    Mounting a radial fan on the Smart Effector
    Smart effector for delta printers
    16
    36
    6.6k
    • Jimborrundefined
      Jimborr
      The radial fan is far better in my opinion and I was considering myself to try and design something, but
      I lack the time anytime soon.
      But If you find a solution that'd be great πŸ™‚
      • hamelundefined
        hamel
        I used 2 3010 blowers and don't use a nozzle. I placed them so that they swirl around the nozzle to get max air flow at the tip. I'll throw up a pic tonight. I tried one larger radial, but the flow reduced so much from redirecting it to both sides was dramatic. I have much more airflow now, but the downside is the smaller radial fans are kind of expensive compared to the 5015 ones.
        • Edkirkundefined
          Edkirk
          Where did you get the radial fans? I have been trying to find a source for a good small fan to use on my delta.
          I have tried a verity of (part cooling) fans on different machines, my best results have been with high volume low velocity.
          Thanks, Ed
          • number40fanundefined
            number40fan
            Here is a couple of pics showing how I have mounted a 40x10 blower fan.
            • adavidmundefined
              adavidm
              @number40fan
              That looks perfect. What model number is that fan, if you don't mind me asking, I've not seen a tiny blower fan like that on general sale?
              • DADIYundefined
                DADIY
                @number40fan:
                http://preview.ibb.co/ftRzAm/fan.jpg
                http://preview.ibb.co/d2BzAm/IMG_20171023_162724.jpg
                Looks good, is there any parts to 3d print to make this work? Also whats the noise like compared to a standard 40mm fan.
                  number40fan
                  12 volt fans.
                  Edit: The listing for the 12 volt fans on ebay has been discontinued. Search for 40x10 blower fan and you'll find both 12V and 24V.
                  24 volt fans.
                  https://www.aliexpress.com/item/2PCS-Gdstime-40mm-40x10mm-4CM-DC-24V-0-1A-Mini-Turbo-Blower-Cooling-Cooler-Fan-For/32799434002.html?spm=a2g0s.9042311.0.0.quhQCp
                  I did have to print some small pieces to attach to the effector and for the nozzle end. Then I just hot glued the fan to both pieces. Away from that computer with the files, but will try to remember to get them up.
                    number40fan
                    @DADIY:
                    Missed this earlier. I can't hear it over the 30mm hotend fan.
                      number40fan
                      https://1drv.ms/f/s!Aubeh9qhGMnugRJP1NWykcZDVWFM
                      Let me know if this works for getting the files.
                      • hamelundefined
                        hamel
                        Thanks! I have issues with one sided air flow, so I will try and make a mount for the other side to give it another fan.
                          number40fan
                          I have tried. Just not enough room. But, I am trying to keep both fans vertical and inside the effector.
                          • hamelundefined
                            hamel
                            I used 2 4010 radials and no nozzles. I positioned them while running, and found they actually had a very focused, but far off axis flow of air. Due to this I had to have them pretty off axis to get the air in the right spot without going below the nozzle. I have one blowing just across the front side of the nozzle, and one blowing just off the back in the opposite direction, and it has a nice swirling flow of air right at the tip, with no warm spot under the extended side of the heater block. They stick out from the effector slightly. I could get them inside of the effector with 3010's and a nozzle, but I am finding that it doesn't matter, and the fans sticking out don't get in the way.
                            https://photos.app.goo.gl/lzuc5FcrEgM3YD5W2
                            • hamelundefined
                              hamel
                              They look really off, but the air flow is pointed directly in front of and behind the nozzle.
                              I might give an aquarium air pump a try if I can find one that will flow enough air to keep the entire area under the block cool.
                              I have seen people plumb a hose into bent copper rings right around the nozzle fed by a pump. I don't remember the name of the design, but it is well known. I don't think I will like that, as I really like the extra air flow that cools the entire area…but I might try it sometime.
                                number40fan
                                Berd Air is the one with the copper tubing.
                                My old effector had two of these fans on opposite sides of the hot end. With the same type of nozzle I have on now, it did just that. Created a swirl pattern around the tip.
                                  number40fan
                                  I just realized that I had uploaded the wrong fan to effector mount that was in the previous link a few posts up. It has now been changed.
                                  I also included a mount for the hot end fan (30mm) that drops the fan down and away 10mm.
                                  • DADIYundefined
                                    DADIY
                                    @number40fan:
                                    12 volt fans.
                                    24 volt fans.
                                    Ive bought from this seller on Aliexpress and after 40 days of no delivery doesn't want to give refund like their buyer protection, which sadly automatically closes at 40 days.
                                    EDIT: Seller did just refund after all.
                                    I did find them on ebay at the same price by searching for 24v Fan 4010S.
                                    • Juggeliundefined
                                      Juggeli
                                      I too have been experimenting with different blower fan mounts. I tried my design with 40x40x20mm and 45x45x10mm blower fans but these seem to be just a little too big to fit on the effector assembly and to not reduce the printing area. I just got the shipment for the Gdstime 40x40x10mm blowers and adapted my design for those. I already printed the parts but haven't yet had time to install those, so they might or might not fit πŸ™‚ I'll post more pics after i try these.
                                      https://cad.onshape.com/documents/8ba77f2402fa7158a8d70539/w/3a248fe5905849418e449f95/e/1539f40d5e31d733d60ec655
                                      • hamelundefined
                                        hamel
                                        I'll give it a try. Looks like a nice design. Test printing now.
                                        • hamelundefined
                                          hamel
                                          https://cad.onshape.com/documents/e3ad7802741e48f7b333d901/w/d3234fc2aae1fdcd65eb5f59/e/b077e46d6fa1feab4594d930
                                          Had to move the ducts forward 10mm to get the air on the nozzle. Without it just blows 10mm behind the heater block. Works great and I love how it looks. Great design job. I'm reprinting now in transparent to see if it helps the LEDs reach.
                                          Thanks again.
                                          • Juggeliundefined
                                            Juggeli
                                            Oh yes good point. Thanks for that. The exit hole is aligned with the nozzle but the airflow itself goes behind the nozzle. Gotta reprint mine now. Also have to make a slight adjustment on where the fan exit meets the shroud
