    Error: G1/G2/G3: intermediate position outside machine limits
    391
      A Former User
      hello to all when I launch a print I have this as an error you have an idea of ​​​​this can come please
        Post the gcode you are trying to print. Config.g never hurts either.
        A Former User? 2 Replies Last reply Reply Quote 0
          A Former User @Phaedrux
          @phaedrux
          hello I found the problem I believe line
          G30 P1 X330 Y175 Z-99999 S2; probe near a leadscrew and calibrate 2 motors was badly configured compared to the config
          M208 X340 Y320 Z350 S0; Maximum axis set
            @phaedrux
            I changed 340 to 330
            It's exact?
              What's your probe offset?
                @phaedrux ; ================ Z-Probe ========================
                M558 P8 C"io2.in" A2 B1 H5 F120 T15000 ; set Z probe type to unmodulated and the dive height + speeds (for Mini IR sensor M558 P8 C"io2.in" A2 H5 F120 T15000)
                ;G31 P50 X11.5 Y65.8 Z1.035 ; set Z probe trigger value, offset and trigger height Z1.023
                G31 P50 X-1 Y-20 Z1.300 ; Set Z probe trigger value, offset and trigger height
                M556 S50 X0 Y0 Z0 ; set orthogonal axis compensation parameters
                ;M557 X30:270 Y30:270 P4 ; define mesh grid
                M557 X20:270 Y20:270 P3 ; Define mesh grid
                  Are you still getting the errors when doing a G29 mesh?
                  Or was it when doing a G32?
                    @phaedrux I think I solved the problem, since I changed.
                    m208 x340 to 330
                    I don't get the error anymore
                    • Phaedruxundefined Phaedrux has marked this topic as solved
                      A Former User @A Former User
                      @sgk yes no more error closed this post thank you😀👍
