    Anybody wants a stepper motor analyzer?
    281
    32.9k
    • nyaruundefined
      nyaru
      Hi.
      I am planning to sell a small quantity of this analyzer in Japan for CNC users.
      I found a cheap current sensor CC6920BSO-5A made in China at LCSC and tested it. LCSC Part No: #C2880430
      This sensor also drive in 3.3V.
      With this, the current sensor can also be mounted on the board in JLCPCB.
      I want to share you the test result.
      There appears noises on the signal. But I think It is not a problem to get rough forms of waveform.
      movies:
      https://youtu.be/GVSU9TVF_7k
      https://youtu.be/dTQMCF_6i5k
      zaptaundefined 2 Replies Last reply Reply Quote 0
      • zaptaundefined
        zapta @nyaru
        @nyaru, that's very useful, especially the availability from JLCPCB. Thanks.
        I have hard time downloading the datasheet from LCPCB. Do you happen to have it?
        If the sensitivity of this chip is lower, e.g. 200mv/A instead of 400mv/A, it can be compensated in firmware.
        Do CNC users typically need higher current range than 3D printers?
        Edit: The firmware does basic signal filtering which reduces the impact of the noise. https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/acquisition/analyzer.cpp#L323
        nyaruundefined 1 Reply Last reply Reply Quote 0
        • nyaruundefined
          nyaru @zapta
          @zapta
          You can see it from another current value sensor page.
          https://www.lcsc.com/product-detail/Current-Sensors_Cross-chip-CC6920BSO-10A_C2880431.html
          I already changed sensitivity to 264mV/A in firmware. and it works well.
          Yes. Milling and Cutting something in CNC machine need more power than 3D printer. I used 3A stepper motor in my CNC machine.
          Thanks for telling it! This may be the reason why analyzers are less noises than oscilloscopes.
          • zaptaundefined
            zapta @nyaru
            @nyaru, thanks for the datasheet link. It does work.
            BTW, the design has some support for sensor selection using configuration resistors. May or may not be useful for you.
            https://github.com/zapta/simple_stepper_motor_analyzer/blob/main/platformio/src/misc/hardware_config.cpp#L53
            • zaptaundefined
              zapta @zapta
              Here is a sample screenshot of a Windows/python client that talks with the experimental BLE stepper monitor and displays the data in real time. In this example the stepper runs on 12V which causes current reduction in higher speed (shown by the arrows). This is reflected in the current graph, the current vs speed histogram, and the oscilloscope view.
              The Python client is here https://github.com/zapta/ble_stepper_monitor/tree/main/python . Hopefully somebody can write a similar one for mobile devices.
              The probe is powered from the stepper signals and thus can be left embedded in the printer and be connected to any time. Each probe has a unique address which is shown at the upper left part of the picture.
              • zaptaundefined
                zapta @nyaru
                @nyaru said in Anybody wants a stepper motor analyzer?:
                Here is a noise comparison between the Alegro ACS70331EOLCTR-2P5B3 (blue) and the TI TMCS1108A4BQDT (yellow). I don't have yet the JLCPCB CC6920BSO-5A sensor to compare, but may guess is that it's similar to the TI.
                I tested it by disconnecting the stepper connectors, on the new BLE stepper probe which samples at 40khz instead of 100khz.
                The Alegro datasheet says " It incorporates giant magneto-resistive (GMR) technology that is 25 times more sensitive than traditional Hall-effect sensors to sense the magnetic field generated by the current flowing through the low resistance, integrated primary conductor. " such that is needs less gain and thus has less noise.
                • nyaruundefined
                  nyaru @zapta
                  @zapta
                  Thanks for letting me know.
                  It seems that a large part of the problem is the performance of the IC.
                  I have also built an analyzer with the TMCS1108A4B, but I think the CC6920BSO is noisier.
                  Hi.
                  I have made the analyzer using TMCS1101A4B.
                  When using the CC6920BSO for an analyzer, it may be better to set LPF stronger.
                  • gnydickundefined
                    gnydick
                    definitely interested to know more. what are the practical uses, etc.? I'm keen to build my own if your production run is over.
                    • Doc'sundefined
                      Doc's
                      Greetings, I know I'm late to the thread but I must ask if your still offering the stepper motor analyzer? If you are how do I get in line for one.
                      In addition do you know if Thingiverse has the STL file for the case. Again thank you for your efforts.
                      Doc'
                      zaptaundefined Th0mpyundefined nyaruundefined 3 Replies Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @Doc's
                        @doc-s, the model for the case is available here https://github.com/zapta/simple_stepper_motor_analyzer/tree/main/3d
                        I don't provide them but others may do. Let's see if anybody will respond here.
                        Doc'sundefined 1 Reply Last reply Reply Quote 0
                        • Th0mpyundefined
                          Th0mpy @Doc's
                          @doc-s I have a few of the touch screen version. If you are interested send me a direct message.
                          Usually the team that scores the most points wins the game.
                          T-Printerundefined Doc'sundefined 2 Replies Last reply Reply Quote 0
                          • T-Printerundefined
                            T-Printer @Th0mpy
                            @th0mpy Hello, I am very interested in one, how, with payment, and shipment?
                            Th0mpyundefined 1 Reply Last reply Reply Quote 0
                            • nyaruundefined
                              nyaru @Doc's
                              @doc-s I have a small amout of analyzer kits using the CC6920BSO-5A shown here.
                              Hi.
                              I sell it in Japan at the following page .
                              https://nyarurato.booth.pm/items/4025304
                              If you need them with international shipping, you can order them from the web page using a proxy service or by sending direct message to me on this forum.
                              Payment would be made by PayPal or T/T transfer.
                              If anyone else is interested, please send me a direct message.
                              • zaptaundefined
                                zapta @nyaru
                                Is it ok to link it in the page below, saying that people can buy it from your site?
                                • nyaruundefined
                                  nyaru @zapta
                                  @zapta said in Anybody wants a stepper motor analyzer?:
                                  Of course it is OK.
                                  I hope other sellers will appear for users in other countries, because shipping from Japan is expensive to non-Asian countries.
                                  zaptaundefined 1 Reply Last reply Reply Quote 1
                                  • Th0mpyundefined
                                    Th0mpy @T-Printer
                                    @t-printer I sent you a chat message to discuss further. 🙂
                                    • Doc'sundefined
                                      Doc's @Th0mpy
                                      @th0mpy ,
                                      Greetings and thank you for your reply. I have an I.O. error on my end regarding a direct message. How is that done?
                                      Doc'
                                      • Doc'sundefined
                                        Doc's @zapta
                                        @zapta Greetings and thank you for your reply and thingiverse link.
                                        Doc'
                                        • Th0mpyundefined
                                          Th0mpy @Doc's
                                          @doc-s You should be able to just click the message icon in the upper right of the forum:
                                          • zaptaundefined
                                            zapta @nyaru
                                            I run a steps noise analysis for the TMCS1108A4B. It was done on the bluetooth version which samples at 40Khz instead of 100Khz but I believe the results would be the same.
                                            Test methodology:
                                            1. Energize the stepper. (I used ~1A at an arbitrary stepper micro step position).
                                            2. Reset steps to zero. This resets the full steps but maintains the steps fraction.
                                            3. Sample the steps reading at ~1sec interval, for a total of ~150 samples.
                                            4. Compute peak to peak and RMS noise (in steps units) using the spreadsheet here https://github.com/zapta/ble_stepper_monitor/tree/main/analysis
                                            The noise results I got were 0.09 steps peak to peak and 0.0166 steps RMS. This is much better than I expected so I hope my methodology and match are correct. 😉
