    notifications upon start/pause/finish of print
    Third-party software
    18
    65
    6.3k
    • stuartofmtundefined
      stuartofmt @Torin
      @torin said in notifications upon start/pause/finish of print:
      Can you point me to this duetmonitor? First time I'm hearing about this and haven't seen it.
      Here is DuetMonitor
      https://forum.duet3d.com/topic/23282/duetmonitor
      • Torinundefined
        Torin @Nxt-1
        @nxt-1 hiya, would you be able to provide me output from these two commands(run from the nano itself):
        curl -v http://localhost:8080/machine/system
        curl -v http://localhost:8080/rr_model?key=boards
        Nxt-1undefined 1 Reply Last reply Reply Quote 0
        • Nxt-1undefined
          Nxt-1 @Torin
          @torin They result in a 404 for both, though I would not be able to guess why since the base address does seem to be reachable, though understandably complaining about the lack of JS.
          *   Trying 127.0.0.1...
          * TCP_NODELAY set
          * Connected to localhost (127.0.0.1) port 8080 (#0)
          > GET /rr_model?key=boards HTTP/1.1
          > Host: localhost:8080
          > User-Agent: curl/7.58.0
          > Accept: */*
          < HTTP/1.1 404 Not Found
          < Content-Length: 0
          < Date: Tue, 19 Jul 2022 14:44:56 GMT
          < Server: Kestrel
          * Connection #0 to host localhost left intact
          * Rebuilt URL to: http://localhost:8080/
          * TCP_NODELAY set
          > GET / HTTP/1.1
          > Accept: */*
          < HTTP/1.1 200 OK
          < Content-Length: 1441
          < Content-Type: text/html
          < Date: Tue, 19 Jul 2022 14:47:27 GMT
          < Server: Kestrel
          < Accept-Ranges: bytes
          < ETag: "1d8772d0a7368a1"
          < Last-Modified: Fri, 03 Jun 2022 09:33:54 GMT
          <!DOCTYPE html><html lang="en"><head><meta charset="utf-8"><meta http-equiv="X-UA-Compatible" content="IE=edge"><meta name="viewport" content="width=device-width,initial-scale=1,user-scalable=0"><!--[if IE]><link rel="icon" href="/favicon.ico"><![endif]--><title>Duet Web Control</title><link href="/css/app.62f87138.css" rel="preload" as="style"><link href="/js/app.d9dc885b.js" rel="preload" as="script"><link href="/css/app.62f87138.css" rel="stylesheet"><link rel="icon" type="image/png" sizes="32x32" href="/img/icons/favicon-32x32.png"><link rel="icon" type="image/png" sizes="16x16" href="/img/icons/favicon-16x16.png"><link rel="manifest" href="/manifest.json"><meta name="theme-color" content="#2196f3"><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black"><meta name="apple-mobile-web-app-title" content="Duet Web Control"><link rel="apple-touch-icon" href="/img/icons/apple-touch-icon-152x152.png"><link rel="mask-icon" href="/img/icons/safari-* Connection #0 to host localhost left intact
          pinned-tab.svg" color="#2196f3"><meta name="msapplication-TileImage" content="/img/icons/msapplication-icon-144x144.png"><meta name="msapplication-TileColor" content="#000000"></head><body><noscript><strong>We're sorry but Duet Web Control does not work properly without JavaScript enabled. Please enable it to continue.</strong></noscript><div id="app"></div><script src="/js/app.d9dc885b.js"></script```
          Duet3D and delta printer enthousiast. Buildlog
          Looking for Duet3D configuration support, check out Nxt-3D
          Torinundefined 1 Reply Last reply Reply Quote 0
          • Torinundefined
            Torin @Nxt-1
            @nxt-1 Right, so the second paste is wrong and missing URI 🙂 and I had a thought as well, since there's '?' in URI bash might be screwing around with it try again with:
            curl -v "http://localhost:8080/rr_model?key=boards"
            • Nxt-1undefined
              Nxt-1 @Torin
              I did in fact ment to post it without URI, just to show that can I fact make a connection.
              Here's the two requests, as requested 🙂
              * TCP_NODELAY set
              > GET /machine/system HTTP/1.1
              > Accept: */*
              < Content-Length: 0
              < Date: Tue, 19 Jul 2022 15:39:09 GMT
              < Server: Kestrel
              * TCP_NODELAY set
              > Accept: */*
              < Content-Length: 0
              < Date: Tue, 19 Jul 2022 15:39:18 GMT
              < Server: Kestrel
              • Torinundefined
                Torin @Nxt-1
                @nxt-1 That's bit odd according to the previous post it should be either one of those two URLs.
                @stuartofmt / @chrishamm any idea why either doesn't work?
                • chrishammundefined
                  chrishamm administrators @Torin
                  @torin It's /machine/status, not /machine/system. Support for rr_ requests will come in v3.5.
                  Duet software engineer
                  • Torinundefined
                    Torin @chrishamm
                    @chrishamm Awesome, thanks for the great spot, not sure how I missed it.
                    @Nxt-1 would you mind giving it another go please? also api_version not needed anymore, software will try to detect it automatically.
                    • Nxt-1undefined
                      Nxt-1 @Torin
                      @torin /machine/status does give me a wall of json output 🙂 .
                      curl -v http://localhost:8080/machine/status
                      * TCP_NODELAY set
                      > GET /machine/status HTTP/1.1
                      > Accept: */*
                      < HTTP/1.1 200 OK
                      < Content-Length: 14094
                      < Content-Type: application/json
                      < Date: Wed, 20 Jul 2022 13:45:18 GMT
                      < Server: Kestrel
                      {"boards":[{"accelerometer":null,"bootloaderFileName":null,"canAddress":0,"closedLoop":null,"directDisplay":null,"firmwareDate":"2022-06-01","firmwareFileName":"Duet3Firmware_MB6HC.bin","firmwareName":"RepRapFirmware for Duet 3 MB6HC","firmwareVersion":"3.4.1","iapFileNameSBC":"Duet3_SBCiap32_MB6HC.bin","iapFileNameSD":"Duet3_SDiap32_MB6HC.bin","maxHeaters":32,"maxMotors":6,"mcuTemp":{"current":44,"min":39.8,"max":50.4},"name":"Duet 3 MB6HC","shortName":"MB6HC","state":"unknown","supports12864":false,"supportsDirectDisplay":false,"uniqueId":"08DJM-9P63L-DJMSS-6JKD0-3S06T-9AF79","v12":{"current":12.3,"min":12.2,"max":12.4},"vIn":{"current":32.1,"min":31.9,"max":32.3}}],"directories":{"filaments":"0:/filaments/","firmware":"0:/firmware/","gCodes":"0:/gcodes/","macros":"0:/macros/","menu":"0:/menu/","scans":"0:/scans/","system":"0:/sys","web":"0:/www/"},"fans":[{"actualValue":0,"blip":0.1,"frequency":2000,"max":0.7,"min":0,"name":"Compressor","requestedValue":0,"rpm":-1,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":1,"blip":0.1,"frequency":25000,"max":1,"min":0,"name":"Duet","requestedValue":1,"rpm":2039,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}},{"actualValue":1,"blip":0.1,"frequency":25000,"max":1,"min":0,"name":"Pump","requestedValue":1,"rpm":4539,"thermostatic":{"heaters":[],"highTemperature":null,"lowTemperature":null}}],"global":{},"heat":{"bedHeaters":[0,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1],"chamberHeaters":[-1,-1,-1,-1],"coldExtrudeTemperature":160,"coldRetractTemperature":90,"heaters":[{"active":0,"avgPwm":0,"current":33.6,"max":150,"min":-273.1,"model":{"coolingExp":1.4,"coolingRate":0.138,"deadTime":19.5,"enabled":true,"fanCoolingRate":0,"heatingRate":0.577,"inverted":false,"maxPwm":1,"pid":{"d":0.849,"i":0.0008,"overridden":false,"p":0.06221,"used":true},"standardVoltage":0},"monitors":[{"action":1,"condition":"tooHigh","limit":150},{"action":0,"condition":"disabled","limit":0},{"action":0,"condition":"disabled","limit":0}],"sensor":0,"standby":0,"state":"off"},{"active":0,"avgPwm":0,"current":29.2,"max":285,"min":-273.1,"model":{"coolingExp":1.4,"coolingRate":0.319,"deadTime":5.4,"enabled":true,"fanCoolingRate":0.038,"heatingRate":1.825,"inverted":false,"maxPwm":1,"pid":{"d":0.268,"i":0.0029,"overridden":false,"p":0.07116,"used":true},"standardVoltage":32.1},"monitors":[{"action":0,"condition":"tooHigh","limit":285},{"action":0,"condition":"disabled","limit":0},{"action":0,"condition":"disabled","limit":0}],"sensor":1,"standby":0,"state":"off"}]},"httpEndpoints":[],"inputs":[{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"HTTP","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Telnet","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":10.5,"inMacro":false,"macroRestartable":false,"name":"File","stackDepth":0,"state":"idle","lineNumber":270768,"volumetric":false},{"axesRelative":false,"compatibility":"Marlin","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"USB","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Aux","stackDepth":0,"state":"reading","lineNumber":7,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Trigger","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Queue","stackDepth":0,"state":"idle","lineNumber":270768,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"LCD","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"SBC","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Daemon","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Aux2","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false},{"axesRelative":false,"compatibility":"RepRapFirmware","distanceUnit":"mm","drivesRelative":true,"feedRate":50,"inMacro":false,"macroRestartable":false,"name":"Autopause","stackDepth":0,"state":"idle","lineNumber":0,"volumetric":false}],"job":{"build":null,"duration":null,"file":{"filament":[7056],"fileName":null,"generatedBy":"Simplify3D(R) Version 4.1.2","height":33.1,"lastModified":"2022-07-17T15:13:52","layerHeight":0.2,"numLayers":165,"printTime":7380,"simulatedTime":4309,"size":7460736,"thumbnails":[]},"filePosition":7460476,"lastDuration":4298,"lastFileName":"0:/gcodes/LampAdapter.gcode","lastFileAborted":false,"lastFileCancelled":false,"lastFileSimulated":false,"layer":null,"layers":[],"layerTime":null,"pauseDuration":null,"rawExtrusion":null,"timesLeft":{"filament":null,"file":null,"slicer":null},"warmUpDuration":null},"limits":{"axes":15,"axesPlusExtruders":25,"bedHeaters":12,"boards":21,"chamberHeaters":4,"drivers":26,"driversPerAxis":8,"extruders":16,"extrudersPerTool":10,"fans":20,"gpInPorts":32,"gpOutPorts":32,"heaters":32,"heatersPerTool":20,"monitorsPerHeater":3,"restorePoints":6,"sensors":56,"spindles":4,"tools":50,"trackedObjects":40,"triggers":32,"volumes":1,"workplaces":9,"zProbeProgramBytes":8,"zProbes":4},"messages":[],"move":{"axes":[{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.2"],"homed":false,"jerk":400,"letter":"X","machinePosition":-5.392,"max":200,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":-200,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":-5.365,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.1"],"homed":false,"jerk":400,"letter":"Y","machinePosition":-24.104,"max":200,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":-200,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":-23.984,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]},{"acceleration":1000,"babystep":0,"current":2400,"drivers":["0.0"],"homed":false,"jerk":400,"letter":"Z","machinePosition":133.866,"max":770.05,"maxProbed":false,"microstepping":{"interpolated":true,"value":16},"min":0,"minProbed":false,"percentCurrent":100,"percentStstCurrent":71,"speed":10000,"stepsPerMm":160,"userPosition":133.2,"visible":true,"workplaceOffsets":[0,0,0,0,0,0,0,0,0]}],"calibration":{"final":{"deviation":0.037,"mean":0},"initial":{"deviation":0.038,"mean":-0.033},"numFactors":8},"compensation":{"fadeHeight":null,"file":null,"liveGrid":null,"meshDeviation":null,"probeGrid":{"axes":["X","Y"],"maxs":[188.8,188.8],"mins":[-188.7,-188.7],"radius":190,"spacings":[41.9,41.9]},"skew":{"compensateXY":true,"tanXY":0,"tanXZ":0,"tanYZ":0},"type":"none"},"currentMove":{"acceleration":0,"deceleration":0,"laserPwm":null,"requestedSpeed":0,"topSpeed":0},"extruders":[{"acceleration":3000,"current":750,"driver":"0.3","filament":"","factor":1,"jerk":2000,"microstepping":{"interpolated":true,"value":16},"nonlinear":{"a":0,"b":0,"upperLimit":0.2},"percentCurrent":100,"percentStstCurrent":71,"position":7053.9,"pressureAdvance":0.14,"rawPosition":7054.8,"speed":10000,"stepsPerMm":414}],"idle":{"factor":0.6,"timeout":30},"kinematics":{"deltaRadius":231.522,"homedHeight":770.057,"printRadius":200,"towers":[{"angleCorrection":-0.02,"diagonal":501.3,"endstopAdjustment":0.413,"xPos":-200.544,"yPos":-115.692},{"angleCorrection":-0.091,"diagonal":501.3,"endstopAdjustment":-0.814,"xPos":200.319,"yPos":-116.08},{"angleCorrection":0,"diagonal":501.3,"endstopAdjustment":0.402,"xPos":0,"yPos":231.522}],"xTilt":-0.009,"yTilt":0.003,"name":"delta","segmentation":null},"limitAxes":true,"noMovesBeforeHoming":true,"printingAcceleration":20000,"queue":[{"gracePeriod":0.01,"length":60},{"gracePeriod":0.01,"length":5}],"rotation":{"angle":0,"centre":[0,0]},"shaping":{"amplitudes":[],"damping":0.1,"durations":[],"frequency":40,"minAcceleration":0,"type":"none"},"speedFactor":1,"travelAcceleration":20000,"virtualEPos":0,"workplaceNumber":0},"network":{"corsSite":null,"hostname":"server","interfaces":[{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"AE:A2:57:DA:70:FA","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"48:B0:2D:3D:3E:E4","numReconnects":null,"signal":null,"speed":10,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:35","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:35","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":null,"configuredIP":null,"dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"A6:73:89:4F:B4:37","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":null,"type":"lan"},{"activeProtocols":[],"actualIP":"172.17.0.1","configuredIP":"172.17.0.1","dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":null,"mac":"02:42:A8:9B:B4:7D","numReconnects":null,"signal":null,"speed":0,"state":"disabled","subnet":"255.255.0.0","type":"lan"},{"activeProtocols":[],"actualIP":"192.168.178.22","configuredIP":"192.168.178.22","dnsServer":"127.0.0.53","firmwareVersion":null,"gateway":"192.168.178.1","mac":"58:96:1D:13:6F:0A","numReconnects":null,"signal":-71,"speed":0,"state":"active","subnet":"255.255.255.0","type":"wifi"}],"name":"server"},"plugins":{},"scanner":{"progress":0,"status":"D"},"sensors":{"analog":[{"lastReading":33.6,"name":"Bed","type":"thermistor"},{"lastReading":29.2,"name":"Hotend","type":"thermistor"}],"endstops":[{"highEnd":true,"triggered":false,"type":"inputPin"},{"highEnd":true,"triggered":false,"type":"inputPin"},{"highEnd":true,"triggered":false,"type":"inputPin"}],"filamentMonitors":[],"gpIn":[],"probes":[{"calibrationTemperature":25,"deployedByUser":false,"disablesHeaters":false,"diveHeight":5,"lastStopHeight":-0.116,"maxProbeCount":10,"offsets":[0,0,0.1],"recoveryTime":0.5,"speeds":[1000,1000],"temperatureCoefficients":[0,0],"threshold":100,"tolerance":0.03,"travelSpeed":10000,"triggerHeight":-0.1,"type":8,"value":[0]}]},"spindles":[{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"},{"active":0,"canReverse":false,"current":0,"frequency":0,"min":60,"max":10000,"state":"unconfigured"}],"state":{"atxPower":null,"atxPowerPort":null,"beep":null,"currentTool":0,"deferredPowerDown":null,"displayMessage":"","dsfVersion":"3.4.1","dsfPluginSupport":true,"dsfRootPluginSupport":false,"gpOut":[],"laserPwm":null,"logFile":null,"logLevel":"off","messageBox":null,"machineMode":"FFF","macroRestarted":false,"msUpTime":230,"nextTool":0,"pluginsStarted":false,"powerFailScript":"","previousTool":-1,"restorePoints":[{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,238.806],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1},{"coords":[0,0,0],"extruderPos":0,"fanPwm":0,"feedRate":* Connection #0 to host localhost left intact
                      50,"ioBits":0,"laserPwm":null,"spindleSpeeds":[],"toolNumber":-1}],"status":"idle","thisInput":null,"time":"2022-07-20T15:44:46","upTime":4052689},"tools":[{"active":[0],"axes":[[0],[1]],"extruders":[0],"fans":[0],"feedForward":[0],"filamentExtruder":0,"heaters":[1],"isRetracted":false,"mix":[1],"name":"Hotend","number":0,"offsets":[0,0,0],"offsetsProbed":0,"retraction":{"extraRestart":0,"length":0.9,"speed":45,"unretractSpeed":45,"zHop":0.1},"spindle":-1,"spindleRpm":0,"standby":[0],"state":"active"}],"userSessions":[{"accessLevel":"readWrite","id":33,"origin":"94.105.126.101","originId":-1,"sessionType":"http"}],"volumes":[{"capacity":236242378752,"freeSpace":220662013952,"mounted":true,"name":null,"openFiles":null,"partitionSize":236242378752,"path":"/","speed":null}]}
                      However launching the updated executable I get continous json errors:
                      (I am running rrf 3.4.1 fyi)
                      ./reprap_notify_linux_arm64
                      2022/07/20 15:48:57 Detecting API version...
                      2022/07/20 15:48:57 Detected firmware revision 2
                      2022/07/20 15:48:57 Error parsing JSON: unexpected end of JSON input
                      • Torinundefined
                        Torin @Nxt-1
                        @nxt-1 Interesting, can you provide me full curl of:
                        curl -v 'http://localhost:8080/rr_status?type=3'
                        curl -v http://localhost:8080/rr_fileinfo
                        (those two below probably will not work)
                        curl -v 'http://localhost:8080/rr_model?key=job'
                        curl -v 'http://localhost:8080/rr_model?key=state'
                        • Nxt-1undefined
                          Nxt-1 @Torin
                          curl -v 'http://localhost:8080/rr_status?type=3' -> 404
                          curl -v http://localhost:8080/rr_fileinfo -> 404
                          curl -v 'http://localhost:8080/rr_model?key=job' -> 404
                          curl -v 'http://localhost:8080/rr_model?key=state' -> 404
                          Which makes sense, since Chrishamm mentioned the rr_ system wil be introduced in v3.5
                          • Nxt-1undefined
                            Nxt-1 @Nxt-1
                            @Torin So, it's been a while. I finaly broke down and installed a Go environment so I can play around with your project.
                            What I belive is going on is that there is rrf3 and 2, which your latested beta does differentiate between, though not entirely correct. Within rrf3 a subdivision must be made between the SBC version and the standalone version. The standalone version (rrf3) will get detected as is and work as intended (I assume I cannot test this). Rrf2 will also work I believe (again, I cannot test this). However, SBC mode (rrf3) will not work since it uses the /machine/status syntax which will lead it down the rrf2 branch of your code. That wont work as rr_status is deprecated and returns resulting in a empty response. Which is obviously not json parsable, hence the continuous json errors I reported earlier. @chrishamm please correct me if I am wrong at any point here.
                            What I belive needs to change to make all of this work:
                            • Expand the api version check in main to handle rrf3 sbc as a separate case (or pass the version/type as a config parameter again)
                            • Make a 3rd handler for rrf3 sbc that uses /machine/status to get the full object model and takes the data it needs from it
                              -> I've changed the v2handler to package for now as an example on how this could work, check the files attached below
                            Some other changes I think would be useful if added:
                            • Make the connection protocol part of the host parameter. I.e. add the http part in there as well. For example my machine normally does not listen to http requests so making this user changeable would save some hassle on my side 😇
                            • Add the same delay to the loop in case of errors, so the loop does not run at mach3 🙂
                            Example implementation for rrf3 sbc handler (currently sits in place of the v2 handler)
                            v2_handler.gcode
                            types.gcode
                            chrishammundefined 1 Reply Last reply Reply Quote 1
                              chrishamm administrators @Nxt-1
                              @nxt-1 I would unify /machine/status and rr_model, then you can use basically the same data in your code. DSF 3.5-b1 will be able to emulate rr_ requests (except for rr_status and rr_config), too.
                              stuartofmtundefined 1 Reply Last reply Reply Quote 0
                                stuartofmt @chrishamm
                                @chrishamm
                                I'm not sure I'm following what the issue is or if there is a better / neater way (than I use) .
                                In an attempt to assist, I posted an excerpt of code that I use in most of my (python) applications. DuetLapse3 etc.
                                https://forum.duet3d.com/topic/11088/notifications-upon-start-pause-finish-of-print/44
                                Is this sub-optimal? about to be outdated? just clumsy?
                                • stuartofmtundefined stuartofmt referenced this topic
                                  chrishamm administrators @stuartofmt
                                  @stuartofmt That's alright since it already uses the object model.
                                  • GeneRisiundefined
                                    GeneRisi @Torin
                                    @Torin Hello! I tried using this to send a text message to my phone via email. I have "email: 1234567890@vtext.com" and I keep getting messages from mail-daemon@comcast.net that delivery failed permanently and the recipients is "(empty line)". Is it possible that the email address starting with a number is not working as intended?
                                    Thanks!
                                    • mballinundefined
                                      mballin
                                      This post is deleted!
