    usb dwc
    Using Duet Controllers
    • oolykundefined
      oolyk
      I cannot connect to the wifi in my duet2 wifi. noticed moderator's remark:
      "You can run the Duet via USB too if you want, but you will lose the power of the web interface"
      kindly explain how. thanks!
        dc42 administrators @oolyk
        @oolyk see https://docs.duet3d.com/How_to_guides/Getting_connected/Getting_connected_to_your_Duet for how to get started using USB. Once you have a working USB connection, you should find it easier to get the network connection working.
        oolykundefined 1 Reply Last reply Reply Quote 0
        • oolykundefined
          oolyk @dc42
          @dc42 , thanks.
          I am totally stuck. my paneldue turned dead a year ago and I have since been using wifi dwc but now wifi disappeared as well. cannot manage to have the network being recognized.
          what can I do under these conditions to find the problem of the paneldue ?
          thanks.
            For the PanelDue try updating the firmware
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
            For the loss of wifi, follow the link posted above by DC42 on how to get connected to your duet. It goes through using a USB connection and terminal software to send commands to the Duet. If that doesn't work, I suggest you look at this link and let us know how far you get in testing it.
            https://docs.duet3d.com/en/User_manual/Troubleshooting/Duet_wont_respond
            • oolykundefined
              oolyk @Phaedrux
              @phaedrux. thanks.
              I am trying to follow "activate and connect......when it doesn't work"
              I check the sd card in the computer and it has all the files, including SetNetwork. however, when I command m98P/macros/SetNetwork, it comes back with "could not find..." . tried other macros files with same results. how can I check the card thru YAT?
                Phaedrux Moderator @oolyk
                @oolyk said in usb dwc:
                Well it sounds like it is responding to commands over YAT. Can you send M122 and copy paste the results here? Be sure that your line endings have been set correctly in YAT so that we can get the full report.
