default 15C)
              ; Pressure advance
              M572 D0 S0								;D= extruder S=amount of pressure advance (If increasing S slows the print down, try increasing extruder jerk (M566 E parameter))
              ; Bed
              M307 H0 A20.1 C140.7 D5 S1 B0						; Use model heater (D was 1.8)
              ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30                              ; Use PID on bed heater (may require further tuning)
              M305 P0 T100000 B3950 C0 R4700                                		; ADC parameters for heater 0 T= 100000 is ohms at 25 celsius B= Beta(was 4725) C= Steinhart-Hart C coefficient (was 7.060000e-8), default 0 R= Series resistor is 4700 for Duet
              ;M305 P0 T100000 B4472 C8.152118e-8 R4700  				; Calculated steinhart coefficent at 25-50-100 from thermistor table
              M143 H0 S100                                                            ; Set temperature limit for heater 0 to 100C
              M106 P0 S1 I0 F10 H-1                                                  ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off F= was 500
              M106 P1 S1 I0 F10 H T30                                                ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M106 P2 S1 I0 F10 H T30                                                ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0 H1                                                           ; Define tool 0
              G10 P0 X0 Y0 Z0                                                         ; Set tool 0 axis offsets
              G10 P0 R0 S0                                                            ; Set initial tool 0 active and standby temperatures to 0C
              ; Automatic power saving
              M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"                      ; Set voltage thresholds and actions to run on power loss
              M106 S0									;turn OFF Layer fan on boot
              ; Filament Monitor HC-020K
              M591 D0 P7 C3 S1 R60:8000 L1.85 E10   					; D= sensor for extruder drive 0, C= E0 endstop input, P= Sensor type, S1= Enable, R=70% to 130% tolerance, L= mm/pulse, E= detection length
              M591 D0 								; display filament sensor parameters for extruder drive 0
                jay_s_uk @paboman
                @paboman thats one massive delta.
                when are you loading the heightmap?
                • pabomanundefined
                  paboman @jay_s_uk
                  yes, and its 4 year old now. worked good until now.
                  I load the heightmap in the Homedelta.g
                  ; homedelta.g
                  ; called to home all towers on a delta printer
                  G91                        ; relative positioning
                  G1 S1 X2500 Y2500 Z2500 F6000 ; move all towers to the high end stopping at the endstops (first pass)
                  G1 X-5 Y-5 Z-5 F1800 S2    ; go down a few mm
                  G1 S1 X10 Y10 Z10 F360     ; move all towers up once more (second pass)
                  G1 Z-5 F1000               ; move down a few mm so that the nozzle can be centred
                  G90                        ; absolute positioning
                  G1 X0 Y0 F1000             ; move X+Y to the centre
                  G29 S1			; Load Heightmap
                    jay_s_uk @paboman
                    @paboman I don't see any issues there.
                    You could try adding an M561 before the first G91
                    Have you made any changes like update the firmware or anything?
                    • pabomanundefined
                      paboman @jay_s_uk
                      last update was 2 years ago
                      I am running on Firmware: 2.05.1 - Web Interface:1.21.1
                      • weed2allundefined
                        weed2all @paboman
                        @paboman on my deltas with smart effector I need to home the effector then run G30 to establish the Z0 datum, and after i have the G29 S1 to load the mesh
                        https://www.thingiverse.com/weed2all/designs
