    Running G32 on Duet 3 Mini 3 5+ the skew is applied in reverse?
    • Mr_Phelpsundefined
      Mr_Phelps
      If I manually level the bed I get a good first layer.
      When I run G32 it seems to make the adjustment in the wrong direction.
      Here is the z parts of config.g:
      M584 X1 Y2 Z0:4 E3 ; set drive mapping
      M671 X-37:287 Y0:0 S10 ; define dual driven z-axis
      Here is bed.g:
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Mon Mar 15 2021 19:09:36 GMT+0100 (Mitteleuropäische Normalzeit)
      M561 ; Clear any existing bed transform.
      G28 ; home
      M558 F100 A5 S0.003
      G30 P0 X15 Y125 Z-99999 ; probe near a leadscrew, half way along Y axis
      G30 P1 X205 Y125 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
      M558 F200 A1
      G1 X10 Y210 Z10 F10000
      Any suggestions on what I am doing wrong?
      Thanks,
      Mike
        jay_s_uk @Mr_Phelps
        @mr_phelps sounds like the M671 is the in the opposite order to your M584 mapping
        Change your M584 from Z0:4 to Z4:0
        Mr_Phelpsundefined 1 Reply Last reply Reply Quote 1
          Mr_Phelps @jay_s_uk
          @jay_s_uk Thanks! Looks like that worked. When the controller on my Prusa 2.5 finally died I swapped over to the Duet Mini 5+. Probably got the z connectors reversed by accident.
