Solved error G0\G1 home Z ratrig vcore 500
Hi everyone
I need some help with first config my rat rig vcore 500. Error like you see on the screen
I tried many option from few days but allways the same result. This is my first printerconfig.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"V-Core 3" ; set printer name M669 K1 ; CoreXY G21 ; Set Units to Millimeters ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S0 D3 ; physical drive 0.0 goes forwards M569 P0.1 S0 D3 ; physical drive 0.1 goes forwards M569 P0.2 S0 D3 ; physical drive 0.2 goes forwards M569 P0.3 S1 D3 ; physical drive 0.3 goes forwards M569 P0.4 S1 D3 ; physical drive 0.4 goes forwards M569 P0.5 S1 D3 ; physical drive 0.5 goes forwards M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 ; set steps per mm M906 X1000 Y1000 Z800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X10800.00 Y10800.00 Z1000.00 E3600.00 ; set maximum speeds (mm/min) M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X510 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io0.in" ; configure active high endstops M574 Y2 S1 P"io1.in" ; configure active high endstops M671 X-4.5:250:504.5 Y-4.52:505:-4.52 S5 ; define positions of Z leadscrews or bed levelling screws M557 X20:480 Y20:480 P5 ; define 5x5 mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 ; create bed heater output on out5 and map it to sensor 0 M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C ;; Run Bed PID Tune!! Below is an example for a 300x300 bed ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; Fans M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"out3" Q500 ; create fan 1 on pin out3 and set its frequency M106 P1 C"Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S250 ; set the maximum temperature in C for heater ; EVA 2 / BMG / E3D V6 M92 E830 ; set extruder steps per mm, 0.9 angle/step (LDO Pancake) M906 E800 ; set extruder motor current (mA) and idle factor in per cent M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend" ;; Run Heater PID Tune!! ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 ; Z-Probe ;; Inductive Probe M558 P5 C"!io3.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X-30 Y-15 Z0.20 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ;; BLTouch M950 S0 C"io7.out" ; Create a servo pin on io7 M558 P9 C"io7.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds G31 P25 X-28.00 Y-13.00 Z0.90 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ; Select default tool T0 ; Pressure Advance M572 D0 S0.10
homeall.g
M201 X500.00 Y500.00 ; Reduce acceleration for homing moves ; BLTouch M280 P0 S160 ; Precautionary alarm release M280 P0 S90 ; Ensure the pin is raised G91 ; Relative positioning G1 H2 Z5 F6000 ; Lift Z relative to current position G1 H1 X-625 Y605 F3600 ; Move quickly to X and Y axis endstops and stop there (first pass) G1 H1 X-625 F1800 ; Move quickly to X and Y axis endstops and stop there (first pass) G1 H1 Y605 F1800 ; Move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X1 Y-1 F600 ; Go back a few mm G1 H1 X-625 Y605 F360 ; Move slowly to X and Y axis endstops once more (second pass) G1 H1 X-625 F360 ; Move slowly to X and Y axis endstops once more (second pass) G1 H1 Y605 F360 ; Move slowly to X and Y axis endstops once more (second pass) M201 X3000 Y3000 ; Return to full acceleration G90 ; Absolute positioning ;G1 X150 Y150 F10000 ; Go to the center of the bed (300x300) ;G1 X200 Y200 F10000 ; Go to the center of the bed (400x400) G1 X250 Y250 F10000 ; Go to the center of the bed (500x500) G30 ; Home Z by probing the bed G91 ; Relative positioning G1 Z5 F100 ; Lift Z relative to current position G90 ; Absolute positioning
homez.g
; BLTouch M280 P0 S160 ; Precautionary alarm release M280 P0 S90 ; Ensure the pin is raised G91 ; Relative positioning G1 H2 Z5 F6000 ; Lift Z relative to current position G90 ; Absolute positioning ;G1 X150 Y150 F10000 ; Go to the center of the bed (300x300) ;G1 X200 Y200 F10000 ; Go to the center of the bed (400x400) G1 X250 Y250 F10000 ; Go to the center of the bed (500x500) G30 ; Home Z by probing the bed ; Uncomment the following lines to lift Z after probing ;G91 ; Relative positioning G1 Z5 F100 ; Lift Z relative to current position G90 ; Absolute positioning
@dejvid17 said in error G0\G1 home Z ratrig vcore 500:
;; Inductive Probe
;; BLTouch
G31 P25 X-28.00 Y-13.00 Z0.90 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bedHow many probes do you have? You've got two different M558 commands.
It sounds like you have a BLTouch so you should delete the inductive probe.
Please send M122 and M98 P"config.g" in the gcode console and copy and paste the results.
You've also got some commands in a strange order which may cause other problems. Like the tool being defined before the heater is defined.
I have one probe BLtouch.
When M558 is on in Z-probe / off in BLTouch bed goes up and can't stop
in other way off in Z-Probe / on in BLTouch still the same ErrorI download a .zip config packeg from ratrig link
Please tell me what I should do with those strange commandsM98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Error: Invalid Z probe index
Error: Unknown pin name 'io7.out'
Error: Unknown pin name 'io7.in'
Error: Invalid Z probe indexM122
RepRapFirmware for Duet 3 Mini 5+ version 3.2.2 running on Duet 3 Mini5plus WiFi (standalone mode)
Board ID: GMDS7-G096U-D65J0-40KM0-M403Z-HS1D4
Used output buffers: 3 of 40 (12 max)
Static ram: 98732
Dynamic ram: 107768 of which 228 recycled
Never used RAM 38488, free system stack 128 words
Tasks: NETWORK(ready,156) HEAT(blocked,315) CanReceiv(blocked,947) CanSender(blocked,358) CanClock(blocked,363) TMC(blocked,106) MAIN(running,418) IDLE(ready,20) AIN(blocked,269)
Owned mutexes: WiFi(NETWORK)
Last reset 00:20:31 ago, cause: power up
Last software reset at 2022-07-31 15:16, reason: User, GCodes spinning, available RAM 38488, slot 0
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
Error status: 0x00
Aux0 errors 0,0,0
Aux1 errors 0,0,0
Supply voltage: min 0.0, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 40000, standstill, SG min/max 0/12, read errors 0, write errors 0, ifcnt 13, reads 49566, writes 13, timeouts 1, DMA errors 0, failedOp 0x6a
Driver 1: position 0, standstill, SG min/max 0/10, read errors 0, write errors 0, ifcnt 13, reads 49567, writes 13, timeouts 0, DMA errors 0
Driver 2: position 4000, standstill, SG min/max 0/12, read errors 0, write errors 0, ifcnt 13, reads 49567, writes 13, timeouts 0, DMA errors 0
Driver 3: position 0, standstill, SG min/max 0/20, read errors 0, write errors 0, ifcnt 12, reads 49568, writes 12, timeouts 0, DMA errors 0
Driver 4: position 0, standstill, SG min/max 0/2, read errors 0, write errors 0, ifcnt 13, reads 49567, writes 13, timeouts 0, DMA errors 0
Driver 5: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 49570, writes 10, timeouts 0, DMA errors 0
Driver 6: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 49571, writes 9, timeouts 0, DMA errors 0
Date/time: 2022-08-01 08:51:00
Cache data hit count 2515220930
Slowest loop: 14.00ms; fastest: 0.12ms
=== Storage ===
Free file entries: 10
SD card longest read time 3.9ms, write time 0.0ms, max retries 0
DMs created 83, maxWait 1173485ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 9, completed moves 9, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
=== AuxDDARing ===
Bed heaters = 0 -1, chamberHeaters = -1 -1
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 24.80ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address f0:08:d1:03:7f:8e
WiFi Vcc 3.36, reset reason Power up
WiFi flash size 2097152, free heap 26184
WiFi IP address 192.168.2.223
WiFi signal strength -44dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
=== CAN ===
Messages queued 11082, send timeouts 11079, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 16
- WiFi -
Where do you have the BLTouch wires connected? Can you show a photo? Did you delete the inductive probe lines?
@Phaedrux
I checked BLTouch wirring twice.
Yes, I delete two command inductive probe
@dejvid17 Those wires look to big for the connector really but if it's a solid connection and you have no loose wire strands that can short out it's "ok" for now I guess.
But your current issue is that you need to look at the duet mini 5+ pinout and adjust your config.g.
I.e there isn't a io7 on a mini5+. https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mini_5+_Hardware_Overview
@rushmere3d thank you !! I change 7 for 2 and home Z done..
but now I tried to bed leveling and another error
G32
Error: Some computed corrections exceed configured limit of 5.00mm: -500.000 -500.000 -500.000 -
@dejvid17 was the bed in the position you posted earlier? I think it's referring to the S5 in your M671, the correction is more than 5mm.
@rushmere3d yes, but next time I correct manual level of the bed and again the same error
M671
Z leadscrew coordinates (-4.5,-4.5) (250.0,505.0) (504.5,-4.5), factor 1.00, maximum correction 5.00mm, manual adjusting screw pitch 0.50mmwhen I change Z from -500 to 500 error almost the same G32
Error: Some computed corrections exceed configured limit of 5.00mm: 500.000 500.000 500.000bed.g
; this script compensates for what the Z offset is
; so if G31 P500 X-30 Y-15 Z1.7 then first probe will be at
; X30 Y20 (when G30 P0 X0 Y5)M561 ; clear any bed transform
G30 P0 X5 Y5 Z500 ; probe near a leadscrew
G30 P1 X150 Y285 Z500 ; probe near a leadscrew
G30 P2 X270 Y5 Z500 S3 ; probe near a leadscrew and calibrate 3 motors -
@dejvid17 Not sure on that one, it feels like it's to do with the whole file set and coordinates. Like can the lead screw coordinates be greater than the min/max? Someone else will need to chip in on it.
G30 P2 X270 Y5 Z500 S3 ; probe near a leadscrew and calibrate 3 motorsI think you need to remove the Z500 from those lines.
@phaedrux thank you
Z should be 99999 and everything works fine.. -
Guy's any ideas what this time is wrong????
It's telling you a lot of the issues, files not found and bad commands.
You seems to be sending Klipper commands?
Do you have a Pause. and Resume.g?
@rushmere3d
I send from super slicer project to printer and after a few sec first error heater 1 no pause.g fileno any of those files
@dejvid17
What firmware is superslicer set up for?
Whats in your Start and end gcode boxes? -
@Rushmere3D
Super slicer fixed up in setting printer was Klipper.
but I don;'t know what do with thatError: Heater 1 fault: heater monitor 0 was triggered Error: Heater 0 fault: temperature rising much more slowly than the expected 1.7°C/sec
Error: Can't activate heater 0 while in fault state
Resume state saved
Warning: Macro file pause.g not foundconfig.g
M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S110 ; set temperature limit for heater 0 to 110C;; Run Bed PID Tune!! Below is an example for a 300x300 bed
;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0; Fans
M106 P1 C"Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CM950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1
M143 H1 S250 ; set the maximum temperature in C for heater; EVA 2 / BMG / E3D V6
M906 E800 ; set extruder motor current (mA) and idle factor in per centM308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend"
;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 -
@dejvid17 Have you PID tuned both the bed and hotend?
@rushmere3d Yes both
and still the same problem Error: Heater 0 fault: temperature rising much more slowly than the expected 0.6°C/sec -
