1LC board z-endstop issue
Using 3.4.1, Duet3Mini5+, Duet 3 Toolboard 1LC
The documentation says "Input/output with +5V power, for endstops, Z-probes.Input is 30V-tolerant"
Using
M558 P5 C"20.io1.in" H1.5 F600 T8000 A3 S0.03
does not recognize this as an endstop for z (not displayed in DWC and response is no z-sensor). All other things connected to the extension board (actually 2 boards) work fine.
Found this comment by DC42 "Endstop switches connected to the main board cannot control motors on an expansion board". Is the opposite true "Motors connected to main cannot be controlled by switches connected to expansion boards"? This would be a mistake in the documentation.
Any insights?
@wschadow change from
P5
toP8
@jay_s_uk Thanks, that did the trick
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
