    Strange sensorless homing in X
    • Tinchusundefined
      Tinchus
      Hello. I have a duet3 board, SBC mode, running 3.4 firmware.
      This is my homex.g file for my sensorless setup:
      M915 X Y S1 R0 F0
      M400 ; Wait for current moves to finish
      M913 X40 Y40 ; drop motor current to 70%
      M400
      G91 ; relative positioning
      G1 H2 Z10 F12000 ; lift Z relative to current position
      G1 H1 X-350 F7000 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X50 F12000 ; go back a few mm
      G1 H1 X-350 F7000 ; move slowly to X axis endstop once more (second pass)
      G1 x150 f7000
      G1 H2 Z-10 F6000 ; lower Z again
      G90 ; absolute positioning
      M400
      M913 X100 Y100 ; return current to 100%
      M400
      M915 X Y S1 R1 F0
      The problem Im having is that when it runs the G1 H1 X-350 F7000 ; move quickly to X axis endstop and stop there (first pass)
      sensorless is triggered and it goes back a little BUT it moves +25mm in the Y. It is a real movements since on the interface I can read the +25mm Y movement
      And then goes for the sencond pass.
      Im loosing my mind trying to figure it out why it is moving those 25 mm on the Y axis
      Ideas?
        Is this a corexy? If so, remove the H2 from the back off move as it is moving just one motor, not the axis itself.
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Phaedrux
          @phaedrux Yes, it is something similar, an H-bot configiration.
          Question: is the corexy also going to affect somehow the tunning of the sensorless homing regarding currents and sensibility of each axis? Im having some trouble there too.
            Yes sensorless homing will be harder in a system with multiple motors moving at the same time to generate movement. It will also be influenced by belt length/stretch and tension. A simple endstop is usually the better option.
