    Problems with Duet 3 Mini 5+ WiFi
    3.8k
    • fcwiltundefined
      fcwilt @Unforgivenll
      @unforgivenll said in Problems with Duet 3 Mini 5+ WiFi:
      @fcwilt Thank you again. I'm clearly over my head here. I thought I had a handle on this before I started. Unfortunately I have a lot of money plus time into this project, so I can't walk away from it. I'm feeling a little overwhelmed at the moment. I'm 45 and just started using 3d printers a little over a year ago. I don't have any background whatsoever in CNC, CAD, or 3D printing (maybe a tiny bit in general electronic/soldering). Anyhow, I'll try to implement your advise when the new parts come in. I'm waiting on a build plate and have yet to setup/order a custom heater. I appreciate your help, patience and time. Hopefully I can make some progress on my own when I get the new parts. I'm not feeling real confident at the moment.
      I started working with 3D printing in my late 60s, I just turned 72.
      Feel free to ask whatever questions you have. Someone here is likely to answer them. I check in here most every day but I don't spend too much time here, lots of other things I need to do.
      Unforgivenllundefined 1 Reply Last reply Reply Quote 0
      • Unforgivenllundefined
        Unforgivenll @fcwilt
        @fcwilt Thank you you I appreciate it. Unfortunately I do have to wait for parts. I don't think there's a lot more I can do until I have them. At least none I can think of that makes sense without the build plate or heater.
        • fcwiltundefined
          Well there are things about GCode you can learn, such as there being a short form for M208
          M280 Xmin:max Ymin:max Zmin:max
          All on one line instead of two.
          What hardware are you using? Your config.g file mentions a Duet 3 Mini but the M584 line suggests you have an external device on the CAN bus.
            @fcwilt I have the tool board with the BLTOUCH, Lgx, mosquito magnum, part fan, cooling fan, thermistor and heater setup and working.I designed the carriage and the mount. The duct was designed by someone on Thingiverse, * just modified my carriage to work with it.
            PXL_20220624_021300492.jpg PXL_20220624_021306157.jpg PXL_20220624_021312228.jpgPXL_20220624_021300492.jpg
            • fcwiltundefined
              @unforgivenll
              Is the Z-probe as close to the nozzle as you could get it?
              That is a long ways away.
                @fcwilt I'm sure someone more experienced than me could have done a better job. Like I said I don't have any background in Cad and only starting using it less than a month ago.
                • fcwiltundefined
                  Don't be surprised if you find yourself re-designing parts of your printer. I have one printer that is so different now from it's first version there is very little left of the first one.
                  I recently converted a printer using stall detection for homing to using actual endstop sensors. It took me several tries to get it done to my satisfaction.
                  For me that's part of the enjoyment. Learning from experience and striving for improvements.
                    @fcwilt Yeah I plan to take another look at it at some point. It took me quite awhile to get that far. I figured when I was actually able to print I'd have to revise it. All I have at the moment is a resin printer. I don't trust it to last long.
                    • fcwiltundefined
                      You are a brave pioneer. I watched a few videos regards resin printers. That was enough to keep me far away from the complexity of the entire process.
                      The results can be impressive and well suited to certain projects.
                      Unforgivenllundefined 2 Replies Last reply Reply Quote 0
                        @fcwilt Well it looks like it will be a month or so before the parts are shipped. I started this project over a year ago, another month or so isn't too bad, I guess.
                          @fcwilt It's been a long time since I was last in contact with you. I had ordered some CNC parts and they were supposed to take a month or so. Flash forward to today and I might receive them Wednesday. Since then I have changed my mind on the hotend mount I had designed as the Hero Me designer came out with a mount specifically for my setup. I am unable to print with the materials that I need so I'll have to order those as well. I just wanted to touch base. Hopefully I can have all the electrical and mechanical parts setup in the near future. I could still use your help with the software when the time comes, if you're available your help and guidance would be greatly appreciated.
