    Update fail on very first step!
    Firmware installation
    1.9k
    • Andy Cohenundefined
      Andy Cohen @Phaedrux
      @phaedrux So... what should I do next? 3.3? 3.4.1? Stop and get a shot of Whiskey?
        @phaedrux DOH!
        It lost the connection!
        How do I upload pics on this system?
          You can drag an image file onto the message window
          Andy Cohenundefined 1 Reply Last reply Reply Quote 0
              do you have chrome installed to try?
              We could also try leaving 3.0 behind and going straight to 3.4 but it takes some manual doing.
              Andy Cohenundefined 2 Replies Last reply Reply Quote 0
                @phaedrux I think I figured it out. I got the web control to load.
                Reloaded it 3 times and it worked OK.
                I have a PanelDue (already updated FW for 3.3 not 3.0) which was connected physically but on the screen it said it was connecting. Seemed to make sense there may have been a lot of EM noise on this cable which goes across the entire box to the front. I disconnected it and it's been OK for the longest amount of time.
                I tried so many things! I even put a repeater right next to the board! It was the noisy Paneldue cable all the time.
                So assuming this was the problem... what should I do next???
                  @phaedrux Still good. I think that was the problem.
                  So should I update to 3.3 or go right to 3.4.1???
                  Then after that will be doing the config file. This is a tool changer.
                    Update to 3.3 first, and then 3.4.1. That should help avoid any possible problems. The firmware folder changes in 3.3.
                    Once you are at 3.4 the PanelDue might start working again.
                      @phaedrux Got it. Thanks. Chances are I'll have issues when I get to the config file.
                        Andy Cohen @Andy Cohen
                        @andy-cohen Updates to 3.4.1 went OK... I updated the Homing scripts(S to H for G1)...
                        Now the config file. Could you please take a look and let me know what I have to change???
                        ; Configurat; Configuration file for Duet WiFi / Ethernet
                        ; For Toolchanger and RRF 3.3+
                        M111 S0 ; Debugging off
                        G21 ; Work in millimetres
                        M555 P2 ; Set firmware compatibility to look like Marlin
                        M550 P"ToolChanger" ; Set machine name
                        ;M587 S"ssid" P"password" ; WiFi Settings
                        ;M552 S1 P"ssid" ; Enable WiFi Networking
                        M587 S"ATT642" P"4269605351" ; Configure access point. You can delete this line once connected
                        M552 S1 ; Enable Networking
                        M586 P0 S1 ; Enable HTTP
                        M586 P1 S0 ; Disable FTP
                        M586 P2 S0 ; Disable Telnet
                        M575 P1 B57600 S1 ;Paneldue
                        M667 S1 ; Select CoreXY mode
                        M574 X1 Y1 S0 ; Set X / Y endstop stall detection
                        M574 Z1 S2 ; Set Z endstop probe
                        M558 P7 X0 Y0 Z2 H3 F360 I0 T20000 ; Set Z probe type to switch, the axes for which it is used and the dive height + speeds
                        G31 P200 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                        M557 X10:290 Y20:180 S40 ; Define mesh grid
                        ; Drive direction
                        M569 P0 S0 ; Drive 0 X
                        M569 P1 S0 ; Drive 1 Y
                        M569 P2 S1 ; Drive 2 Z
                        M569 P3 S0 ; Drive 3 E0
                        M569 P4 S0 ; Drive 4 E1
                        M569 P5 S0 ; Drive 5 E2
                        M569 P6 S0 ; Drive 6 E3
                        M569 P7 S0 ; Drive 7 COUPLER
                        M569 P8 S0 ; Drive 8 UNUSED
                        M569 P9 S0 ; Drive 9 UNUSED
                        M584 X0 Y1 Z2 C7 E3:4:5:6 ; Apply custom drive mapping
                        M208 X-35:328.5 Y-49:243 Z0:300 C0:500 S0 ; Set axis maxima & minima
                        M350 E16:16:16:16 I1 ; Configure microstepping with interpolation for Orbitors
                        M350 X16 Y16 Z16 I1 ; Configure microstepping with interpolation for X,Y,Z steppers
                        M350 C8 I0 ; Configure microstepping with interpolation for C stepper
                        M92 X100 Y100 Z1600 C100 E679.21:679.21:679.21:679.21 ; Steps per mm for the Orbitors V2
                        M566 X400 Y400 Z8 C2 E300:300:300:300 ; Set maximum instantaneous speed changes (mm/min) Orbitors
                        M203 X35000 Y35000 Z1200 C5000 E 7200:7200:7200:7200 ; Set maximum speeds (mm/min)
                        M201 X6000 Y6000 Z400 C500 E 10000:10000: 10000:10000 ; Set accelerations (mm/s^2) for Orbitors
                        M906 X2000 Y2000 Z1330 C400 E900:900:900:900 I10 ; Set motor currents for the Orbitors
                        M84 S120 ; Set idle timeout
                        M207 S1.75 F7200 Z0.4 ; Set FW Retraction
                        ;Stall Detection
                        M915 C S5 F0 H200 R4700 ; Coupler
                        ;Stall Detection
                        M915 X Y S5 F0 H400 R4700 ; X / Y Axes
                        M305 P0 T100000 B4138 C0 ; Set thermistor
                        M143 H0 S225 ; Set temperature limit for heater 0 to 225C
                        M570 H0 P10 T15 ; Sets the time and temp for heater error check
                        M305 S"T0" P1 R4700 T100000 B4388 ; Set thermistor
                        M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                        M570 H1 P10 T15 ; Sets the time and temp for heater error check
                        M305 S"T1" P2 R4700 T100000 B4388 ; Set thermistor
                        M143 H2 S300 ; Set temperature limit for heater 2 to 300C
                        M570 H2 P10 T15 ; Sets the time and temp for heater error check
                        M305 S"T2" P3 R4700 T100000 B4388 ;Set thermistor
                        M143 H3 S300 ; Set temperature limit for heater 3 to 300C
                        M570 H3 P10 T15 ; Sets the time and temp for heater error check
                        M305 S"T3" P4 R4700 T100000 B4388 ; Set thermistor
                        M143 H4 S300 ; Set temperature limit for heater 4 to 300C
                        M563 P0 S"T0" D0 H1 ; Define tool 0
                        G10 P0 X0 Y0 Z0 ; Reset tool 0 axis offsets
                        G10 P0 R0 S0 ; Reset initial tool 0 active and standby temperatures to 0C
                        M563 P1 S"T1" D1 H2 ; Define tool 1
                        G10 P1 X0 Y0 Z0 ; Reset tool 1 axis offsets
                        G10 P1 R0 S0 ; Reset initial tool 1 active and standby temperatures to 0C
                        M563 P2 S"T2" D2 H3 ; Define tool 2
                        G10 P2 X0 Y0 Z0 ; Reset tool 2 axis offsets
                        G10 P2 R0 S0 ; Reset initial tool 2 active and standby temperatures to 0C
                        M563 P3 S"T3" D3 H4 ; Define tool 3
                        G10 P3 X0 Y0 Z0 ; Reset tool 3 axis offsets
                        G10 P3 R0 S0 ; Reset initial tool 3 active and standby temperatures to 0C
                        M106 P0 S0 ; UNUSED
                        M106 P1 S255 H1 T70 ; T0 HE
                        M106 P2 S0 ; T0 PCF
                        M106 P3 S255 H2 T70 ; T1 HE
                        M106 P4 S0 ; T1 PCF
                        M106 P5 S255 H3 T70 ; T2 HE
                        M106 P6 S0 ; T2 PCF
                        M106 P7 S255 H4 T70 ; T3 HE
                        M106 P8 S0 ; T3 PCF
                        M593 F50 ; cancel ringing at 50Hz
                        ;M376 H15 ; bed compensation taper
                        ;tool offset
                        G10 P0 X-9 Y39 Z-4.55 ; T0 Positive moves closer negative away
                        G10 P1 X-8.8 Y38.8 Z-4.55 ; T1
                        G10 P2 X-9 Y38.8 Z-4.55 ; T2
                        G10 P3 X-8.8 Y38.8 Z-4.55 ; T3
                        M501 ;Use the config-overide.g file
                        ;deselect tools
                        T-1
                        M572 D0 S0.02 ; pressure advance T0
                        M572 D1 S0.02 ; pressure advance T1
                        M572 D2 S0.02 ; pressure advance T2
                        M572 D3 S0.02 ; pressure advance T3
                          I suggest you start with the config tool and create a simple starting config to see the syntax differences. It'll be easier to compare.
                          https://configtool.reprapfirmware.org/Start
