    I could use some help
    682
    63.9k
    • fcwiltundefined
      fcwilt @A Former User
      @mac said in I could use some help:
      @fcwilt I just posted the measurements I've been collecting over the last four hours. Maybe they will be helpful? Maybe they will have some impact on what I just read in your post? I'm all for moving forwards, but it's nice to know the route ahead beforehand?
      My first goal today is to get the Y axis working in all regards.
      We have gotten it moving in the right directions.
      We have determined how far it can travel.
      Now we need to get Y homing working.
      Once that is done we need to move on to getting the X axis working, then the Z axis.
      It is essential that all three axes work correctly and home correctly before we can move on to the next phase.
        A Former User @fcwilt
        @fcwilt essential work sounds like fun! I'm all in.
          A Former User @droftarts
          @droftarts thanks for asking, Ian. I'm going to focus all of my attention of meeting Frederick's needs today, as he's hell-bent to get my printer working properly. I feel like I need to support his efforts as best I can.
          At some point, I'll make a video about all of this, and put what I've learned about the technology and the coding and the great customer support I've received. Hopefully, I'll be able to use moving pictures to make the points that need to be made.
          Mac
            @fcwilt I'm going to make the change, etc., and will let you know as quickly as I can.
            droftartsundefined 1 Reply Last reply Reply Quote 1
            • fcwiltundefined
              Mac
              I assume you want to get it working as well?
              If that is not the case then let me know and we can explore any aspect of your printer you like.
                droftarts administrators @A Former User
                @mac once the axes are moving correctly, it may help you to draw a picture of the bed. Measure the size of the bed. Move the nozzle to the home X and Y position, touching the endstops. Is the nozzle over the bed, on the edge of the bed, or not over the bed? Measure the offsets. Do the same with the nozzle at the maximum position, measuring the offsets from the bed. You will need these numbers for the M208 commands, to get the printer to know where the printable are of the bed is.
                  @fcwilt REPORT: the bed started towards the rear of the printer slowly, then moved faster, until it came to where it thought it should stop, and did so.
                  UPDATE: I decided to move the bed forwards as far as it would go. DWC is telling me that the bed will go to 220mm. According to my metal measuring stick, 220mm is 327mm in the real world.
                  UPDATE: I thought I was seeing weird behavior. So I moved the bed forwards and backwards to the limits imposed on it by the firmware. A couple of times I hit the endstop and then kept going to pound on the motor a bit. None of this bothers me. I have a box of endstops and a box of motors I can use to repair whatever damage these efforts produce.
                  The firmware is limiting how far the bed can go forwards to where it thinks 220mm is. It's 220mm is 327mm in the real world.
                  It's not lightly touching the end-stop, then backing up (forwards) / away from it.
                  M119 reports that Y is at Max Endstop.
                    @fcwilt "properly" means exactly that.
                    I'll put it another way: I want this $160+ dollar board to outperform the mystery board in my Xvico. I think my efforts, and everyone's help require that to put the world right again.
                    Mac
                      @droftarts I understand. And I'm working on developing that image.
                        A Former User @A Former User
                        @fcwilt I just ran M119 for all 3 endstops. When depressed, all of them are reporting that they are at Max Endstop.
                        • fcwiltundefined
                          I have no idea what is going wrong.
                          Your testing confirmed the Y jogged in the correct directions.
                          You testing confirmed that all of the endstops were working.
                          The Y homing code is very simple.
                          How about this:
                          • move the bed to roughly the center of it's possible travel
                          • verify the Y endstop is working using M119
                          • if all is good execute G91 then G1 H1 Y-360 F3600
                          It should move to the endstop and halt. The DWC display should read Y = 0.
                          • fcwiltundefined
                            Max Endstop?
                            That's wrong.
                            What do the current M574 commands look like.
                              @fcwilt I put a + on the center of the bed. I also put a l on the left side of the bed. I lined those marks up with 9 inches, which is half of the 18 inches the bed can travel.
                              I sent the codes.
                              The bed moved may-be a millimeter to the rear.
                                @fcwilt
                                M574 X2 S1 P"!^io5.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in
                                M574 Y2 S1 P"!^io6.in"							   ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in
                                M574 Z2 S1 P"!^io2.in"							   ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io2.in
                                  @fcwilt M119 is reporting Y not stopped. The bed is forwards of it 60mm.
                                    @fcwilt DWC is reporting that when the bed is at the center of it's actual real-world run (228.6mm), it's at 220mm, which is the end of it's run.
                                      @fcwilt when I run the bed back to the y-endstop, DWC says the bed is at 104mm.
                                        @fcwilt how do we tell the firmware that 104mm is 0mm / home?
                                        A Former User? fcwiltundefined 2 Replies Last reply Reply Quote 0
                                          @mac well, I guess that's the end of that.
                                            @fcwilt
                                            Change to X1, Y1 and Z1. How did these get changed back? These were right yesterday!
