    Warning: Lost connection to Duet (SPI connection
    936
      A Former User @Phaedrux
      @phaedrux
      OK OK I understand better than tried I'm going to put ip directly on the config. But it's a shame that I can't use the rpi card, that's crazy.
        Phaedrux Moderator @A Former User
        @sgk said in Warning: Lost connection to Duet (SPI connection:
        There may be a problem with the cable or your board.
          @phaedrux with the rpi
            There may be a problem with the cable connecting the Duet to the RPI or your clone duet board.
              @phaedrux yes ok i see there is a way to know? by changing the cable.
                A Former User @A Former User
                It doesn't work but I think I made a mistake somewhere
                M552 S1 192.168.117 ; enable network and acquire dynamic address via DHCP
                M586 P0 S1 ; enable HTTP
                M586 P1 S0 ; disable FTP
                M586 P2 S0 ; disable Telnet
                  192.168.117
                  You only have 3 numbers.
                    @phaedrux yes is my ip
                      An IP address must be a set of 4 numbers.
                        @phaedrux sorry i'm really stupid i didn't pay attention you're right
                          @sgk no it doesn't work it's not possible I'm going crazy
                          M552 S1 192.168.1.117 ; enable network and acquire dynamic address via DHCP
                            You need a P before the ip address.
                            M552 S1 P192.168.1.14
                              @phaedrux ok thank 😊 you it works it works more than testing
                                even if i but a blank sheet i have this error
                                  @sgk
                                  like jay said I have to change the probe that's the best thing I have to do😢
                                    @sgk
                                    no more errors regarding this post thank you all for your help
