2 PT100 daughterboards for the bed heaters, Code?
Firmware installation
    axiom
    I am currently building a relatively large 3D printer. My board is a Duet2 Wifi. Since I don't have any experience yet, I used the RRF Config Tool for the configuration. I can already address and move the axes, I can also warm up the 2 print heads, but they are displayed somewhat awkwardly in the terminal. The heating bed consists of 4 heating elements, each 400x400mm. So I have a total of 4250 watts. I have planned 2 PT100 daughterboards for this and hopefully I have connected them correctly according to the instructions (see photos)pt100.png . I don't understand the description in the instructions, especially how to get the elements visible in the terminal. I am attaching the current code and some photos. The second question is how can I address the 2 extruders for the 2 print heads.
    Can someone send me a code that I can just copy and paste?
    best regards
    Aktueller Config.g:
    ; Konfiguration File for Duet WiFi (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Jun 29 2022 17:59:36 GMT+0200 (Mitteleuropäische Sommerzeit)
    M550 P"axiom eins DMH" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P4 S1 ; physical drive 4 goes forwards
    M584 X0 Y1 Z2 E3:4 ; set drive mapping
    M92 X80.00 Y80.00 Z400.00 E420.00:420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
    M906 X1800 Y1800 Z1800 E1400:1400 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X400 Y400 Z400 S0 ; set axis maxima
    M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
    M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
    M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
    M558 P1 C"zprobe.in" H5 F240 T6000 ; set Z probe type to unmodulated and the dive height + speeds
    G31 P500 X50 Y50 Z2.5 ; set Z probe trigger value, offset and trigger height
    M308 S0 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin e0temp
    M950 H0 C"e0heat" T0 ; create nozzle heater output on e0heat and map it to sensor 0
    M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H0 S280 ; set temperature limit for heater 0 to 280C
    M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
    M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
    M308 S2 P"bedtemp" Y"pt1000" ; configure sensor 2 as PT1000 on pin bedtemp
    M950 H2 C"bedheat" T2 ; create bed heater output on bedheat and map it to sensor 2
    M307 H2 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
    M140 H2 ; map heated bed to heater 2
    M143 H2 S280 ; set temperature limit for heater 2 to 280C
    M106 P0 S1 H0:2 T25 ; set fan 0 value. Thermostatic control is turned on
    M106 P1 S1 H1:2 T25 ; set fan 1 value. Thermostatic control is turned on
    M563 P0 S"Druck" D0 H0:1 F0 ; define tool 0
    M563 P1 S"Stuetz" D1 H1 F0 ; define tool 1
    M575 P1 S1 B57600 ; Display Don
    T0 ; select first tool
    undefined 1 Reply Last reply 14 Jul 2022, 14:57 Reply Quote 0
      Norder @axiom
      @axiom
      Da hat was mit den Fotos nicht geklappt.
      Eventuell sind die von der Dateigröße her zu groß ?
      ---- Translated Text ------
      Something went wrong with the photos.
      Maybe the file size is too big?
      DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
      Thingiverse
      undefined 1 Reply Last reply 14 Jul 2022, 16:24 Reply Quote 0
        axiom @Norder
        @günter-jibben Danke für den Tip!....da passt ja grad mal ein kleines Foto rein!
          So you have 2 PT100 daughterboards and 4 PT100 sensors?
          Which sensor is connected to which heating element?
          In the config tool you can select the PT100 channels from the sensor drop down in the I/O Mapping tab.
          8a4bc44a-6d5d-4379-b04c-c4defaa6cb7a-Screen Shot 2022-07-14 at 3.51.31 PM.png Screen Shot 2022-07-14 at 3.51.31 PM.png
          And here is a basic example config using 3 PT100 sensors one each for bed and 2 hot ends.
          ; Configuration file for Duet WiFi (firmware version 3.3)
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jul 14 2022 15:54:51 GMT-0600 (Central Standard Time)
          M550 P"My Printer" ; set printer name
          M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M208 X230 Y210 Z200 S0 ; set axis maxima
          M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M308 S0 P"spi.cs1" Y"rtd-max31865" ; configure sensor 0 as PT100 on pin spi.cs1
          M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as PT100 on pin spi.cs2
          M308 S2 P"spi.cs3" Y"rtd-max31865" ; configure sensor 2 as PT100 on pin spi.cs3
          M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
          M563 P1 D1 H2 F0 ; define tool 1
          1 out of 4
