    notifications upon start/pause/finish of print
    Third-party software
    18
    65
    6.3k
    • Festivejellyundefined
      Festivejelly
      This is fantastic. Just what I was looking for.
      I tried running this on windows from command line, but theres no feedback... so im not even sure its running?
      I do have a spare raspberry pi lying around so which release would I use for that?
      Torinundefined 1 Reply Last reply Reply Quote 0
      • Torinundefined
        Torin @Festivejelly
        @thebaseddoge Simply start two programs with from two different directories with two different config files 🙂
        @festivejelly There's no feedback unless there's a problem 🙂 If you want to run on rpi you need an arm build.
        Festivejellyundefined 1 Reply Last reply Reply Quote 0
          Festivejelly @Torin
          @torin So do I run from command line? or do I just double click the exe? When I do either I dont see the process running in the list. Ill give the arm build a try instead on my rpi
          • Torinundefined
            Torin @Festivejelly
            @festivejelly You can run it both ways, either from command line or double click. If it doesn't quit and windows stay open it should just work.
            • Nxt-1undefined
              Nxt-1 @Torin
              @torin I don't know if you planned on maintaining this app, but it sure would be nice if it received an update.
              I did some testing and got a contineous stream of JSON parse errors. After checking the sources it seems the program uses the GET /rr_status way of talking to the Duet. However, according to this page on the Duet Github, it is deprecated now.
              Should you decide to maintain it, I could make time to help out testing.
              -Nxt
              Duet3D and delta printer enthousiast. Buildlog
              Looking for Duet3D configuration support, check out Nxt-3D
              madeinta1wanundefined 1 Reply Last reply Reply Quote 1
              • madeinta1wanundefined
                madeinta1wan @Nxt-1
                @nxt-1 getting the similar errors via windows
                "2022/06/21 14:23:53 Error while downloading rr_status: Too many errors, resetting counters and stoping track operation. Will hide consequent errors..."
                Any chance there's a fix for this @Torin ?
                Thanks,
                Nate
                Torinundefined chrishammundefined 2 Replies Last reply Reply Quote 0
                • Torinundefined
                  Torin @madeinta1wan
                  @madeinta1wan This is due to API changes introduces in RRv3. There's a chance but it requires few hours of work which I currently do not have, however I will try to squeeze that in somehow. The code is opensource so if someone would make an PR I will happily merge it.
                  • chrishammundefined
                    chrishamm administrators @madeinta1wan
                    @madeinta1wan @madeinta1wan rr_status is still supported in standalone mode AFAIK. We will add a support layer for rr_ requests to SBC mode in v3.5 but I'm afraid it won't support rr_status. If possible, I'd strongly recommend upgrading to rr_model which returns portions of the object model.
                    Duet software engineer
                    • Torinundefined
                      Torin @chrishamm
                      So I finally found some time and resurfaced my duet enabled printer so I have started updating the app.... So hopefully soon there will be something to show 😉
                      @chrishamm How do I currently identify finished print? Previously it was in rr_status marked as 'I'(capital I), now I can see see only in rr_model?key=state status: idle, pause, printing.
                      chrishammundefined 1 Reply Last reply Reply Quote 1
                        chrishamm administrators @Torin
                        @torin Those letters are abbreviations for the different machine states (see here), so idle is equal to I.
                        • Torinundefined
                          Torin @chrishamm
                          @chrishamm Many thanks for that, it definitely extends what I've seen.
                          However I am missing a 'final status' if that makes sense e.g. there's the status for cancelling yet there's no cancelled status or processing and no processed which makes it hard to understand and put the proper function in place to determine final status without hammering the API and making a request every let say 100ms which could still lead to some false positives.
                          stuartofmtundefined 1 Reply Last reply Reply Quote 0
                          • stuartofmtundefined
                            stuartofmt @Torin
                            @torin
                            This may help. Its some of the logic in DuetLapse3. It ends up being a bit convoluted .... and of course I have a bunch of defensive coding in here (for other reasons).
                            The main logic starts at line 16.
                            Any yes - it can do with a bit of tidying up 😞
                            def captureLoop():  # Run as a thread
                                global printState, duetStatus, captureLoopState
                                if connectionState is False:
                                    return
                                captureLoopState = 1
                                printState = 'Not Capturing'
                                lastDuetStatus = 'idle' # logical state on start of each thread instance
                                logger.debug('Starting Capture Loop')
                                while captureLoopState == 1:  # Set to 0 to stop. e.g  By http listener or SIGINT or CTL+C
                                    if duetStatus != lastDuetStatus:  # What to do next?
                                        logger.info('****** Duet status changed to: ' + str(duetStatus) + ' *****')
                                        # logical states for printer are printing, completed
                                        if duetStatus == 'idle' and printState in ['Capturing', 'Busy'] and terminateState != 1:  # Capturing is finished without being commanded
                                            printState = 'Completed'
                                            logger.debug('****** Print State changed to ' + printState + ' *****')
                                        elif duetStatus in ['processing', 'idle'] or (duetStatus == 'paused' and detect == 'pause'):
                                            printState = 'Capturing'
                                            logger.debug('****** Print State changed to: ' + printState + ' *****')
                                        elif duetStatus == 'busy':
                                            printState = 'Busy'
                                        else:
                                            printState = 'Waiting'
                                        logger.info('****** Print State changed to: ' + printState + ' *****')
                                    if printState == 'Capturing':
                                        oneInterval('Camera1', camera1, weburl1, camparam1)
                                        if camera2 != '':
                                            oneInterval('Camera2', camera2, weburl2, camparam2)
                                        unPause()  # Nothing should be paused at this point
                                    elif printState == 'Completed':
                                        logger.info('Print Job Completed')
                                        # use a thread here as it will allow this thread to close.
                                        startnextAction('completed')
                                        break # Do not want to wait to end
                                    if captureLoopState == 1 and terminateState != 1 and connectionState:  # If still running then sleep
                                        lastDuetStatus = duetStatus
                                        time.sleep(poll)
                                captureLoopState = -1
                                return  # End of captureLoop
                            • Torinundefined
                              Torin @stuartofmt
                              Hey folks,
                              I want to share a download link with the version that should now work with v2 and v3 API.
                              If you could test it and let me know if it's all good that we'd be great and I will release it officially.
                              Only change you need to make is additional entry in your configuration file adding api_version in the connection section(v2 or v3) e.g.:
                              connection:
                                host: 192.168.0.11
                                polling_time: 30
                                error_count: 5
                                api_version: v3
                              Without further ado:
                              https://1drv.ms/u/s!Aq3gq6mIQqpsisE-e3Adz3wsP6dAJw
                              Link is going to expire in 2 weeks, after that I will just merge it 🙂
                              stuartofmtundefined Nxt-1undefined 2 Replies Last reply Reply Quote 0
                                stuartofmt @Torin
                                @torin
                                Don't know if this is interesting for you but may avoid having the user input the version /model info. Its Python, but the logic will be the same.
                                def getDuetVersion(model):
                                    # Used to get the API and version information from Duet
                                    if model == '' or model == 'rr_model':
                                            URL = ('http://' + duet + '/rr_model?key=boards')
                                            r = urlCall(URL, 3, False)
                                            if r.ok:   #The API type is rr_model
                                                try:
                                                    j = json.loads(r.text)
                                                    version = j['result'][0]['firmwareVersion']
                                                    return 'rr_model', version
                                                except:
                                                    pass
                                    if model == '' or model == 'SBC':
                                            #  model = '/machine/status'
                                            URL = ('http://' + duet + '/machine/status')
                                            if r.ok:
                                                try:
                                                    version = j['boards'][0]['firmwareVersion']
                                                    return 'SBC', version
                                                except:
                                                    pass
                                • Torinundefined
                                  Torin @stuartofmt
                                  @stuartofmt Cool. I'll have a look tomorrow (that is if I will survive tomorrow heatwave...). Cheers buddy.
                                    stuartofmt @Torin
                                    @torin
                                    Ha! - good day to be indoors and futzing with play code 🙂
                                    Good Luck. BTW what programming language are you using?
                                    Part of the reason I ask is that I also have some code for using gmail.
                                    I don't actually use your program as I use DuetMonitor (which only supports gmail) - but it you wanted to extend your connection capabilities - I can sling it in your direction.
                                    I
                                    • Torinundefined
                                      Torin @stuartofmt
                                      @stuartofmt Ah that's quite cool. I've already put that in, however I stripped in my case and just checked for the appropriate content-type header on each URL, in both cases it should be app/json, otherwise it's just wrong.
                                      I'm doing it all in golang, since it's quite nice for such nice things and portability and lack of dependencies.
                                      I have notifications for any email service assuming it can do smtp so should in theory work everywhere. Can you point me to this duetmonitor? First time I'm hearing about this and haven't seen it.
                                      If you want to poke around code and see what's there, that's the current that will go to master soon.
                                      https://gitlab.com/Toriniasty/reprap_notify/-/tree/feature/apiV3/
                                      • Nxt-1undefined
                                        Nxt-1 @Torin
                                        @torin I tried the new version but could not get past identifying v2 of v3 firmware.
                                        Printer is a Duet3 6HC in SBC mode, attached to a Jetson Nano (arm64). That name Nano also runs your project.
                                        Top of rrnotity.yaml looks like this (dwc is running on port 8080)
                                        connection:
                                          host: localhost:8080
                                          polling_time: 5
                                          error_count: 50
                                          api_version: v3
                                        Running the rr_notify results is this output:
                                        2022/07/19 00:40:18 Detecting API version...
                                        2022/07/19 00:40:18 Couldn't identify v2 or v3 firmware
                                        panic: Couldn't identify v2 or v3 firmware
                                        goroutine 1 [running]:
                                        log.Panicf({0x463b71?, 0x454fd0?}, {0x0?, 0x1?, 0x400022a030?})
                                        	/usr/local/go/src/log/log.go:392 +0x6c
                                        main.main()
                                        	/builds/Toriniasty/reprap_notify/cmd/rr_notify/main.go:71 +0x46c
                                        I am not sure how to proceed from here or how to debug. ¯_(ツ)_/¯
                                          stuartofmt @Torin
                                          @torin said in notifications upon start/pause/finish of print:
                                          Here is DuetMonitor
                                          https://forum.duet3d.com/topic/23282/duetmonitor
                                          • Torinundefined
                                            Torin @Nxt-1
                                            @nxt-1 hiya, would you be able to provide me output from these two commands(run from the nano itself):
                                            curl -v http://localhost:8080/machine/system
                                            curl -v http://localhost:8080/rr_model?key=boards
                                            Nxt-1undefined 1 Reply Last reply Reply Quote 0
