Hotend Thermistor Issues
I'm having a problem with my Duet 2 WiFi, it was working though I was getting intermittent heater faults on the hotend. I thought that maybe this was due to a flaky connection (I had leads soldered right to the board because the screw terminal had fallen off) so I ended up replacing the screw terminals. Now I see 20 degrees on the dashboard, but when I turn the heater on (LED comes on), I don't see a change in temperature.
I unplugged the thermistor and saw -273.1, measured the resistance of the thermistor at 125 kOhm, saw the resistance decreasing when I held onto the hotend.
My config is attached below:
; generated by RepRapFirmware Configuration Tool v3.3.10 on Mon May 02 2022 10:44:06 GMT-0500 (Central Daylight Saving Time); General preferences
M550 P"Cantilever Monster" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forwards X
M569 P3 S1 ; physical drive 3 goes forwards Y
M569 P2 S0 ; physical drive 2 goes forwards Z
M569 P4 S1 ; physical drive 4 goes forwards E
M569 P1 R-1
M584 X0 Y3 Z2 E4 ; set drive mapping
M92 X76.196 Y99.52 Z806.086 E420.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z400.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z20000 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z250.00 E250.00 ; set accelerations (mm/s^2)
M906 X1200 Y1200 Z1200 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X212 Y300 Z326 S0 ; set axis maxima; Endstops
M574 X1 S3 ; configure sensorless endstop for low end on X
M574 Y1 S3 ; configure sensorless endstop for low end on Y
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
M915 X Y R0 F0; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M307 H1 B1 S1.00 ; disable bang-bang mode for heater and set PWM limit
M572 D0 S0.5M501
M570 S120
; Custom settings are not defined -
@dukemachine said in Hotend Thermistor Issues:
Which screw terminals would that be? The hotend heater terminals?
It sounds like the temp sensor is reading correctly, and it looks like the LED is tuning on, but no temp change.
Can you use a multimeter to check that there is voltage on the heater terminals when the heater is turned on?
@phaedrux Yes the hotend heater screw terminals.
I'm not actually sitting at it right this second but earlier I actually measured between E0- and GND, which showed ~24V when off, ~0V when the heater is on. So the FET seems to be working fine. Some kind of configuration error then maybe? I guess potentially the heater cartridge could be toast.
Is it heating up at all ever?
@phaedrux nope, will try replacing the heater tomorrow and see if that solves it
Well confirmed, heater cartridge needed to be replaced. Thanks for the help.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
