I could use some help
682
63.5k
    A Former User @fcwilt
    @fcwilt
    M574 X2 S1 P"!^io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in
    M574 Y2 S1 P"!^io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in
    M574 Z2 S1 P"!^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io2.in
    undefined 1 Reply Last reply 28 Jun 2022, 17:31 Reply Quote 0
      A Former User @A Former User
      @fcwilt M119 is reporting Y not stopped. The bed is forwards of it 60mm.
      ? 1 Reply Last reply 28 Jun 2022, 16:59 Reply Quote 0
        @fcwilt DWC is reporting that when the bed is at the center of it's actual real-world run (228.6mm), it's at 220mm, which is the end of it's run.
        ? 1 Reply Last reply 28 Jun 2022, 17:01 Reply Quote 0
          @fcwilt when I run the bed back to the y-endstop, DWC says the bed is at 104mm.
            @fcwilt how do we tell the firmware that 104mm is 0mm / home?
            ? undefined 2 Replies Last reply 28 Jun 2022, 17:17 Reply Quote 0
              @mac well, I guess that's the end of that.
                droftarts administrators @A Former User
                @mac said in I could use some help:
                @fcwilt
                Change to X1, Y1 and Z1. How did these get changed back? These were right yesterday!
                ? 1 Reply Last reply 28 Jun 2022, 17:56 Reply Quote 0
                  A Former User @droftarts
                  @droftarts
                  M574 X1 S1 P"!^io5.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !^io5.in
                  M574 Y1 S1 P"!^io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io6.in
                  M574 Z1 S1 P"!^io2.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin !^io2.in
                  ? 1 Reply Last reply 28 Jun 2022, 17:57 Reply Quote 0
                    @droftarts I guess I could scroll backwards through this thread to find out, but I don't want to blame anyone. I changed them, for whatever reason, so I'm the one at fault.
                    And now I've changed them again.
                    ? 1 Reply Last reply 28 Jun 2022, 17:59 Reply Quote 0
                      @droftarts
                      Here's the M119 report:
                      6/28/2022, 10:58:25 AM M119
                      Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped
                      ? 1 Reply Last reply 28 Jun 2022, 18:07 Reply Quote 0
                        @droftarts what did that change accomplish? Is there something I’m supposed to do now? Would you like me to home the Y-axis to see if it stops at the endstop, then backs off?
                        ? undefined 2 Replies Last reply 28 Jun 2022, 18:08 Reply Quote 0
                          @droftarts my apologies to Frederick for pissing him off. He didn’t say anything to me; he just disappeared.
                          undefined 1 Reply Last reply 28 Jun 2022, 18:36 Reply Quote 0
                            When you press them and send M119, they will say ‘at min stop’ now, assuming you restarted. Try homing.
                            I’m sure Frederick has just been distracted, not annoyed. I’m putting kids to bed, so away for a while.
                            ? 1 Reply Last reply 28 Jun 2022, 18:29 Reply Quote 1
                              @droftarts
                              The y-axis was set as M574 Y1 S1 P"!^i06.in". So it went towards the front of the printer, and when it got there it pounded on the front of the bed until I turned the printer off.
                              The end-stop for Y is at the rear of the machine, so, I changed the code to: M574 Y1 S0 P"!^io6.in" to send the bed backwards instead of forwards.
                              Now I'm going to give it a try, but first, I'm going to M119 the end-stops.
                              Interesting, Y: no endstop. At the bottom of the Console screen I'm seeing G28 Y Error: Failed to enable endstops.
                              Why would changing the direction of the bed from moving forwards to an endstop that isn't there to moving backwards to an endstop that is there cause the endstop to disappear?
                              I'll come back to his later.
                              undefined undefined 2 Replies Last reply 28 Jun 2022, 18:38 Reply Quote 0
                                fcwilt @A Former User
                                Mac, you did not upset me in the slightest. My wife and I had made plans to go to lunch and the time to leave snuck up on me.
                                Lunch was grand.
                                Perhaps that will bring us luck.
                                  @mac M574 S0 means no endstop. You change axis direction with M569. Again, this was fixed last night, so either you didn’t save it, or you’re using the wrong config.g.
                                    @droftarts
                                    Mac,
                                    The M574 settings have no effect on the direction of travel. The merely specify the type of endstop (the S parameter ) and the location (the X, Y or Z parameter).
                                    When you changed S1 to S0 you were specifying that there was no endstop on that axis.
                                    S1 specifies a simple switch type endstop - which is what you have.
                                    Change them all to S1.
                                    The direction of travel is controlled, in part, by the settings in M569. Do you change those again. We had them correct, at least for Y.
                                    The direction of homing is controlled by the G1 moves in the homing files.
                                    For the Y axis a negative amount should move the bed backwards.
                                    Example: G91 followed by G1 H1 Y-360
                                    For the Y axis a positive amount should move the bed forwards.
                                    Example: G91 followed by G1 Y+10
                                    ? 2 Replies Last reply 28 Jun 2022, 20:35 Reply Quote 0
                                      We don't need to worry about that now.
                                      We have more fundamental problems with basic axis behavior.
                                      ? 1 Reply Last reply 28 Jun 2022, 20:33 Reply Quote 0
                                        @droftarts @fcwilt
                                        Okay, that's fixed?
                                          @fcwilt
                                          M569 P0.1 S0 ; physical drive 0.1 goes backwards
                                          That is what they are currently. Y is supposed to be going backwards. Does that reverse the jog buttons in DWC?
                                          undefined 1 Reply Last reply 28 Jun 2022, 20:40 Reply Quote 0
                                          417 out of 682
